Question about Hayward Pool Products Hayward 400k Ng H Series Spa & Pool Heater
Problem with my H400 IDL natural gas electronic ignition heater
I have a Hayward H400 IDL natural gas electronic ignition heater. My heater is about 5 yeras old and I have used it 5 times. I opened the pool this year and followed the directions to fire up the heater and it didn't work. It would start its cycle and I would hear a click then it would catch and I would feel heat from the vent and then after 3 seconds it shuts off. I had my gas company come out and they thought it was a delivery issue. I wasn't sure why now since it had worked all these years but they changed an old regulator and I recieved a greater gas flow but within the tolerance of gas supply needed to operate the unit. They checked all the limits, gas valves, cleaned the flame sensor, burners, cleaned alll the gas pipes made sure there were no obstructions and no cob webs. In the end the diagnosis was bad module controller or flame sensor or both. What do you think. These parts are expensive and I was told I could repalce them myself. help.
    Top Expert:
  • Hayward Pool... Master
  • 8,694 Answers
Bad flame sensor
Posted on Oct 24, 2017
  • 14 Answers
SOURCE: Hauward H400 heater won't turn on
check pressure switch operation most heaters will not operate without sufficient water flow/pressure. You can use a multimeter to troubleshoot the wiring using the schematic. If its induced draft milivolt ignition verify there is suffiecient gas flow to the unit
Posted on May 26, 2009
  • 15 Answers
SOURCE: Hayward H Series 400,000 BTU Pool Heater Won't Ignite
You can not manually light it. Open the front cover look for the gas nozzles brass looking on a tube. on the right side you will see a wire going to a sensor above the next to last burner take the nozzle out for that burner. 7/16 wrench unsrcew the nozzle and see if it is clogged. use something soft to push it out. Spiders love to lay eggs in these. Spray with WD40 and reassemble should work now
Best of luck
Posted on Jun 23, 2009
Coastsider
  • 331 Answers
SOURCE: finned tubes get too hot all thermostats and controls chech out o
Sounds like you might have an elevation vs gas burn issue. If you are using a unit not designed for the elevation it is installed at, the unit can burn incorrectly causing the problem you are reporting. Hayward as well as other manufacturers make units to operate from sea level up to about 2000-3000 foot and units designed for higher elevation. It has to do with burn rates and proper gas mixture with oxygen. higher elevation has less oxygen and thus need different size gas orifices. It also is important to make sure you are using a Natural Gas unit with Nat Gas and not propane. Propane burns much hotter and requires smaller orifices. This can also cause premature burn out. Check with Hayward to determine your unit qualifications vs location of installation
Posted on Apr 14, 2010
john224
  • 1378 Answers
SOURCE: my plumber needs manual for Hayward #H400 FDP
The P at the end stans for propane...the manual found here is for the H400FD series natural gas or propane.
John
Posted on May 31, 2010
StepehnD
  • 78 Answers
SOURCE: hayward H400 error code bo
This error means "Bypass Operation". On the back of the control module there are some "dip switches". They have an on or off position. Check switch number 2. Make sure it is in the "off" position. The "on" position is for a remote thermostat.
Posted on Jun 29, 2010
Replace igniter on h400
Open the main door, locate the 2 white fabric coated wires, they go down towards the base of the heater. This is your igniter, usually a 5/16 nut driver will be the tool you need to remove it.
Jul 04, 2014 | Hayward H-series Electronic Gas Pool...
IF error code when trying to start
Error IF is ignition failure.
Last page shows troubleshoot walk through ranging from low gas pressure to bad gas control valve to failed wiring etc
http://waterheatertimer.org/pdf/Hayward-error-codes.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 28, 2012 | Hayward H-series Electronic Gas Pool...
No LEDs on Hayward H400 ED1
if power to unit and transformer ok need display
Aug 03, 2012 | Hayward H Series Natural Gas Electronic...
CAN A OLD STYLE H400 NATURAL GAS BE CONVERTED TO A LP GAS I HAVE A H400PED2 IT DIED IT IS NOT MAKE ANY MORE IF I FIND A H400 NATURAL GAS CAN IT BE CONVERTED
The last I checked a kit was available for this conversion.
I recommendyou call the Hayward technical support at 908-355-7995and they might be able to help you figure this issue out. Ihope this helps.
Sep 17, 2011 | Hayward H-series Electronic Gas Pool...
Can an H150PI pool heater be converted from propane to natural gas
On this heater, the conversion may be a kit that replaces all the orifices. In any case if you call Hayward technical support they should be able to provide the correct solution. I hope this helps.
Jul 27, 2011 | Hayward H-series Electronic Gas Pool...
I have a hayward H400 serise propane heater. I replaced the gas valve. When it goes tot turn on it takes about a minute then starts clicking to ingnite the gas. SSoem time it lights but then goes out other...
0. Check the spark ignitor conection to the board
1. Check the water by-pass valve if you have it
2. Check your gas pressure. (5-7"wc for natural gas, 9-13"wc for propane gas)
3. Clean your filter for your water system or remove it and try again
4. Check the Hi-limits on your heater
5. Replace the thermostat
May 27, 2010 | Hayward H Series Pool & Spa Heater 400k...
Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Hayward Pool Products Hayward 400k Ng H Series Spa & Pool Heater  Logo
252 people viewed this question
Top Hayward Pool Products Pool & Spa Experts
Jay Finke
Jay Finke
ray gallant
Tom Chichester
Are you a Hayward Pool Products Pool and Spa Expert? Answer questions, earn points and help others
