Question about GE Profile Prodigy WPSE4200A
I washed a rug and it fell apart in the machine. I can't get it to rinse. It will agitate and fill and spin but will not rinse. I took out the hose and drained the water and cleaned out the debris. Somebody told me to clean out the pump. Where is it located?
  • 315 Answers
Remove the front panel and set the timer in the spin cycle and pull the knob to turn the timer on. Open the washer door and listen to the pump to hear if it is running, making a humming noise, or the pump is not do anything at all.
If the pump sounds like it is running, but the washer is not draining, you will need to check for an obstruction anywhere before the pump. It could be in the tub or the hose before the pump.
An obstruction could be the reason why your washer is not draining.
If the pump makes a humming noise, check for an obstruction inside of the pump that is preventing the pump impeller from turning. Also the pump bearings could be worn out and and instead of the motor turning, it could be frozen in place.
If the pump won't do anything, and you don't hear any sound coming from the pump, you will need to check the pump motor winding for continuity to see if this is the cause why the GE washer is not draining.
Make sure that the washer is disconnected from the wall outlet before proceeding. Disconnect the pump wires and take a reading with your ohms meter, the reading should be between 5 and 10 ohms.
If the needle in your meter doesn't move, meaning that the reading is infinity, the pump is bad and must be replace. That could be the reason that your is not draining.
To replace the pump, you will need to disconnect the wires, remove the hoses, and unscrew the two pump holding screws.
Posted on Jun 03, 2009
Why does not agitate on rinse cycle
It shouldn't agitate on rinse cycle. ''Quick wash'' is the last type of ''cycle'' you can select that the machine will ''agitate.'' On ''rinse'' cycle, it will fill with water and then simply drain & spin.
May 18, 2015 | Washing Machines
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Throw rugs are dripping wet after washing. My washer doesn't have just a spin cycle, so I have to rinse and spin. This still doesn't help. Every rug I wash comes out dripping.
The washer is likely detecting an off balance load with only a rug or two. You may want to try and put more rugs or old towles in to offer a counter balance to alleviate off balance condition. Or, you may consider washing the rugs at a commercial facility. They really are hard on the residential machines, especially if they come apart or the backing comes off.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Machine will not agitate during rinse cycle of normal wash.
The brake is part of the mechanism to function the spinning. The agitation is another mechanism to function in the other direction of the same motor. This mechanism is below of the other. The helix part needs to replace to fix this. This should be done when you change the brake. Of course this is a result from the brake change since you have take this apart before you can get in the spinning mechanism. It is good that now you don't have to touch the spinning mechanism, but only the agitation mechanism. It is not from the tight belt. Hope this can help.
Jan 09, 2010 | Dryers
It keeps getting stuck on rinse cycle a
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Check it out....
Good Luck!!
thanks
Jul 19, 2009 | Fisher and Paykel Washing Machines
Washing machine will not spin or agitate.
Replace the timer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Washing machine will fill,agitate,but not rinse or spin
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore Washing Machines
Maytag Dependable Care Plus LAT8824
I think that you mean "Agitate" some of the time that you write "Spin" Yes?
If I understand you correctly, you have no agitation during the "wash" cycle, this is almost certainly a corroded agitator shaft seized up in the transmission.
Oct 05, 2017 | Maytag Dependable Care LAT9706
Washing Machines Logo
50 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
