Question about Dell 3100cn Laser Printer
Margin problem??? So there's a Dell 3100 printer that is used by 7 Dell desktops connected via network.  Whenever I print something, it leaves a 2" margin on the right side of the letter paper, cutting off any text that runs past that.  The first thing I did was check the margin settings in Word, but they're fine.  And it happens in more than just MS Office, but also in notepad.  When I print a Windows XP test page, it doesn't cut anything off, but it still leaves that wide margin.  Funny thing is, in Internet Explorer, it will print the MSN webpage as it should be, leaving only an inch or 3/4 inch of a margin. This happens in more than one computer, so it's likely not an issue with the computer settings.  All the computers are imaged, but the image is shared throughout many more computers in other rooms that don't have this issue (and also don't print to this printer...), so I don't think there's anything wrong with the image either. I've downloaded the new driver, checked margins in the applications, rebooted the printer, initialized the NVRAM, and found no error on the printer.  Nothing's helped! Any ideas???
  • someoneuknow Oct 25, 2007
    It's just letter paper - 8 1/2 x 11" paper, which is the default setting on all applications.  Not sure if that would be it...?
  • Anonymous Mar 25, 2014
    When printing or copying, the unit cuts off the information of every page on the bottom. Have to change margins to allow everything to print.
  • 4 Answers
First thing to check:
In 3100cn Printer Properties, on the 1st tab 'Paper' there is a button at the bottom - 'Margin Shift'. Click on this and make sure it is set to 'No Shift'. By default 'Margin Shift' is on.
Posted on Jan 31, 2008
  • 55 Answers
I can just guess it has to do with the paper being fed. either you have the paper wrong or the paper settings to a different size then the actual dimensions of your print material.
Posted on Oct 24, 2007
I cannot get printer to print documents with equal margins.
Guess you are not using the same page size as the one you've got configured in your computer for printer. ie: you are using Letter and printer is configured to A4
Jul 18, 2015 | Dell Office Equipment & Supplies
Ethernet driver for windows 7
There does not seem to be a valid Windows 7 network driver:
http://ftp.dell.com/Pages/Drivers/dimension-3100.html#Network
You can try the driver for XP to see if that will work, otherwise you may need to buy a new NIC card.
Oct 14, 2013 | Dell Dimension 3100 PC Desktop
I've been using a dell 3100 through a home network for several years. Suddenly I can't print. The network can't find the printer. I can print to it if I connect through USB. I have tried...
Hi
Please check the mention below option
1) First you get any error in your printer screen
2) If you are print through Network please ping your printer if you are not getting the print.
Open command prompt and type ping 192........your pinter ip, if you r getting reply to your printer
its mean your connect to printer.
3) Remove your printer driver and install again.
Jun 01, 2011 | Dell 3100cn Laser Printer
Can't print to HP 2600n over network
The LaserJet 2600N has a built-in print server and can be connected to the local network (normal ethernet cable) directly. While printer sharing via Windows should work, I found it much more convenient to access it without the need of a hosting computer - you do not need to switch on the desktop PC for printing from the Laptop, for example, its also printing faster.
Jan 25, 2010 | HP Color LaserJet 2600n Printer
How to hook up this printer wireless to my main computer
Hi jjank740;
First off, did you try to recycle your printer? Turn it off and back on again. Sometimes power outages can disconnect that printer. If that doesn't work. Go to the printer and access the system network configuration on the led panel. Type in the WEP number and password again, and let it search for the connection. That should do it. Once it's connected you'll see the blue wireless indicator turn on.
Good Luck
Mark
Please don't forget to leave a rating.
Feb 19, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Print 5 x 7 invitations on 3100
You need to adjust the paper size in page setup of the program that you are using to create the invitation. What program are you using?
May 19, 2008 | Dell 3100cn Laser Printer
Dell 926 printing freezing when using remote desktop
I've had a problem with a 926 freezing at the end of printing when deleting the job from the print queue.This was as a local or network computer/printer task.I changed the print processor to winprint/NT EMF 1.008 and this cured the problem.Right click on the printer/properties/Advanced/Print processor and give it a try.HTH.
(Using Vista Ultimate)
Apr 04, 2008 | Dell 962 Photo All-In-One InkJet Printer
HP All-in-one printer C4180 network readiness?
the dell must be set to host or peer to peer on the network for the other computer to find it through tcp/ip or ipp protocol. it comesdown to software set up which is always the biggest headache second to the userintroducing a problem. good luck
Mar 30, 2008 | Computers & Internet
Margin problem
Won't be the printer so I guess that leaves software or printer driver settings or the actual document setup.
Nov 17, 2007 | Samsung ML 2010 Laser Printer
Dell 3100cn Laser Printer Logo
459 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
