Question about ASUS SiS Chipset ME-99 (ME-99/OM/WOA) Motherboard
Hi zidordinateur hi i'm a repair man i need to know ohw can i switch the connector assus to let ok my usb drive
Audio Driver vaio vpcea390x
I'd say you need to get an experienced repair person to resolder the connection.
Feb 27, 2014 | Computers & Internet
I had external hard drive got a new casing just want to know how to put in new casing
Hi
Which type or external drive you have (PATA) or (SATA), connect your driver to your External drive case, The external drive case have both of connector to connect the drive, chose your drive and connect the drive and connect the power, that ok
Now close your drive case and USB one side put in external drive case and second side put your Com/Lapi and switch on your external drive, your com/lapi detecting your external drive and your see the my computer external drive now what ever data you want to store, copy
and enjoy
May 25, 2011 | Computers & Internet
Hi, i installed a new hard drive and the monitor isnt getting a signal at all.
Is the system new? What is the VGA you use, on board or exteral? In case of an external VGA take a look if it fits ok at the mobo.
Waiting clarification, don't hesitate to post.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 22, 2010 | EliteGroup GF7050VT-M Motherboard
1994 Honda Prelude Headlights
checkout the headlight switch and the ground and give the websites a try its www.alldatadiy.com and www.autozone.com if all fails stop by your local library and get your hands on a Haynes auto repair manual for your car also take the headlight out and check the plugs to the headlights and the wires wish you the best of luck Michigan Man
Nov 04, 2009 | 1994 Honda Prelude
USB connector for Western Digital My Book fell off inside
its some difficult to repair. you should purchase a newer case for your Hard disk
Aug 16, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Assus external cd/dvd rom
Hl
You must buy asus external drive its worth
Harry
Oct 31, 2008 | ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM...
Snapped off Flash Drive
Ok, What you need todo, IF the internal circuitboard of the usb memory is still intact, you will need to solder the 4 usb connector pins onto the usb circuitboard of the usb memory.
This is not your device but you should get the idea, you need to solder those 4 connectors back into place, I marked them with red boxes, if the circuitboard is cracked or otherwise damaged, it may be best to give up. Or take it to a electronics repair man, but if the circuitboard is cracked and there are no good connection points the repair will be very difficult but not impossible.
you need to take the plastic cover off from the usb memory and inspect how the board is, you could even send me a picture here by using the attach picture button.
Jul 31, 2008 | Computers & Internet
Need to know where front connectors for firewire usb go
ok..here is the link from the official MSI site ..download the pdg manual..and good luck instaling...
bye;)
Feb 06, 2008 | MSI MS-6380E (MS-6380E-010) Motherboard
Maxtor one touch usb hard drive
I would remove the hard drive from the case and slave it to my primary drive inside the tower. If it is out of warranty then it is likely old and about to die. Maxtors do not exactly have a reputation for longevity. Your best bet would be to image it and restore the image on a new drive.
Mar 19, 2007 | Maxtor USB 2.0 External Enclosure + Hard...
ASUS SiS Chipset ME-99 (ME-99/OM/WOA) Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
