Question about Ovens
Whirlpool Oven AKZ101/1X serial 858510115001 140349004758
Following a power cut I have been unable to use my oven as it just displays STOP. This has happened reviousl however after much knob twisting and switching on and off it has always worked again however this time nothing will seem to work. As the oven was already in house when we moved in we've never had manual and canot locate on whirlpool website either!
Can anyone help?
Thank you
  • 1 more comment
  • 0306910 Dec 12, 2007
    I have had exactly the same problem. Moved into a new house and turned electricity off. When I turned it back on 'stop' was displayed on the LCD screen and I could not longer use the oven. However after messing around with dials etc for a few minutes I managed to get the oven working again. This time however, I experienced a powercut and 'stop' was displayed once again. This time after many many many attempts, the oven will not work.
  • hungrycook Feb 24, 2008
    does anyone have the product description sheet / user guide for whirlpool akz101/1x single oven ? would it be possible to copy / scan it & send it to me please or say where i can get one from
  • bmp229 Aug 28, 2008
    I have somewhat a similar problem. A power outage caused the LCD display to stop working. There is no display at all now. Everything else works on the oven, except the clock and the timer.
    I think the serial number for my whirlpool oven is 0485682.
Press the bell and arrow(pointing to the right) button simultaneously while turning the rotary knob to set the time of day. hope this helps
Posted on Jan 20, 2009
Ensure the oven knob is set to 0 (zero) and press the reset button in the middle
Posted on Oct 26, 2007
Code E0 and F2 with a little lock displayed on touch board of Whirlpool Gas Range. burners work but unable to operate the oven
You will need to press the cancel/stop button, this will clear the display and you will be allow to use the oven. If this does not work yoy will have to unplug the stove for five minutes and then plug back up and this should clear the display and allow the oven to work.
Nov 14, 2009 | Ovens
I have a STOP message on the oven display. The user manual refers me to the product description sheet or the electronic programmer description, neither of which I have. The oven is not working at all while...
HI. This is a control fault, that may be corrected by simply shutting down the appropriate circuit breaker for 5 minutes. This will DE-energize the control board. Once the 5 minutes have passed, simply re-introduce power to the unit. If the unit continues to produce the error, this will confirm that the main control board has failed. it should be replaced asap.
Nov 04, 2009 | Whirlpool RBS275PD Electric Single Oven
I have a whirlpool built in oven. There was a
by setting the clock otherwise oven wont work.
Sep 14, 2009 | Ovens
Whirlpool electric oven problem
thermal fuse to board blows, relays turn fans off, the thermal cut out on rear of oven kills element. change both fuses, install new style oversized blower.
Sep 22, 2008 | Ovens
Whirlpool oven
Press the botton between the two control knobs and hold for a few seconds.
Aug 20, 2008 | Whirlpool AKZ159IX Oven
My whirpool oven display reads stop, how do i turn it off?
This "STOP" message appears when either the cooker has been switched off at the mains or there has been a power cut. What you have to do is a s follows:
1. The knob on the left should be turned anti-clockwise ONE click only.
2. Press the button between the two knobs (under the display) ONCE only. You will now have got rid of the word "STOP" and it will be replaced by _ _ . _ _ symbols.
3. Press the same button twice more or until "12.00" is shown. This is the 24hr clock and can the be adjusted up or down by turning the right hand knob clockwise or anti-clockwise. Its always recomended that you set the clock before useing the oven although you dont have to.
4. Now you can operate the oven as normal.....Good luck with that!
Regards Ian W.
Jul 31, 2008 | Whirlpool AKZ159IX Oven
Re: my whirlpool digital oven
The red key sign is a lock against children. To cancel it you have to hold the two buttons at the same time for 5 seconds (you activate it the same way).
The STOP sign appears after the cooker switches of after a power cut. You just have to press the left button, and, using the right knob, set the time.
Jun 24, 2008 | Ovens
Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Dec 06, 2007 | Whirlpool RBD245PRS Stainless Steel Oven
Ovens Logo
1,040 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
