Question about Ricoh Aficio CL3500N Laser Printer
Can you throw away in regular waste trash the full toner waste bottle?
  • 95 Answers
Yes. You might want to put in inside a plastic garbage bag. The toner is mainly plastic.
Posted on Jun 04, 2009
What is ar407 toner weaste problum in machine and salve
The waste toner bottle is full. You can empty it into a trash bag but beware it is very messy. The waste toner door is on the rear right hand side of the machine. Remove the white bottle and carefully empty it out, then put the bottle back into the machine.
Jun 13, 2014 | Sharp AR407 Waste Toner Bottle Genuine
Waste toner bottle full so replaced but will not reset and says still full
then the clear section of the waste toner bottle is not clear some toner is left blocking the sensor that monitors the waste toner level
Apr 02, 2014 | Konica Minolta New Bizhub C25 Color Laser...
Waste toner is almost full on Savin C9020
The bottom left portion of the display gave the error message:
Waste Toner Bottle 1 Almost Full. Please call service.
They were still able to print, however this message would not go away.
To Fix:
Power down the printer using the normal shutdown method.
Open the top front door.
Remove the cover directly below the 4 toner cartridges.
The removable cover below the toner cartridges is actually the Waste Toner Bottle.
Bring this to the dumpster.
There is a round, clear-plastic tab on the underside of the "bottle". Remove this.
Shake the bottle around over the dumpster. Continue until all the toner has been removed.
Push the clear plastic tab back in place. Wipe off all toner residue before putting it back into the printer.
Put the waste toner bottle back into place. Power on the Savin. Confirm the message no longer appears and that users are able to print.
Feb 08, 2012 | Savin Office Equipment & Supplies
How do i change the waste toner container on a canon imagerunner 3320i?
Hello tandi,
I can help you. First, lets establish a point of reference which will be you satnding at the copier as if you were about to make a copy. The waste toner bottle is located on the left side,lower rear corner. If you have a stapler/sorter you will need to release it from the copier and slide it away from the copier. Notice the small cover that is @ the lower left corner of the copier. Remove the single screw that holds the cover and then remove the cover. The waste toner bottle is now exposed. It even has a hande so that you may slide the bottel STRAIGHT OUT not up or down. Carefully empty the bottle into a trash bag while keeping in mind that holding it low and pouring it slow will avoid a Hiroshima style mess. Once the bottle is empty, look at the "neck" of the bottle. There are "clear windows" at the top of the neck of the bottle. But right now they are not "clear" since they are covered in toner. That's how the copier determines if the bottle is full or not. It shines a beam through the lenses and as long as the beam is not broken the copier is happy.When enough toner rises in the bottle to break the beam the copier "assumes" the bottle is full. So now that you have emptied the bottle you need to use a Q-tip or such to clean your windows ! :-).Re install everything. Turn the "TRUE" main power switch off, or unplug, and then power back up. Happy copying. Please let "fixya" know if I helped. SPINAL
Mar 31, 2011 | Canon Image Runner 3320I Copier
Ricoh aficio Aficio 3224C used toner bottle -1 is full
On a 3224, the used toner bottle is easily replaceable. To get to it, open the front cover of the copier. In the lower left corner, you will see a white or light gray plastic container which slides straight out -- that is the used toner bottle. You can replace it (if you have a new one) by taking the old one out, putting the black plug in the hole to prevent toner from spilling, throwing it away, and inserting the new bottle. If you don't have a new used toner bottle, you can empty this one out into a large bag or trash can and then reinstall it.
Mar 18, 2011 | Ricoh Aficio CL3500N Laser Printer
Canon 2220i - error E000019-0000 does not re-set when turning off from mains
hello denise,
The error code you have means the waste toner bottle is full. I'll explain. As you make copies /prints the device produces the image you wish to see on the output paper on whats called the drum. Then that image is transferred from the drum to the paper and you recieve what you need. In a perfect world all of the image would be tranferred. In reality,there will always be some of the image left behind and must be wiped off clean so the next copy/image does not have a ghost image of the previous copy. That old image is cleaned and (which consists of waste toner) and deposited into the waste toner bottle. What we need to do is empty the waste toner bottle and your device will be happy again. It's not difficult and i know you can take care of it. Just remember that you are dealing with toner, which of course can be a mess. This type of toner can be washed out with cold water even if you decide you need to poor it on your head. LOL. Ok ,using YOU standing in front of the device as a referrence, the waste toner bottle is located on the left of the device, at the rear,lower corner. If you have a stapler attached you will need to "undock" it from the device and slide as far away as you can so you can get to the small panel "about 5 inches x 12 inches". There is one screw you need to remove. That will expose the waste toner bottle. Slide it straight out to you. It will be kinda' heavy.Set it down and find a trashbag. Keeping in mind of the mess potential, open the trashbag, lower the bottle into the trash bag,and slowly empty the bottle. You will see some "poof" no matter how hard you try. As long as you don't "snort" a line of it you need not worry. Disposal of the bag is at your discrection. Now that the bottle is empty, look at the top or"neck" of the bottle.You will see round disks which are windows for the beam of light that the device uses to tell if the bottle is full or not. If those windows are cloudy the device will still think the bottle is full. Wipe those, witha cloth or better yet a Q tip. Re-install the bottle.Power off, then on. YA DID IT!!!!!!!! TADA!!! WOOOOOOOOOOOOOOOOOHOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!. Tell the guys, heck tell the gals!! Congrats! Please let "FIXYA" know I helped. Happy copying, happy life. :-)
Feb 25, 2011 | Canon Office Equipment & Supplies
Waste toner gets full before toner runs out
Actually, the waste toner should get full sometime before the regular toner runs out in laser printers that have several toner cartridges compared to the single waste toner reservoir.
You can dump the toner reservoir out and avoid buying the empty waste toner 'reservoir.'
I did this on my Brother Laser printer and saved about $30 or so for an empty plastic waste toner bottle or jar.
If this is the way the Kyocera-4020DN is, then I would put the waste toner, which is just that, waste, and put it into a plastic zip loc storage bag and throw it away. Don't breath the toner.
Good luck on this repair.
Jul 19, 2010 | Office Equipment & Supplies
Waste toner collection IR 5570
remove the small lower( rear)right side cover 2screw then you will see the waste bottle youcan pull it out and throw away the waste toner
Jul 15, 2009 | Canon imageRUNNER 5570 Copier
Error c7990 waste toner full
Open the left door.remove the waste toner bottle.It is whitish, odd shaped and directly in the front.throw it in the trash carefully.replace it with a new one.close the door.Good luck!
Mar 31, 2009 | Kyocera Mita Office Equipment & Supplies
I use a Lexmark color laser printer. Used toner accumulates in the waste toner bottle. Can I throw the toner away in the trash and reuse the bottle, or am I supposed to throw the used toner and bottle...
The excess toner can just be discarded, and it will not be hazardous to the environment. Toner is simply a dyed carbon powder. I would recommend rinsing it down the drain or disposing it into a plastic bag to prevent a big mess. Toner is very difficult to clean up if you spill it, so clean carefully.
Jul 21, 2008 | Lexmark Office Equipment & Supplies
Ricoh Aficio CL3500N Laser Printer Logo
1,174 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
