1. Log in to your Gmail account. Just type in your username and password and click on "Sign in."
2. Click on "Settings" in the top right-hand corner. Just click on the gear on the top right of the page and select "Settings" from the drop down menu. It'll be fourth from the bottom.
3. Click on "Accounts." This option will be fourth from the left on the top of the settings panel.
4. Scroll down to the "Send mail as" section and find the email address you want to edit by clicking on "edit info." This option will appear to the right of your email address.
5. Type your new name in the empty box below your old name and click "Save Changes." This will finalize your new email name. If you want to check your handiwork, send an email to a friend and see if it has been successfully changed.
Refer the article below to view these steps with images.
http://www.wikihow.com/Change-Your-Name-on-Gmail
SOURCE: Just created a new gmail account and am unable to
http://mail.google.com/support/bin/answer.py?hl=en&answer=46346
follow the yellow brick road and your be back up in no time. it will help you to access it again.
SOURCE: The connection to www.google.com was
Check out the internect connectivity on your computer this problem normally happens if there is a variance in the connection.
you can try some other browser apart from the one which you are using now and then check if the problem persists.
SOURCE: somebody has changed my password
If you have configured your gmail setting to any password recovering email (any other email) or to a mobile phone it will be easy to reset the password. If not then you better try to create a new gmail here.
Hope this helps, please rate if the solution was helpful, thanks!
SOURCE: i have 2 gmail accounts and only want 1
Probably the best and easiest solution is to set up email forwarding from your old account to your new account.
If not, you will need to basically download all your email from your old account and upload it to your new account. This will require some type of desktop email client and quite a bit of setup.
http://lifehacker.com/5521065/how-to-migrate-email-from-one-gmail-account-to-another
If you're not interested in moving your old email then you could just delete the old account.
Hope that helps!
SOURCE: 2 gmail accounts one is not working, plz help
ive had a phone that had a gmail on it and now i can get in it ple help
