Question about HP vs15 15"LCD Flat Panel Monitor
Is it safe or unsafe to try to repair on your own?
I want to be able to open up my HP vs15 to test the power cord.  I get no power to start it.  Anyone even know how to open?  I unscrewed all the screws
    Problem Solver:
  • 7 Answers
You have 6 screws 4 hold the base on and 2 on the backside of speakers. From their you can open it.
If you still have the monitor that is.
Posted on Jun 18, 2008
Do you mean the power cord in the wall or the cord to the computer itself? I...
The discoloration problem is due to the near by magnetic field appliances like speakers which are very near to monitors ...
so what you have to do is just keep some distance to the monitor from the speakers and other magnetic appliances and then press menu button & just give degauss..
on Jan 13, 2009 | Sony SDM-HS73P 17" LCD Monitor
No power when u plug in an turn on HP vs15 15 in. Flat Panel LCD Monitor.can u tell me how to open it up so i can check the switch
You need thin flat blade screw driver to crack open the case, it is almost the same as VS19, more likely to havebad caps with bulging tops, see pictures here:
Mar 10, 2010 | HP vs15 15"LCD Flat Panel Monitor
HP vs15 monitor Flickers then blacks out.
This monitor has 5 capacitors in the power supply that age prematurely. I can repair this for $50.00 +parts + shipping. Or you can take it to a local repairperson.
Jul 28, 2009 | HP Vs17 17" LCD Flat Panel Monitor
HP vs15 no problem
Please check first if your LCD monitor is still under Warranty period, if yes, then I recommend to bring the unit to authorized service center to properly diagnose & fix the problem, because if you open it yourself & probably broken its seal then the Warranty will be Void & other problem/s that may arise / found will no longer be covered by their free service / part replacement.
If no longer covered by a Warranty, then you can open it by yourself, by turning (counterclockwise) its lock screws to open its back cover & check the power button connections if loose/broken. regards
May 15, 2009 | HP Vs17 17" LCD Flat Panel Monitor
HP Pavillion Entertainment PC screen blank, power lights on
try this put off the laptop and remove the battery and the power cable and then hold the power button from 30-60 seconds then put back the power cable(without battery) and switch it on it should work then shutdown and put battery pack in
Apr 05, 2009 | HP Pavilion dv9000z Notebook
Is the power light on? If not, recicle the monitor. If it is on, then maybe the back lighting is the culprit.
I have a similar problem, and the repair is more expendive than buying a new one.
Sep 18, 2008 | HP vs15 15"LCD Flat Panel Monitor
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
Thanks and Regard
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
Power button stay on for 2 seconds, black screen,no picture
hi there, yes, you do have a broken monitor, bring it to qualified service personel how can repair the monitor. or you can just simply replace it. TY
Nov 29, 2007 | HP vs15 15"LCD Flat Panel Monitor
Hp vs15, black screen, power light goes on and off like it is in sleep mode
Monitor is dead. The LCD inverter board probably went out and needs replacing. More than likely, it will cost you over $100 to get it fixed. It's better to spend the money on a new monitor.
Jul 13, 2007 | HP vs15 15"LCD Flat Panel Monitor
HP vs15 15"LCD Flat Panel Monitor Logo
115 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
