Question about RCA F27442 27" TV
Middle prong is missing on tv, is this the ground prong? is this a fire hazard? will tv work without this prong
  • 36 Answers
It will work. But to be safe...simply make sure u connect it to a surge protector. You will be just fine.
Posted on Jun 03, 2009
Ac unit keeps resetting
Good Morning Friend,
I understand that your Frigidaire air conditioner keeps resetting itself. First, be sure the electrical service is adequate for the model you have chosen. This information can be found on the serial plate, which is located on the side of the cabinet and behind the grille. Secondly, be sure the air conditioner is properly grounded. To minimize shock and fire hazards, proper grounding is important. The power cord is equipped with a three-prong grounding plug for protection against shock hazards. Lastly, your air conditioner must be used in a properly grounded wall receptacle. If the wall receptacle you intend to use is not adequately grounded or protected by a time delay fuse or circuit breaker, have a qualified electrician install the proper receptacle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 20, 2014 | Frigidaire Heating & Cooling
Whirlpool (Old) dryer makes a zapping noise at the outlet. It will run, but there is no heat
Unplug the dryer, IMMEDIATELY.
Get a Pro to check for wiring shorts or heating elements that are, burned loose, touching or other wise going to ground...
What you are describing is a severe fire hazard if not corrected...
Feb 16, 2014 | Dryers
I am changing cord on my dryer from 4 prong to 3 prong. do i hook the ground wire with the middle wire?
connect the ground wire and the middle wire together. the red wire on one side and the black wire on the other side the ground wire and the middle wire in the middle
Mar 31, 2011 | Frigidaire GLER642A Electric Dryer
I have a very old mixer, a hamilton beach no.18. I have a basic understanding of how things work, but this has me beat. The cup holder switch is the on/off, and the top switch is to change speed correct?...
The green ground wire attaches directly to the frame of the mixer. If the green iwire is attached directly to the speed "prong" you will have a direct short. There should be a grounding screw just inside the place where the wire enters the frame. If it really old, you may not have a ground screw because in the old days the wires only had two prong plugs. You can operate the machine without a ground wire,but if it fails internally you could get a potentially fatal shock. Any screw that is attached directly to the frame can be used as a ground screw. The green wire is there to take any grounded short circuit back to the breaker box instead of sending the electricity into you.
Sep 21, 2010 | Microwave Ovens
I had a burnt out element in my Maytag oven and had to take back off oven and follow the wire that went into the element holes. I know how to fix the element and wires with that. I noticed that the...
dont worry about insulation missing i have worked on ovens for many years and often bits are missing from earlier repairs and the oven will work fine.
Aug 27, 2010 | Ovens
I have a new GE DCVH680EJ1MS Electric Dryer that I want to run 240V. I see it has Black/Red/White and Ground and this tells me that I "MUST" have the same in both cable to attach as well as female...
This is a prong conversion problem and all you have to do is convert from 4-prong to 3-prong. Your suggested configuration will not work, damage the dryer, and pose a fire hazard. The correct way to convert from 4 to 3-prong is by using three of the four wires; black, red, and white (neutral), and then connect the dryer frame to the neutral terminal. It is similar to making the neutral (white) and the ground terminals as one.
Mar 25, 2010 | Dryers
I need to convert a four prong into a three prong cord, I have the three prong cord allready, but it's not color coerdinated (sp) what do I do?
Hi, The 3 prong cord should be set up with the ground wire in the middle and the lead wires on the outside. It will hook up that way.
Just make sure you put the middle ground wire on the middle post of the block and the outside wires go on the putside post. It doesn't matter witch side.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 01, 2009 | Ovens
Need help with plug for kenmore elite he quiet pak dryer
if she went from a 4 prong cord to 3 prong cord the only difference is a extra green ground wire... black and red to the out side screws and the white in the middle... not sure what your calling a converter... unless the changeing of the cord.. 4 prong are mostly in trailers here in florida
Aug 25, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
RCA F27442 27" TV Logo
78 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
