Question about Zebra S4M Thermal Label Printer
Temp is set at 28. printing on mylar black mark.Speed is factory setting I believe at 2 print is blurry and not dark. Using resin ribbon
  • 3 Answers
Synthetic labels need resin ribbons. Wax/ Resin might work if it is a matte finish or has a varnish on it, but you should use full resin.
Brian Wallace
Peak Technologies
877-863-2491 x 6807
Posted on Jul 10, 2009
I haven't tried yet but after doing extensive reading feel that the problem is in the ribbon type. I thought it was a resin wax blend but it was one that I had for awhile without any label on it and I'm thinking it may be just a wax and that is why it works on white labels but not on the poly or mylar.
Posted on Jun 04, 2009
Poor print quality
Several checks:
- Just saying...Ribbon sometimes is placed in the wrong sense and it doesn't print.
- Verify the settings at printer driver. Download a powerful Driver from here: http://www.nicelabel.es/downloads/nicelabel-designer-pro/?uid=10004, and test the darkness option by printing with different measures at each time.
- If that doesn't work, we can check it again, but you should first test this options.
Jul 03, 2014 | Toshiba TEC B-SX4 Thermal Label Printer
HOW TO INCREASE DARKNESS IN HP 4300
1. If you are printing using postscript driver, try using PCL6 - printout would be darker for grey scaled items.
2. Print in lower resolution 600dpi or 300dpi, printouts would be darker.
3. Try printing all characters as black
You can adjust darkness at the printer using the console menu.
In the Configuration Menu ' Print Quality sub Menu , there is a parameter called Tonor Density. Factory Default is 3. Set to 4 or 5 to increase darkness..
Sep 27, 2013 | Office Equipment & Supplies
I have a brand new zebra tlp2844 I have set it up with a resin ribbon, the print quality is very poor and patchy why is this ?
There are a couple of possible solutions.
1/ Resin ribbons are meant to be used on synthetic labels onle ie vinyl or polyester. If you are trying to print on paper labels then you will get a rubbish print. you need to use either a wax ribbon or a wax resin ribbon.
2/ If you are printing onto a synthetic labels and the print is light, try increasing the "print darkness" some times called contrast or heat or printhead setting.. This can be fount in the printer set up in the labels software you are using or in the print drive under "Print Preference"
Dec 16, 2012 | Zebra TLP 2844-Z Thermal Label Printer
HI, our Zebra 4m+ is currently set to a Darkness of 30 as that seems to eb th eonly way it will print enough detail on the label. We have tried adjusting the pressure settings to no avail. Now we are...
Full resin ribbons tend to require higher darkness settins on all thermal printers.
It could be a mismatch between label and ribbon. This would need to be looked by your supplier.
May 25, 2011 | Zebra 105SL Thermal Label Printer
I'm printing a double sided card. The back side comes out fine (white with black letters). The front side needs to be completey black with red letters. It keeps coming out blurry. How do I fix that?
It may be that the ribbon is mispositioned. There are quite a few points in the trouble shooting section of the owners manual. These start on page 53. Here is the link to the page at the zebra company site that you can download the manual from.
http://www.zebra.com/id/zebra/na/en/index/products/printers/card/p120i.4.tabs.html
Hope this helps,
Best Regards,
Mark
Dec 29, 2010 | Zebra P120i Thermal Card Printer
My magicard alto prints fine except the color quality is not very great. when i use the color ribbon and print black letters with it the letters come out gray and not black and it has a problem making the...
The printer driver must be set to print text with the K resin panel.
If the text is part of a bitmap image and not a true-type font then it will print from the coloured panels and be dark grey.
To create the correct green on the card you need to change the RGB values so it prints correctly but look wrong on the badge design program. Even different printers print the same colour differently.
Jan 29, 2010 | Magicard Alto Card Printer
Ink smearing
This is a compatible ribbon/label combination as Zebra says. The only thing you can try is to turn up the darkness setting. The 5586 ribbon you are using requires a fairly high darkness setting ~ maybe around 25. If this still doesn't work then the best solution would be to use a Zebra card printer that prints right on the plastic card. These are made for exactly what you are trying to do. If you don't want to buy the printer then we can print them for you when you need them. I can give you my email if you want us to help.
Jun 23, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Unable to print a dark green logo?
Use Photoshop. Also their are Color Profiles you can install on you computer. n windows
Rt click an Goto properties/Settings/advanced.
THe last tab is where you can install them.
They will only allow you to match you screen to the printer color better.. Google where and what on you need.
In Card5 id I remember. There should be a setting that comes up when the print is initiated.
You should be able to set card of to control the color and not the printer. Or visa verso.
Also you can get a Solid Resin Green Ribbon.
Selvol
Jun 16, 2009 | Zebra Eltron P310 Thermal Printer
Not having good quality print with zebra z4 m
Try slowing down the print speed to 2 ips. Then increase the speed. Usually, this is a problem of exceeding the limits of the printer. The faster you print, the weaker the print. With a ribbon that is matched to the label stock, you will have an optimum speed for best performance.
May 22, 2009 | Zebra Z4M Printer
Problem printing on Glossy Label [butterfly label] using Zebra TLP 2844 EPL
You must make sure that the ribbon is compatible with the label you are attempting to print on. It must be a permanent resin. We use the AXR7+ material. Try to avoid using such a high printer head temperature as this will reduce the life of the head.
Dec 26, 2007 | Zebra TLP 2844-Z Thermal Label Printer
Zebra S4M Thermal Label Printer Logo
215 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
