Question about HTC G1 Smartphone
Pairing Jawbone 2 with BlackBerry 8700
My J2 was paired with a BlackBerry Pearl that I lost. I received a replacement BlackBerry 8700 and can't pair the J2. I heard that the J2 is stil married to the BlackBerry Pearl and that the J2 need to be reset but how do you reset it? Followed the instructions to reset and pair but it won't work. Frustrating!
    President:
  • 688 Answers
Just put your jawbone in pairing mode, usually by press and holding the on button for about 10 seconds. you should see the light flash blue and red alternately.The go to options on your BB and bluetooth then press the ball and add device you will have an option for allow another to find me, click it and when your jawbone pairs put in the default code which should be 0000 or 1234
you device will pair and your set
Posted on Jun 03, 2009
Have a jawbone bluetooth ear piece trying to pair it with a blackberry cant remember how to pair it
I have two jawbone headsets and they won't pair with our blackberry phones. Can you help me
May 20, 2010 | Cell Phones
Problem with Blackberry Pearl 8100
Did you try deleting all devices paired and then try pairing again?
May 20, 2008 | Motorola Mobility H700 Wireless Headset
When trying to connect my mobile via bluetooth to my car phone it says sim rejected why ?
We suggest you to reinsert the sim once again and check for the same. And try to perform the following steps: Apply the Bluetooth Pairing Helper application to your BlackBerry smartphone. Download the Bluetooth Pairing Helper application file using your BlackBerry smartphone browser Note: The Bluetooth Pairing Helper is available for BlackBerry smartphones running BlackBerry Device Software 4.2 and later. Complete the following steps for the Bluetooth Pairing Helper software. The following steps use the Land Rover as an example. Place the vehicle into pairing mode. For instructions, see the vehicle user manual. Start the Bluetooth Pairing Helper application. See links above. The following message appears on the BlackBerry smartphone: Please initiate the pairing process on your car. Click ?Done? when pairing is complete On the vehicle, press the Dial button. The following message appears on the Land Rover, and the progress bar on the Bluetooth Pairing Helper Application begins to advance: Searching The Land Rover display lists the name of the BlackBerry smartphone (and any other Bluetooth devices found within range). This may take one or two minutes. On the vehicle display, use the dial to highlight and then select the BlackBerry smartphone. The vehicle displays a random personal identification number (PIN) to pair. When the BlackBerry smartphone prompts for a PIN, type the PIN shown on the vehicle display in step 8 and press Enter. The BlackBerry smartphone displays Pairing complete. Connect to and press Yes. Pairing completes and an Connection to vehicle succeeded should appear on the BlackBerry smartphone. If the Bluetooth Pairing Helper application does not close, click Done to close the application. If you find the same error as sim rejected even after performing the steps, you need to check with the service provider relavent to the sim problem.
Oct 18, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Jawbone not connect with phone
Is the jawbone in pairing mode (this means either a solid light on the jawbone by pressing and holding the button. Or it could be a flashing light. Either way you need to be in pairing mode for your phone to discover it.once it is pairing mode the pairing code is "0000" put this in and the light should flash off on the bluetooth
Aug 26, 2009 | Motorola Cell Phones
Pairing Issues
Try the passkey as 1234 and then try to connect.
May 27, 2009 | RIM BlackBerry Pearl 8100
I purchased a aliph jawbone 2 from all4cellular.com for $69.95 and it won't pair up with my treo 755p. It's not my phone because I can pair up with my wifes Motorola headset. I even tried my coworkers...
Palm Treo 755p
To pair the Palm Treo 755p handset with the Jawbone, perform the steps listed below:
  1. Set the Jawbone to Pairing Mode.
    • For the Original Jawbone, press and hold down the Noise Shield button for at least three seconds until the LED Indicator Light flashes red.
    • For the New Jawbone, press and hold down both the NoiseAssassin™ Button and the Talk Button for at least three seconds until the LED Indicator Light flashes red and white alternately.
  2. Press Applications and select Bluetooth.
  3. Select Bluetooth On.
  4. Select Setup Devices.
  5. Select Trusted Devices.
  6. Select Add Device. (The Discovery icon appears, indicating that the discovery process is active.)
  7. Select the Show pick list and select Nearby devices.
  8. Select Jawbone from the Discovery Results list, and then select OK.
  9. Enter the PIN "0000" (be sure you are entering four zeroes and not the letter "O".) and select OK.
  10. Select Done, and then select Done again to return to the Bluetooth screen.
Your phone should now be paired with the Jawbone.
Feb 21, 2009 | Palm Treo 755p Smartphone
Problem Pairing Blackberry 8700 w/ BlueAnt Z9 Bluetooth Headset
This problem has been solved by turning on the blue ant system then holding down the vol - and vol + buttons simultaneously for 5 secs.
Dec 15, 2008 | RIM BlackBerry 8700c Cellular Phone
Pairing Issues
Thanks guys
U helped me bigtime.
Andrea313
Feb 05, 2008 | RIM BlackBerry Pearl 8100
Iphone and headset
Is this the first time you're pairing iPhone and jawbone or it's been working before?
If this is the first time,
1. Go to settings-general-bluetooth and turn on the bluetooth on your iPhone 2. Press and hold the button above the LED light until the LED light flashes Red and White 3. Go to your iPhone and click on Jawbone and it should connect.
If it's been working before:
1. Make sure Jawbone is fully charged. 2. Press and hold the button below the LED until white light blinks 3. Go to iPhone make sure bluetooth is on press Jawbone to connect
If this procedure fails try the to follow the First Time Pairing Instruction
Hope this works for you.
Nov 21, 2007 | Apple iPhone Smartphone
Pairing tom tom one with Blackberry 8700
I believe that the TomTom One and One XL do not have the Handsfree option. The bluetooth connection is soley for the TomTom Plus Services which are not compatiable with the Blackberry
Oct 10, 2007 | Tomtom ONE GPS Receiver
HTC G1 Smartphone Logo
1,250 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
