Question about Jenn-Air JDB1105AW Built-in Dishwasher
Foul Smell in Dishwasher
This dishwasher was installed in December 2008 in our new home. At first there was a very new "rubber" smell in the dishwasher and just thought because it was new it would go away. It's been 18 months and the smell is getting worse. We had two service calls before the 1 year warranty expired. One put in a refresher liquid which killed the smell for a while but it came back even worse.
What could it be?
  • Jenn-Air Master
  • 3,498 Answers
Try running bleach thru it... place a bowl in the bottom rack with bleach in it...start with a small amount... work up to what cures it.. The vent hose may have "crud" in it.. mine stopped up..D/W stopped draining..smelled..
Posted on Jul 16, 2017
aborcass
  • 2651 Answers
SOURCE: foul odor
first hting do you use a rinse agent( jet dry ?) perhaps s you're not selecting heated dry as an option.as far as the smell if its musty form water left behind,using jet dry will evaporate more of the water (a small amount on a paper towel and wipe down the inner door and walls will also decrease moisture, doenst to be done every time either on ly as needed might be once a year. if the smell is anything else id look into perhaps hoked to a garbage disposer?? smells permeate back into d/w.
Posted on Mar 10, 2008
  • 14 Answers
SOURCE: jennair dishwasher jdb8910aww
Start by puting timer in heat dry for about 4 seconds and see if element got warm. If so check you rinse aid and make sure it is full. I like the turbo dry made by jet dry. If it is empty, this is your problem. about the smell, you would use a cleaner such as diswasher magic made by GE. If element did not get warm, put unit on heat dry and and test voltage at the element. 120 volts present replace element. if not check voltage at thermal fuse for 120 volts. If no voltage there replace timer.
Posted on Jul 26, 2008
  • 258 Answers
SOURCE: door spring on dishwasher broke
I have just done this on my own dishwasher, and managed to bend the next curl of the springs to replace the broken ends, see instructions and pictures here:-
http://www.howtofixanything.co.uk/howto-260.html
Posted on Jan 15, 2009
  • 212 Answers
SOURCE: smell in a new dishwasher
run bleach through it. if your on well water then this will happen often
Posted on Jun 22, 2009
SOURCE: Our jenn-Air built in dishwasher smells foul and
We had similar type of problem (as well as residual water always left in bottom) and after pulling out the dishwasher, found that the drainage tube was incorrectly installed by contractor. It was laying on the floor behind it with a only a slight rise to the garbage disposal inlet. I suspect this contributed to sewer odors as well a water back flowing into the dishwasher. I disconnected drainage tube so that it went up 24+" and then connected to garbage disposal (creates a loop that blocks sewer odors and back flow conditions). I also cleared out the filter at bottom of inside the dishwasher. The Use & Care Guide suggested using baking soda in China/Crystal mode for 10 minutes, opening the front door and letting it sit overnight. I repeated that for 3 nights and it did clear up the remaining odor. Don't know if this will help your issue or not. Good luck!
Posted on Jan 10, 2010
Why does my tap pan dishwasher have a foul smell? What can I do to fix it.
First thing to do is check filter for blockages then get some dishwasher cleaner and let it go through a cycle. It is common for dishwasher and washing machines to start to smell if not cleaned through every two months or so
Jun 25, 2015 | Dishwashers
Why is there a foul smell in the dishwasher?
You might want to check the drain hose. It should be mounted up, or have a loop that is higher that the garbage-disposal port that it feeds into. If it is not mounted up, or have a high-loop, it is possible that water from the sink and debris from the garbage disposal can backwash into the dishwasher, and that would be the cause of the smell. Alternatively, it is possible that the heater is not working at all, so dishes aren't drying, and the water isn't getting hot enough to kill the bacteria, mold, and mildew that can form if the water isn't getting heated during the wash cycle.
Sep 14, 2014 | Dishwashers
The Vent on the front of my Kenmore Elite Dishwasher is giving off a very strong smelling odour when the dishwasher is going through the entire cycle. The inside of it is fine, no smell. It smells up my...
There is a product sold at home depot that is called AFFRESH made for cleaning smells of stagnant water and other smells as well. They make two different kinds of this product one is for a dishwasher and comes in a yellow bag the other is for front load washers but can also be used on top load washers as well in a green bag. Basicly you use a tablet and run the dishwasher on its hottest setting. Unfortunatley I am unable to smell the smell that your smelling if it were a burnt wire smell then I would ask that you turn off the electrical breaker to the dishwasher whereas I have seen on LG units a couple years ago a type of black goey insulation that LG used to use as a form of insulation on the wires in between the the two panels for the door. Unfortunatley this type of insulation ended up corroding the wires and eventually makeing them short against the door of the unit. Also at least once per year you should also clean out the chopper area in your dishwasher this is the part of the dishwasher that shreds up any large debris or food particles in a dishwasher. It would really depend on if it smells like a stagnant water smell, a old food type smell, or an electrical type of smell. I very much reccommend using the AFFRESH though as even the toughest smells of mold or stagnant water can be alleviated with this product. Using two tablets usually remedies the smell. If you have any further questions message me back and please remember after our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks
Rick
p.s if you need a schematic showing the location of your chopper message me back the model number to your machine and I will locate your schematic
Aug 11, 2011 | Kenmore Dishwashers
Ther's a foul smell coming from the dishwasher evert time I open it. Doing a wash does not solve this. I'v had this since it was new, months ago, and have had the installer look at it, said it wasn't his...
You need to run a cycle with a dishwasher cleaner inside, you can get these from the same place you get your dishwasher powder from, Before you run the cleaner through remove the filters from the bottom of the machine and place these in the rack, run through the hottest cycle with these filters in the racks and the dishwasher cleaner in place, this will clean the dishwasher properly and assist with correct draining and the odour, if the dishwasher is sitting for long periods unused leave the door open slightly to allow it to dry out.
May 13, 2017 | Frigidaire FGHD2433K 24 in Builtin...
There is a foul smell when we run the washer. There is also a lot of black residue inside the washer.
Here is a tip that will help you with how to clean that dishwasher up and get it smelling good again...
Dishwasher Maintenance
heatman101
Oct 14, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
My dishwasher has a foul/ garbage like smell during/after running. Dishes do come out clean but the smell is really bothersome and it sometimes doesn't fully drain.
goto your nearest home depot they sell a product called affresh you use it on dishwashers there is also another version for frontload washers use this on your washers hotest cycle this removes mostly all smells if the smells persist you might want to check around the chopper area to see if you have any food enlodged around the chopper
May 18, 2010 | Whirlpool 24 in. DU900PCD Built-in...
Why does my new dishwasher (in a new home)smell
You have to leave it open atleast 2 hours after the wash. Atleast the door left half open.
Or the smell must be flowing from your main drain pipe!!
Mar 30, 2010 | Thermador DWU244 Dishwasher
The dishes are wet when the cycle is finished and the dishwasher smells sour. This dishwasher was installed 4 days ago and this has been happeningt since installation.
Call the store that you bought it from and speak to the manager. Have him send a different person out to check this out. Your heated dry button is either not depressed or the heater is out but the foul smell is not acceptable. The best of luck to you!
Aug 14, 2009 | Dishwashers
Very bad smell coming from dishwasher
Possibly a water leak underneath or a dead mouse behind the unit.
Mar 17, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Jenn-Air JDB1105AW Built-in Dishwasher Logo
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
