Question about GE GSS25LGM Side by Side Refrigerator
GE PCG23NHM - Water dripping from dispenser
Hi We have a GE PCG23NHM side by side, water is constantly dripping from the water dispenser. As a temporary measure I have removed the filter to stop the water supply and switched the ice maker off.
Any ideas what the problem is and how to fix it much appreciated
  • 1073 Answers
SOURCE: Water and Ice Dispenser shorts Fridge
call ge there is a replacement program for the 05-06 sxs motherboard issue call 800-386-1215 to see if your machine is one of the machines in this program you will need the serial number of the ref before you call
Posted on Jun 13, 2008
SOURCE: GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Posted on Nov 17, 2008
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Posted on Dec 19, 2008
  • 19 Answers
SOURCE: water dispenser not working ice maker is fine
The refrigerator has a dual water valve. The water dispenser side of the valve may be defective, but, my experience has shown the problem to be in the water reservoir, located in the bottom of the fresh food section, which, might be frozen or the water line through the freezer door is frozen. Scenario #1: Remove the kick panel, disconnect the water line from the fitting. Have someone depress the water actuator, while, holding a cup to collect any water which may come through the line. If water comes through the tube. The problem is a frozen water line in the door. My best advice for this problem is to remove any frozen goods from the door. Take a piece of cardboard and seal the freezer section of the refrigerator with any kind of tape. Make sure you tape the door switch in the closed position, so, the refrigerator will continue it's normal operation. The frozen goods will remain frozen and the fresh food section will be okay. Leave the freezer door open. You might want to put a towel under the door. The water line will thaw. It might take 15 minutes. It might take 3 hours. Periodically check the water dispenser operation. When the water flows remove the cardboard. Scenario # 2:if, after disconnecting the water line and depressing the water actuator there is not water. The reservoir is frozen. Use a hair dryer to that the reservoir. You will have to remove at least a couple of crisper drawers to perform this action. The cause of a reservoir freeze is too little stuff in the drawers or too low a temp in the crisper drawer area.
Posted on Jun 18, 2009
SOURCE: Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Posted on Jul 30, 2009
Why is the water dispenser constantly dripping?
If the water is coming from the water dispenser itself then most likely you have a water valve that bis going bad and it will only get worse.
Jul 13, 2015 | GE Refrigerators
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Problem: Water continually drips from water dispenser spout
Should be the water valve in the back. Over time the seals break down our debre in water will cause to leak. Sometimes new water filters will also cause small issues but shouldn't last long.
Aug 18, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Water dispenser in the freezer door has a constant slow drip, how do I fix it?
You will need to replace the water valve. It is located in the back rear of refrigerator. If it is leaking by then you will see drip. Before you replace valve make sure the water pressure of water supply is proper. The valves will not seal properly without proper pressure.
Nov 24, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Have GE GSS25WGMC WW. Water dispenser dripping water at a constant pace. What could be the problem, is is something we can handle or should we get a repair person? What would be the cost expected?
There are only two reason that I know of. They are air bubles in the water line or the water control valve on the rear of your refrigerator is defective on the dispenser side allowing water to bypass the valve while shut. I will be right back with part numbers, Sea Breeze
Feb 18, 2010 | GE Refrigerators
I have a side by side GE refrigerator and the water dispenser is leaking quite a bit. It looks like is leaks where the water is dispensed.
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Oct 31, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE TPX24 BRBJ side-by-side drips water from door dispenser
water valve is behind ref.on either the right side or left but you will see your water line going to ref.water valve.Most likely replace.
Mar 06, 2009 | GE PDS22SIS Bottom Freezer Refrigerator
Water drip at doorfront water dispenser
Hi!!! Yes you can fix it by installing an antisyphon device on your water line leading to the water dispenser..remember i've done this for many years repairing frigs and they all do this they all leak water out alittle bit..Good luck..
Jan 03, 2009 | Refrigerators
Drips at water dispenser GE PSC23MGSA BB
If it's a constant drip then you need a new water valve.
Jan 03, 2009 | GE Profile Energy Star PSC25MGS Side by...
Water dripping on GE Fridge model TFX24ZR
check your water filter. water preasure is important in the operation of the water valves. if the filter is ok replace the valve. water filter should be changed at least once every year.
Sep 10, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser won't turn off
Stix: Check behind the dispenser handle the switch or button which is responsible to activate the mechanism of water dispensing. If the switch or button is covered with a reubber you must remove the rubber cap or whatever cover it has. If you have mineral oil or somekind of greasy stuff (vaseline or something similar) lubricate the switch or button. Open the freezer door and activate and deactivate the dispenser several times to lubricate the whole mechanism. SithPitt
Jul 04, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25LGM Side by Side Refrigerator Logo
85 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
