SOURCE: need to locate toyota aurion/camry iac valve
the MAF sensor is between the air filter and throttle body. the idle controll is at the throttle body.
Its located on the throttle body on the left side. Follow the air intake to an intake manifold which sits on top of the throttle body.
SOURCE: power steering belt on a 94 camry v6
only 2 bolts. They are hard to get to at the back of the engine but one is the mounting one and the other is the locking one for the adjuster once you get them lose you can undo the adjuster bolt and take tension off of belt then pull it off and replace it.
SOURCE: Toyota Camry idles then dies
It is NORMAL for the engine computer to have to "Relearn" how to idle the engine after a battery replacement. This should only be temporary and will go away after a few trips.
If it does not go away, or if the Check Engine light is coming on, it will require diagnosis to determine the cause. Nobody can tell you if the problem is related to your recent work until the cause of the problem is located.
Poor idling and stalling on deceleration can be caused by anything from a bad Idle Speed Control motor (ISC)
to low fuel pressure (Clogged fuel filter, bad fuel pump) to a bad connection in the A/C clutch sensing circuit. (Kicks the idle up when the A/C compressor is running)
