Question about Randell 47 cu. ft. / 1331 liter Commercial Freezer 47 cu. ft Glass Door Reach-in - All Stainless Steel
Delfield Mdl.6151 freezer
Can I turn this freezer into a cooler?
  • Randell Master
  • 1,150 Answers
If the thermostat will let you set that high of a temp, you probably could use it. Let me give you a few things to think about. At higher temps, the refrigerant pressures could cause the compressor to work harder which would shorten the life. The unit will also have shorter run cycles which could over work the compressor. Shorter run times will affect the humidity of the conditioned space. Bad thing if you have fruits and veggies in there. You will have to eliminate the defrost cycles. No need to have "Forced" defrost at cooler temps. I am not a big fan of using equipment for things other than what it was designed for. So, you can try it and keep an eye on how it performs. Good luck and hope this is of some help.
Posted on Jun 05, 2009
Where is the expansion valve located on a delfield 6151-s freezer?
Not sure on yours but most domestic refrigerator don't have TX v@lvs
Jun 23, 2015 | Delfield Freezers
Delfield Freezer Model # 6151.S Wiring Diagram
http://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/6000XL%20SERIES_spm.pdf. Start here.
Sep 07, 2012 | Delfield Freezers
Service manual for delfield 6151 g
http://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/6000XL%20SERIES_spm.pdf. Start with this one.
Jul 02, 2012 | Delfield 113.28 cu. ft. Commercial Freezer...
My freezer 6151 has build up ice on top of the unit. please help?
start by verifying that the defrost time clock works. Located in the top of the unit. Let me know if we need to go any farther.
Oct 07, 2010 | Delfield Freezer 6151XLSR Stainless steel
Delfield freezer 6151-S ,replaced door gaskets and they don`t seal
Take a hair dryer (or take off the gasket and throw them in the clothes dryer (yes I am for real I do this all day long)) then put them back on. or the hair dyer way is keep heating the gasket up and holding the door closed while you do it. they should start to seal as you are pressing them together.
Sep 23, 2009 | Delfield Freezer 6151XLSR Stainless steel
Looking for 6151-s manual please help!
This should cover your model-Good Luck
6151
Sep 03, 2009 | Delfield Freezers
Delfield freezer 6151-S keeps tripping GFCI
Try it in a normal plug. Freezers and refridgerators just pull too much to be used on a GFCI. The more a GFCI is used the eaiser it trips.
Aug 31, 2009 | Delfield Freezer 6151XLSR Stainless steel
Can I turn my Delfield freezer Mdl 6151-S into a cooler
It can be done but someone would have to do their homework. They have to know the BTU rating of the evap. Then match the compressor and expansion device to it for the intended temp range. In some cases, the compressor can be used in multiple temp ranges, so you could be lucky and just change the expansion device and possible the temp control, depending on which one you have. Let me know if I can be of any further help.
Jun 03, 2009 | Randell 47 cu. ft. / 1331 liter Commercial...
A Delfield Mdl 6151-S 2 door stainless freezer into a cooler? Change thermostat? It cost me $25 . Factory service says it's not practical. What is practical?
to do it right, you gotta get technical. Need to know the BTU rating of the evap coil. Then match the compressor/ condenser coil and the expansion device to the same BTU rating. Can prove to be somewhat expensive. Your unit probably has a 3/4 h.p. compressor. This is pretty big for a 2 door unit. Probably too big, but again, gotta get the technical on all that stuff.
Digital control settings
I have the dlefield maual if you talking about the digital defrost/temp adj
Aug 03, 2008 | Delfield Freezer 6151XLSR Stainless steel
Randell 47 cu. ft. / 1331 liter Commercial Freezer 47 cu. ft Glass Door Reach-in - All Stainless Steel Logo
205 people viewed this question
Top Randell Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Randell Freezer Expert? Answer questions, earn points and help others
