Question about SanDisk 4GB microSD High Capacity Memory Card
Windows XP won't recognize the Sandisk High Capacity Camera cards that I have inserted in my card reader.
  • 29 Answers
You will have to put it in a usb reader,is it for a phone or an R4 card?
Posted on Jun 03, 2009
New sandisk 8 gb sd card reports memory error when inserted in camera. other cards work in camera. card is recognized by laptop. tried reformatting by Vista
There are no 8GB SD cards. Cards this size are SDHC (High Capacity). SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC cards. SDHC is not backwards compatible.
Dec 01, 2010 | SanDisk Cameras
Windows 7 doesn't read my Dynex usb 2.0 card reader
1. You have to see if the program is compatible with the Windows 7 operating system.
this is possibly due to drivers that the Windows 7 doesn't have in the "cab" files.
this manufacturer of the Dynex is your next step for a Windows 7 driver set.
May 29, 2010 | Dynex External USB 2.0 Multiformat Memory...
Card Cant Be Read
Same thing happened to me, after taking some pictures of a christening, connected to card reader, it wasn't recognised by card reader. I re-inserted it in camera and got card error, tried some softwares to extract pics but for nothing!!! I'm very dissatasfied!!
May 25, 2010 | SanDisk Ultra II 8GB Secure Digital High...
I need to know how to use the Sandisk card reader. can u give me instructions?
You should be able to plug the device in. Most operating systems will recognize the device and treat it as new hard drive.
Are you getting a request for a driver? If so, first let Windows look for the driver.
May 22, 2010 | SanDisk Extreme USB 2.0 Memory Card Reader
2Gb Micro sd card not recognized by xp pc.
From Microsoft support:
Some Secure Digital (SD) cards do not work correctly on Windows XP-based computers. Additionally, you may notice a yellow exclamation mark (!) next to the SD card in Device Manager.
This problem may occur even though you have applied other hotfixes that are required for high-capacity SD card support. For more information, click the following article numbers to view the articles in the Microsoft Knowledge Base: 923293 The 923293 hotfix adds support for SD High Capacity memory cards in Windows XP 934428 Hotfix for Windows XP that adds support for SDHC cards that have a capacity of more than 4 GB
Apr 15, 2010 | Kingston 2GB Secure Digital Memory Card
After inserting the sandisk into my computer, I get an error message. It says I/O device error. What does this mean?
It usually means that your Input/Output device (e.g. Card Reader either internal or External) is not compatible with your Flash card which is a 'newer' high speed and high capacity medium (OR your Flash card is a new one and has not been formatted). You can check that your card reader is working by inserting a 'standard' (not ULTRA) working lower capacity card (1GB or smaller). Hope it helps: let me know hoe you go.
Apr 03, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
My computer which is running Windows XP pro 2002 does not recognize my San Disck cruzer 256 mb memory key. The light flashes upon inserting in to computer and then goes out and then I get message that CPU...
try to disconnect all usb devices and install it again to another port also try to install it on another PC if it workson another PC and yours not then try to remove ur O/S and install a good one like windows Xp SP2
Jun 15, 2009 | SanDisk 4GB microSD High Capacity Memory...
Micro sd card not working
I'm having the same problem with a Transcend 4GB microSDHC card / microSD adapter. I have also found it probably has something to do with the card reader...either the card reader is an SD card reader trying to read an SDHC card OR the card reader is not able to read high-gigabyte SD cards (over 1 GB in some cases).
Jan 23, 2009 | SanDisk 4GB microSD High Capacity Memory...
Problem import picts via sd cardreader (taken with eos 450d)
Some card readers struggle with high capacity (SD-HC) cards and indeed some older devices.
If you (or a friend) has a lower capacity card (less than 2GB) try that in you camera and then pc.
You can purchase a VERY cheap USB card reader (c.£10 max) and it should sort your problem - I hope!
Jan 05, 2009 | Canon EOS 450D Digital Camera
Pc not recognizing sandisk micro sd
The Card Reader you are using is probably not compatible with SDHC Memory Cards (High Capacity SD). You may need to get an SCHC compatible reader or check the website for your product to see if the is a driver update. You can get a new reader for about $20 bones if needed. I had the same issue.
Dec 30, 2008 | SanDisk 4GB microSD High Capacity Memory...
SanDisk 4GB microSD High Capacity Memory Card Logo
317 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
