Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson dc04 wont pick up,motor working,replaced clutch assembly but still dosnt turn brushes
    Filmmaker:
    Uploaded 5 video answers.
  • 101 Answers
You need to go through a process of elimination. You are better doing that here: Dyson advice forums
Posted on Nov 30, 2010
I have strong hose suction but none below and beater bar is not turning
Beater Bar Belt Likely Broken--Can Be Checked By Removing Cover(s) Next To Beater Bar (on bottom)
Feb 27, 2015 | Dyson DC33 Multi-Floor Upright Bagless...
How do i alter the dyson dc04 to use on hard floors
Hi there, it's Jack at Dyson.
If your DC04 has a brush control on the cleaner head, you'll need to set this to 'On' for carpets, and 'Off' for hard floors. You can find out how to do this on our Support site:
http://www.dyson.co.uk/support/dc04/dc04-brush-control/my-machine-is-not-working/i-can-see-something-wrong-visual/i-can-see-something-wrong-visual/my-brushbar-is-not-rotating2/does-the-brushbar-rotate-with-the-power-on
If your machine does not include the brush control, it will only be suitable for vacuuming carpeted surfaces and we'd advise against using it on hard floors in upright mode. However, you can use the hose and wand to vacuum hard floors and we have several suitable hard floor tools available which may help.
I hope this helps - if you'd like further advice you can reach our freephone Helpline on 0800 298 0298. Just to let you know, our Helpline is available from 7am-10pm, 7 days a week.
Best wishes,
JackDyson Online Customer Supporthttp://www.dyson.co.uk
Mar 06, 2013 | Dyson DC04 HEPA Bagless Upright Cyclonic...
I have a Dyson DC04 brush control and it sometimes jumps of the carpet on the back stroke when vacuuming. I have checked the belts and the brush and all seems well. Could this be wear and tear on the...
Sorry to hear you're having difficulties with your DC04. You might find it helpful to run through this step-by-step troubleshooting guide to make sure the soleplate is correctly fitted, and that there are no blockages in the cleaner:
http://www.dyson.co.uk/support/help.asp?article=89&product=DC04-SY-STD-BC
If you've tried this and are still concerned, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 - our Helpline is open from 7am until 10pm, 7 days a week.
Kind regards,
Jack
Dyson Customer Service
Aug 14, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Brush roller will not rotate on Dyson dc04 absolute
The brush will not rotate when the machine is upright. The brush only rotates when it is reclined; in use.
On the side of the housing where you place your foot to recline it is a round knob. Turn it one click clockwise if you can; to the "auto" position.
If the brush doesn't turn then when the machine is reclined, it needs attention to the belt and/or clutch mechanism.
Jan 13, 2011 | Dyson DC04 HEPA Bagless Upright Cyclonic...
Brush won't turn
Belt is broken. You will need to re[lace the clutch. Here is a video on how to do that.
http://www.videojug.com/film/how-to-replace-the-clutch-on-a-dyson-dc04-dc07-and-dc14
Oct 24, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a Dyson DC04 which is making a strong burning smell within a few seconds of switching on. Is this likely to be the motor and if so can it be replaced?
More likely it is the beater brush which is jammed and not turning. Turn the machine over and remove the bottom plate. Unhook the drive belt, then try to turn the beater brush--it is likely bound up with string, thread, and hair. Try turning the machine on once--if the motor spins and makes vacuum, it is probably ok. Remove the brush assembly and clean it of debris. Clean the end bearings with a Q tip and WD40 oil, then wipe clean with another Q tip. Oil the bearings with 3-1 or other light oil. Check the belt for a badly burned area--replace if necessary. Slide the new belt over the brush and motor shaft, then drop the brush with bearings into the case, and check rotation. If ok, replace the plate and test on your floor. Hope this helps!
May 16, 2010 | Dyson DC04 HEPA Bagless Upright Cyclonic...
The brushes wont turn,but it has good suction for the hose
you have to remove the bottom cover to inspect the belt. Usually if the brush is jammed, you will smell an odor similar to burning rubber. In the absence of that smell, its likely the belt. Its easy to replace
Sep 20, 2009 | Dyson DC14 All floors Bagless Upright...
The brushes move freely by hand but wont spin
It could be the clutch that causing your problems. What you should do is take it to a repair shop and have it looked at and see if that's the problem.
Aug 23, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Not picking up and the brush does not move
Check to make sure that the knob for carpet/ bare floor has not slipped, the brushroll will only turn when carpet is selected. The most likely culprit is a stretched belt on your clutch assembly; you have one tor the brushroll and one to the motor. These belts will stretch out though Dyson will not tell you this. Best remedy is to replace the clutch assembly with OEM # 900252-04. Dyson will sell the Brusholl belt but I suggest shopping arround to find someone willing to pull the clutch apart; to my knowlege Dyson will NOT sell the motor belt.
Jan 17, 2009 | Dyson Vacuums
I changing the belt
Not sure why you claim clutch belts cant be changed because they can.
The DC04 DC07 DC14 all use the same clutch unit if you cant get the belts from your local vac repair shop look on Ebay they are on there.
The special tools are torx screwdrivers & if replacing both belts you will require circlip pliers.
How to replace both belts in manual form can be found here http://dysonmanuals.llc.nu/index.htm
Sep 27, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
142 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
