Question about LG KP500 Cookie black on T-Mobile U-Fix £25 Text , with 30 mins & 500 txts a month Cell Phone
I cant get any signal is says no network i have shut ít off then open its dont work
Try taking the back of your phone and taking the sim out and cleaning it and putting it back in and check you've got the sim in the right way.
Posted on Jun 05, 2009
My galaxy s dont have signal..what can i do?
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Aug 03, 2012 | Samsung Galaxy S I9000 (8 GB) Cell Phone
There is no signal the, the phone is just saying sos! everything else is working fine jus that the phone lost signal and cant regain it!
Possible that the network IC is defective, possible damage in the signal output/ antennae out.
Open set and check for moisture, clean and look in the area of the antennae. If still there is no signal detection seach for network manually . if not the phone is faulty.
Sep 14, 2010 | Cell Phones
Internet connecting problem
First remove the antivirus suites and firewalls. Open IE Go to Tools -> Internet Options -> Connections -> Lan Setup Check whether "USe proxy server..." check box is checked. If so untick it. Apply and Ok. Then check. If you are bot sure whether you have a proxy or not you can chose "Automatically detect settings". That will override manual configs how ever. Alternatively you can check Connection settings of Firefox since it is working.
Check the device manager for the adapter status. Right click on My computer and go to manage. If it has yellow exclamation marks or red X as you said that means a device failure or driver failure. If so you have to rollback the drivers and if it doesn't work uninstall and re install drivers. Use Add Remove programs if a software is there. If you use a software to configure / access the network appliance (if you have one like a wireless router) un install and re install it.
Check this thread as well.
This 6to4 adapter is a IPv6-to-IPv4 conversion layer. If you are not using IPv6 communications across IPv4 routers, you do not need 6to4 enabled. You can disable it. What is the IP address you are using? Is it ip v 4 or 6? Check using ipconfig using a command window (cmd.exe in run box and hit enter). Not necessary to use IPv6 (only if your college or etc etc use IPv6. Check this thread as well. isatap will not work on Vista but it doesn't do any harm though. :D
Please rate the answer and a testimonial (comment) if the solution helped you to solve the problem.If the problem persists please contact us. Thanks for contacting Fixya
May 28, 2010 | Acer Computers & Internet
No signal ,
Please contact who ever you pay to use this phone. It may not work in PI
Jan 20, 2010 | LG TracFone 600 Cell Phone - TF600GP4
I cant get the speed and signal strenght of the wireless network to work
CAN'T GET OR DON'T KNOW?
IF YOU DONT KNOW TRY TO OPEN (MY NETWORK PLACES) THEN CLICK ( Network Connections ) GO TO THE WIRELESS CONNECTION ICON RIGHT CLICK ---> STATUS YOU CAN FIND THE SPEED AND SIGNAL STRENGTH THERE ....
IF YOU DID THESE AND DIDNT WORK TRY TO RE-INSTALL THE EXACT WIRELESS CARD DRIVER ....
Dec 17, 2009 | Maxdata M-Book 1000T Notebook
Cant get a signal just says no network
i have this problem too, it only happened today, it just keeps saying no network everywhere i go, and i've tried turning it off and on and putting different simcards in it and it still dont work. i even restored factory settings and it still says no network!
May 18, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
XBOX 360 Wireless Adapter Question
When i try to play halo3 with my friends i get the same problem. I cant connect to them and sometimes i also cant hear some people talk. Some problems might be that your NAT is set to STRICT or MODERATE you will want it to be open to play with your friends. I dont really have an answer but you will need to get in your apartments router to change the settings to get the NAT to become open. If you type in on the google search bar: Cant connect to friends on xbox live there will be some answers for this problem.
Jan 14, 2009 | Microsoft Wireless Network Adapter Xbox...
Dont know why my sim card wont work?
hi sir..
please check whether the network signal is is there in ur area.. if signal is there. check once once removing the battery once and another trick is put that sim in too ur some friend's pnone and try it..
may be solution will be solved.. thanks sir.
Sep 02, 2008 | Samsung SGH-U600
Wireless problems
HI,
do you usually connect to other wireless network with your laptop?if you don't I suggest trying to unistall the wifi network adapter ( control panel-> system-> device manager) and reinstall it.
Riccardo
Aug 03, 2008 | D-Link DI 514 Wireless Router (DI-514)
Hooking up a tv
Hi first of all are you using scart leads to plug into each device here is how it should be set up ok
1. Scart lead from dish network into vcr
2. then other scart from vcr into tv
3. Now ti recieve the signal from the dish network you need to have the telly on the right av channel so that its picking up the signal from the vcr.
you can test this by changing the channel on the vcr controll or direct via buttons on vcr.
If the channels change then your on the right av channel.
Now when your on right channel on telly you need to now make sure dish network is on and on a channel or press the tv guide button just so you know what your looking for when the picture comes through.
You need to press av on the vcr controll this will then pick up the signal from the dish network via the scart lead as av is the channel for scart lead.
say if you was recording from dish net to vcr you would put the vcr on av to pick up the signal so press av on vcr controll this should then allow you to watch the dish network with no problems.
Let me know if you still cant and ill assist you further if it dont work tell me what you have done so i know how much you have done ok
Feb 10, 2008 | Toshiba TheaterWide 46HM94 46" Rear...
LG KP500 Cookie black on T-Mobile U-Fix £25 Text , with 30 mins & 500 txts a month Cell Phone Logo
174 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
