Question about Sharper Image Blue Hat Toy Company Kids Digital Camera
Need a drawing of the wires inside the Blue Hat Toy Co MP3 player
One black and one red wire have detached and I don't know where to re-attach the wires
  • touchton Jun 04, 2009
    there are more than one red and black wire
  • 67 Answers
Try the red on top and black on bottom if that don't work switch them around
Posted on Jun 03, 2009
Wire a cord that has 4 wires red 2nd ask and 1 blue to 2 wires red and black
240 volts....if you don\'t know what you are doing.don\'t mess with it.
Jul 28, 2014 | Dryers
I have an ACE brand dual control fan and light that I need help wiring. From the ceiling fan to the switch, I have a red, white, and black wire. The dual control has a black, yellow and red wire. I have...
The white to your fan will connect to the white in the switch box, The switch itself should have a wire labeled com or common. This is where the Hot in your switch box will attach. The other two wires will be your switch legs to theto the fan. (Red and Black)
http://www.broan.com/common/productDigitalAssethandler.ashx?id=e07a9916-6b3e-4456-b00e-2edfad475df2
May 04, 2017 | Broan-NuTone Broan 68W Dual Rocker Switch
I am trying to wire a 7 pin trailer arness to my dodge ram 2500,the harness has a dark green,yellow,green,green/white,brown, red and 2 black wires. the truck doesn't have the 2 black wires and the red...
Go to napa and they have the connectors that plug in to your existing wire connection, I don't know if they have the one for yours, but it won't hurt to check, you don't have to cut or splice the wireing with there trailer connectors, plug it in and done.
May 21, 2011 | Dodge Ram 2500 Cars & Trucks
Where do i connect wires on new Intek briggs & stratton motor going into cox compact tractor Model09M7. Red, white, grey & black wires from motor.
i have similar problem robjanottle. the red connects to the power cable in the equipment harness and the white connects to the light switch.this is from B & S website where u can get wiring diagram for dual circuit alternator. ******** if i know where the grey and black wires go. the grey is attached to underside of fuel bowl but don't know where it ends up and maybe black is earth? i am going to local mower dealers to have a pretend look to buy mower but will only be interested to find where this friggin' grey wire goes to. good luck mate
Apr 24, 2011 | GPS
On the top of the dryer there is block where the power cord attaches and there are 6 spaded treminals wit the following wires attached from left to right they are black wire, 2 blank, whiye double wire,...
the green wire is the ground wire,there should be a screw or connector for it near the block,it just connects to the frame so the unit is grounded,you should see on the cord a white,black,red and a green ground wire,on the block you should see the white wire connected,the black on another screw and the last one is for the red,if the white is in the middle the black should be on one side and the red on the other,they are color soated,if you say there are red small wires the large red should connect with them just like the black does,as long as you keep the white wires together,the black wires together and the red wires together you'll be fine and ground the green wire to the frame
Feb 22, 2011 | Dryers
I am wiring my new Fahrenheat hydronic baseboard heater. I notice that inside the left endcap (and also inside the right endcap) there are TWO pairs of wires already attached together, a red with a...
Hello,For 220volt Choose which side you will connect to.Take the nut off that side black=black / white=red leave the other side alone.The manual is useless.
Oct 17, 2010 | Fahrenheat Electric Hydronic Baseboard...
I have an E38 7 series I need to know the wiring connections to the 2 wiper relays, I have 3 small wires and the power feed wire that have corroded and become detached from the relay holders. What...
Got this from Mitchell
On left Relay Red/Brown 8
Brn Blue 4
Brown 5
Red/White 2
Red/Blue 6
On Right Relay
Red/Brown 8
Brown/Black 4
Black/Brown 5
Black/Brn 2
Red/Blu 6
Nov 04, 2009 | BMW 750 Cars & Trucks
I don't know how to attach my speakers to the red
If you have bare ended wires , you simply unscrew the red and black plugs at the amp they should have a hole in the end of the plug and on the side also just place the red wire into the side hole of the red plug and finger tighten the red screw the same on the black plug
Jun 06, 2009 | Polk Audio RTi100 Main / Stereo Speaker
Whirlpool Electric Cooktop Wiring
sound like you have a three wire setup on you house most commonly the black wire is the L1 wire or one of the hot wires and the red is the L2 wire and is also one of the hot wire in this instance your white wire would be your neutral/ground wire this would connect to the copper wire on your cook top depending on the model it would have a red wire a black wire and the copper wire but some may also have a white wire also if this is the case on a three wire setup you would attach the copper and white wires together also if needed you can goto the maufactures website and download an instalation guide.
Mar 25, 2009 | Whirlpool GJC3034 Electric Cooktop
Rewiring Creda W120vw door
THEY ARE BOTH LIVE WIRES THE RED/GREEN ONE GOES NEAREST TO THE DOOR SEAL, AND AS I SAID THEY ARE BOTH LIVE SO PUTTING EITHER WAY WOULD NOT CAUSE A PROBLEM APART FROM ONE WAY THE MACHINE WOULD NOT WORK. I ASSUME THE BLACK WIRE IS ON THE MIDDLE CONNECTION, THIS IS NEUTRAL
Jul 15, 2008 | Creda W120VW Front Load Washer
Sharper Image Blue Hat Toy Company Kids Digital Camera Logo
351 people viewed this question
Top Sharper Image Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Sharper Image Toy Expert? Answer questions, earn points and help others
