Question about HP LaserJet 3055 All-In-One Printer
I load a document into the slot like im about to fax it, it says document loaded. I hit the number then fax, it says storing page1 but wont feed it through. then the "document feeder mispick" comes up
    President:
  • 3,085 Answers
Pull up on the document feeder to access the rollers. Clean with alcohol or water.
Posted on Jun 04, 2009
Paper feed does not work
What model are you referring to? In general. When you load a document you get a beep and the screen will change waiting for you to enter the fax number. If this does not happen then the document detect sensor is not being activated so the machine does not know there is a doc on it. Open the document cover and look for a long black arm hanging down or standing up. Make sure it moves. There will be two other sensors also with black arms . make sure they are also free to move. If they are sticking then investigate as to why. use NO lubricants. just clean.
Jan 29, 2014 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
I cannot copy and print a document on 8"X14" plain paper. No problem with 8"X11 1/2" plain paper
Scanner: dot2.gif optical resolution: 2400 x 4800 dpi /19,200 x 19,200 dpi interpolated dot2.gif 48 bit color depth
maximum document size: 8 1/2 in x 11/11/16 in dot2.gif Copier: dot2.gif copy speed for text documents: up to 30 copies per minute in black; up to 20 copies per minute color dot2.gif reduction/enlargement: 25/400 percent dot2.gif Fax: dot2.gif color or black and white faxing dot2.gif stores up to 40 numbers in speed dial dot2.gif built in memory for up to 100 incoming fax pages General Features: dot2.gif automatic document feeder holds up to 30 originals for copying, scanning, or faxing multiple documents dot2.gif Ethernet port for connecting multiple users in a computer network dot2.gif 2 picoliter sized ink droplets for fine detail 4 individually replaceable ink tanks dot2.gif ChromaLife 100 inks for long lasting photos dot2.gif Full photolithography Inkjet Nozzle Engineering /FINE 1,600 nozzle print head dot2.gif paper sizes: letter /8 1/2 in x 11 in, legal, credit card /2/ 1/8 in x 3 3/8 in, 4 x 6, 5 x 7 in, envelope, photo stickers dot2.gif high speed USB interface dot2.gif 18 15/16 in W x 9/ 7/16 in H x 18/ 1/4 inD dot2.gif weight: 22.3 lbs. dot2.gif Part Number: 2186B002
you have to select the paper size from the computer while giving printout from computer and apply the changes you make.and while copying the page from the scanner you have to change the printersettings by clicking the menu button in the printer.
Oct 04, 2008 | Office Equipment & Supplies
HOW TO SEND A FAX
You can send a fax in a variety of ways. Using the control panel, you can send a black and white or color fax. You can also send a fax manually from an attached phone. This allows you to speak with the recipient before sending the fax.
To send a basic fax (single- or multiple-page black-and-white fax) by using the control panel.These features allow you to control the pace of your dialing. They are also useful when you want to use a calling card to charge the call and you have to respond to tone prompts while dialing. NOTE: If you need printed confirmation that your faxes were successfully sent, enable fax confirmation before sending any faxes. TIP: You can also send a fax manually from a phone or by using monitor dialing.
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed dial button to select a speed dial, or press Redial/Pause to redial the last number dialed.TIP: To add a pause in the fax number you are entering, press Redial/Pause, or press the Symbols (*) button repeatedly, until a dash (-) appears on the display. 3. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, it sends the document to the number you entered. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure your original is loaded print-side down on the glass, and then select Yes.TIP: If the recipient reports issues with the quality of the fax you sent, you can try changing the resolution or contrast of your fax.
Send a fax manually from a phone You can send a fax from a telephone on the same phone line if you prefer to use the keypad on your phone, instead of the keypad on the control panel of the device. You can do this by plugging in a phone into the 2-EXT port on the back of the device. When you send a fax manually, you can hear the dial tones, telephone prompts, or other sounds through the handset on your telephone. This makes it easy for you to use a calling card to send your fax. Depending on how the recipient has their fax machine set up, the recipient might answer the phone, or the fax machine might take the call. If a person answers the phone, you can speak with the recipient before sending the fax. If a fax machine answers the call, you can send the fax directly to the fax machine when you hear the fax tones from the receiving fax machine.
1. Load your originals. NOTE: This feature is not supported if you load your originals on the glass. You must load your originals in the document feeder tray. 2. Dial the number by using the keypad on the phone that is connected to the device. NOTE: Do not use the keypad on the control panel of the device when manually sending a fax. You must use the keypad on your phone to dial the recipient's number. 3. If the recipient answers the telephone, you can engage in a conversation before sending your fax. NOTE: If a fax machine answers the call, you will hear fax tones from the receiving fax machine. Proceed to the next step to transmit the fax. 4. When you are ready to send the fax, press START FAX Black or START FAX Color. NOTE: If prompted, select Send Fax, and then press START FAX Black or START FAX Color again. If you were speaking with the recipient before sending the fax, inform the recipient that they should press Start on their fax machine after they hear fax tones.
The telephone line is silent while the fax is transmitting. At this point, you can hang up the telephone. If you want to continue speaking with the recipient, remain on the line until the fax transmission is complete.
Send a fax using monitor dialing Monitor dialing allows you to dial a number from the control panel as you would dial a regular telephone. When you send a fax using monitor dialing, you can hear the dial tones, telephone prompts, or other sounds through the speakers on the device. This enables you to respond to prompts while dialing, as well as control the pace of your dialing. TIP: If you do not enter your calling card PIN fast enough, the device might start sending fax tones too soon and cause your PIN not to be recognized by the calling card service. If this is the case, you can create a speed dial entry to store the PIN for your calling card. NOTE: Make sure the volume is turned on, or you will not hear a dial tone. To send a fax using monitor dialing from the control panel
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals print-side up in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, you will hear a dial tone. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure that your original is loaded on the glass, and then select Yes. 3. When you hear the dial tone, enter the number by using the keypad on the control panel. 4. Follow any prompts that might occur. TIP: If you are using a calling card to send a fax and you have your calling card PIN stored as a speed dial, when prompted to enter your PIN, press Speed Dial or a one-touch speed dial button to select the speed dial entry where you have your PIN stored. Your fax is sent when the receiving fax machine answers.
Apr 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
When trying to send a fax a brother 1360 and after dialing the number rings but the document will not scan and displays 'telephone'.
The reason why your mahcine shows telephone because it can't recognize the document that you loaded in.
Try to remove the document from the feeder and make sure that your mach shows date & time. Load the document again in the feeder and the display should show enter fax # & start, that's the time you need to dial the fax # and hit the start key,
Hope this helps,
Mar 28, 2011 | Brother Fax-1360
I don't know where to insert the pages to be faxed
Load the paper into the document feeder on top of the machine.
Jul 06, 2009 | HP LaserJet M1522nf Multifunction Printer...
Paper feed
Is your paper right in slot with grey flap over top of paper feeding into slot.
Apr 08, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
Why is my printer saying original loaded?
Is there a piece of paper in the top (copier/fax) feed, or under the top against the glass? Original Loaded means there's some document in place, ready to be copied or faxed. If you remove that, the message should go away. If there isn't one, check inside the feed on top, and see if there's anything stuck in there that could be blocking the sensor.
Aug 28, 2007 | HP OfficeJet 7110 All-In-One Thermal...
Speed dial list
***Storing a Number for Speed Dialing*** 1 Press Phone Book on the control panel. 2 Press Phone Book or the scroll button (􀂥 or 􀂊) to display ?Store&Edit? on the bottom line of the display. Press Enter. 3 Press Enter when ?Speed Dials? appears on the display. The display prompts you to enter a location number, showing the first available number. 4 Enter a one or two-digit speed dial number between 0 and 79, using the number keypad or scroll button (􀂥 or 􀂊), and press Enter. If a number is already stored in the location you chose, the display shows the number to allow you to change it. To start over with another speed-dial number, press Upper Level. 5 Enter the number you want to store using the number keypad and press Enter. To insert a pause between numbers, press Redial/Pause. A ?-? appears on the display. 6 To assign a name to the number, enter the name you want. For details about entering characters, see page 1.14. If you do not want to assign a name, skip this step. 7 Press Enter when the name appears correctly or without entering a name. 8 To store more fax numbers, repeat steps 4 through 7. To return to Standby mode, press Stop/Clear. ***Sending a Fax using a Speed Number**** 1 Feed the document(s) face up into the ADF. For details about loading a document, see page 2.2. 2 Adjust the document resolution to suit your fax needs. See page 2.3. If you need to change the darkness, see page 1.20. 3 Enter the speed dial number. ? For a one-digit speed dial number, press and hold the appropriate digit button. ? For a two-digit speed dial number, press the first digit button and hold the last digit button. The corresponding entry?s name briefly displays. 4 The document scans into the memory. The fax number stored in the speed dial location is automatically dialed. The document is sent when the remote fax machine answers
Aug 17, 2007 | Samsung SF-560 Plain Paper Laser Fax
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
HP LaserJet 3055 All-In-One Printer Logo
320 people viewed this question
Seeker5211
Seeker5211
