Question about Whirlpool MH7140XF Microwave Oven
I HAVE A KENWOOD MICROWAVE GT/AL17,THE TURNTABLE HAS STOPED TURNING, ANY ADVICE MANY THANKS. TONY Nr IRRLAND
    President:
  • 2,992 Answers
Two possibilities: either the turntable coupling is broken or the turntable motor has quit. The plastic coupling can wear or crack so it no longer fits properly on the turntable motor shaft. Then even though the motor still turns, the turntable doesn't. Or the motor itself may have stopped working. If the plastic coupling still looks normal and you can't rotate it easily by hand while it's in place, it's probably the motor.
I'm here in the US so I can't suggest where to find parts, but you should be able to locate a supplier who might have replacements available. Of course the oven will still work without the turntable running. You'll have to open the oven occasionally and turn the food yourself to insure even cooking.
Posted on Jun 03, 2009
I need a replacement turntable for my brevile combination microwave model brcm2516 where can I get one
First4Spares Glass Turntable Plate For Breville Microwave Ovens ...
https://www.amazon.com/First4Spares-Glass-Turntable-Breville-Microwave/.../B007B...
Shop First4spares at the Amazon Small Appliance Parts & Accessories store. Free Shipping on eligible ... BREVILLE MICROWAVE TURNTABLE Glass Plate 245mm 9.5". $29.99. Next ... Container for Microwave Oven · Add to Cart · Add to ...
Amazon.com: BREVILLE MICROWAVE TURNTABLE Glass Plate ...
https://www.amazon.com/BREVILLE-MICROWAVE-TURNTABLE-Glass.../B00COP... Quality replacement glass turntable for your Breville microwave. ... Small Appliance Parts & Accessories > Microwave Oven Parts & Accessories > Turntables
Breville Shop ' Partmaster
www.partmaster.co.uk/breville/microwave/catalogue.pl?shop=breville&path... Find your Breville products and repair your appliance yourself for less. ... Connects the microwave motor to the glass turntable Suitable for select microwave ...
Breville Canada
https://breville.ca/ Breville designs and engineers small kitchen countertop appliances to deliver commercial quality performance that look great and are easy to use.
Breville Microwave Parts & Accessories ' eBay
https://www.ebay.co.uk > ... > Breville Microwave Parts & Accessories BREVILLE Microwave Glass Turntable Plate Roller Ring Support Stand 3 Wheel ... Turntable Turn Table
Plate MOTOR for BREVILLE Microwave Oven ...
Breville Parts -Google Search
Jul 03, 2017 | Microwave Ovens
Turntable not working
please follow this step and fix it. God bless you
f the carousel inside your microwave won't turn when you run it, the small motor that operates it may be broken.
Nov 22, 2013 | Kenwood KENCJ99SSA Microwave Oven
Turntable not turning - no microwave cooking
Could be a reset or fuse within may just have popped Beware of excessive internal Voltages when servicing...
Apr 20, 2010 | Neff B7740N0GB Microwave Oven
My kenwood microwave KEN GT/AL17 wont cook anything. The light comes on and it turns but theres no heat?
This is most likely the high voltage fuse between the transformer and the magnetron. An easy and cheap fix.
Oct 22, 2009 | Microwave Ovens
Turntable sometimes works, mostly doesn't
It sounds like you have a jamming turntable motor.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 28, 2009 | Microwave Ovens
Turntable does not turn.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
The best place to order Sharp parts is Tritronics. Or you can call them toll-free at 866-779-5835.
Dec 23, 2008 | Sharp R-530ES Microwave Oven
I have recently bought a Kenwood Microwave model KEN GJ/SS25. I notice that the turntable does not revolve. Should it? Regards John Hamon jhamon@hotmail.co.uk
For parts and service, you should contact Kenwood at the number in the owner's manual.
Nov 24, 2008 | Microwave Ovens
Over the range microwave turntable has stopped turning
You give very little information Toni, but it seems the turntable motor is defective. If you are comfortable with this you must remove the cabinet (probably six screws in the back) and locate the motor at the bottom of the unit. Check all connections and connect the motor to a 120 volt source. If it is defective, order a new one on-line from the manufacturer. Your other option is to replace the oven. This would be my suggestion unless it is still in warranty.
Ray
Nov 20, 2008 | Maytag MMV1153A Microwave Oven
My KEN GT/AL17 is displaying a "g" icon under the time display and will not function. Any ideas?
As requested, the Microwave was unplugged overnight but the hard reset did not work. The lower-case 'g' is still showing
Sep 25, 2008 | Microwave Ovens
Turntable, lights and fan inop
I'm guessing that nothing is working...is that right? If so, first guess is the breaker or an internal fuse. Nearly all units have them. You don't say what fuse you checked. Unplug the unit, remove the bulb and see what is in the socket. Next, open the breaker and then turn it back on. This will reset it. Something caused this.
Dec 19, 2007 | Magic Chef CMV1000B Microwave Oven
Whirlpool MH7140XF Microwave Oven Logo
1,193 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
