Question about Canon PIXMA iP90 Mobile Printer
My canon iP90 portable printer stopped recognizing the installation of the color ink tank. It keeps asking to install the color ink cartridge and won't print until the color ink cartridge is recognized
According to Canon, the if several actions did not correct the issue, it was a hardware problem. They sent me the location of the closest repair shop. I spoke to them and to do the repair is $80 + parts which my research estimated at between $50-$80, for a total cost of $130-$160 plus 10% cook county Illinois sales tax. I have ordered a new updated printer for a total of $215 plus no tax or shipping charge. I'll be taking the old printer to a location for recycling. I can't believe how disposable this equipment has become. What a waste of raw materials and energy.
Posted on Jun 04, 2009
Showing Check Ink U051 COL. Have removed the
Hi there
For troubleshooting purposes,
Perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank
properly. If it does, it will indicate it does not detect the other ink tanks, as
they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are
installed, the cause will be the last tank installed. For example, if
you inserted an ink tank earlier, and you later inserted another ink
tank, and it said two of the same inks were installed, the cause of
the issue is the last ink tank.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | Canon PIXMA MX310 All-In-One Printer
THE INSTALL COLOR INK NOTICE KEEPS STAYING ON. EVEN AFTER I KEEP INSTALLING DIFFERENT CARTRIDGES
Go into printer maintenance and chose the Canon printer (assuming you have multiple printers). Once you chose the printer you can then perform maintenance and do cleaning and priming. Essentially when you click install new cartridge the system will essentially prime the printer so that when you print a document it will not have to prime itself. It should prime automatically once you close the lid and install the new cartridge.
Feb 08, 2010 | Canon PIXMA iP90 Mobile Printer
I have purchased a ''Virtually Mint'' Canon Pixma ip90 printer however, when I try to print a document a message pops up stating ''the following ink tank is not installed: black ink tank, colour ink tank....
Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Jan 21, 2010 | Canon PIXMA iP90 Mobile Printer
Same prob
Try and remove the ink cartridge and then reinstall it.
Aug 30, 2009 | Canon PIXMA iP90 Mobile Printer
My IP90 stopped recognizing the instalation of the color ink tanh
Take to a ink refill store and ask the to test on there machine(cartridge world etc) it will tell if cartridge is good or not! hope this helps!!!
Jun 21, 2009 | Canon PIXMA iP90 Mobile Printer
Message saying color ink cartridge not installed
This is a common problem with the Canon IP90 printer. The printer keeps saying color cartridge not installed. The problem is caused by the small micro switch under the color tank. This problem is not common with new IP90 printers because ink has not had enough time to build up under the micro switch which will insulate the contacts. To cure this problem is very simple, unless you have screwed around the print head and busted the little micro switch clip off.then you really have a problem........
So if everything is still there and you haven't messed around to much.here is what the fix is.
First get a can of CRC Electronic cleaner for sensitive electronic equipment ,the quick drying formula.CRC#05102. This cleaner is safe and harmless to plastics. Do not use electricial contact cleaner it will disolve plastic.
First center the cartridge carrier,shut off power . Carrier should stay to center. Remove black and color tanks. In front of the carrier is a small print head button , push it in and up and the arm that holds the head in will release. Move the small metal arm up and remove the print head.
This will give you a clear view of the small micro switch. Using a long wooden tooth pick pack small pieces of paper towel under and around the micro switch and carriage.
The can of cleaner should have a long plastic tube nozzle so attach this to the spray head.
Point the spray tube right near the micro switch and spray a couple of short bursts . You will notice a lot of ink on the towel. Change the pieces of towel out ,because they will be wet with cleaner and ink. Two or three times is all that is required. Assemble and try it.
Jan 10, 2009 | Canon PIXMA iP90 Mobile Printer
CanonPIXMA iP90 Color Ink Tank installation problem
yeah it sounds like a cartridge sensors are stuck or broken. i would say to replace the whole print unit. It will need a service support dealer to fit this part unless you can buy it and fir it yourself.
part number: QM2-2020-020
hope this helps
Oct 20, 2008 | Canon PIXMA iP90 Mobile Printer
Canon IP90 portable . No ink printing.
Have you performed a nozzle test? If one or more of the colors is missing when you do the nozzle test, the printhead itself is likely in need of replacement.
Before considering replacment, perform a clean on the printer. Due to variations between mac and pc, please see your documentation / support files on how to perform the clean on your printer.
After performing the clean, again perform the nozzle check to see if the problem is resolved.
If still not resolved, remove and re-install any cartridges you recently replaced to make certain they are installed correctly.
May 01, 2008 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA iP90 Mobile Printer Logo
228 people viewed this question
old marine
old marine
