Question about Sharp EL-1750PIII Calculator
HOW CAN I SET THE DATE AND TIME ON SHARP
HOW CAN I SET THE DATE AND TIME ON SHARP EL-1750PIII
    Sniper:
  • 75 Answers
How I can set the tax on sharp calculator EL-1750p iii
Posted on Dec 05, 2014
Setting time and date canon electronic calculater lc-64t
With switch in set position hit date. Hit the date button (X) and then enter the year in (4) digits (ie:2013) then hit the (X) button. This will enter the year. Enter the month and day in (4) digits (ex: 0615) and hit the (X) button again. This should set the date for you..ie:6/15/2013!!!!! For time in set position enter time (ex: 346 and hit PM button if afternoon and then press time. This should give you 3:46pm. Hope this helps.
Dec 08, 2012 | Sharp EL-1750PIII Calculator
HOW CAN I SET THE DATE ON MY SHARP EL 1750 PIII CALCULATOR
Here is a users manual for your calculator which explains the date and time setting process.
http://www.fixya.com/support/p193843-sharp_el_1750piii_calculator/manual-5324#
I hope this helps you.
Jul 08, 2010 | Sharp EL-1750PIII Calculator
How do you change date and time on Sharp EL 1750Piii
Below are the steps to assist you in
setting the Date and Time on your calculator.
NOTE: The "Time Set", "AM/PM", "12/24" and "Format" associated keys are
on the faceplate above the respective key. Position the calculator so
that you can look directly over the keypad to see the notations.
Setting the date:
1. Press the CALENDAR/CLOCK Key. The default date will appear.
2. Hold the TIME SET key down for 3 seconds or until you see the first
digit begin to blink in the display.
3. Input the correct date.
4. Firmly press and release the TIME SET key. The first digit should
stop blinking and the date is then set.
Setting the time:
1. Press the CALENDAR/CLOCK key. The default time will appear.
NOTE: The seconds will disappear.
3. Input the correct time. If you need to adjust to AM or PM, press
the AM/PM accordingly.
stop blinking and the time is then set. The seconds will again be
displayed.
Follow by pressing the CLEAR key to return to the calculator mode. To
return to either the TIME or DATE, press the CALENDAR/CLOCK key to
toggle between them.
Jan 27, 2010 | Sharp EL-1750PIII Calculator
Changing the time on Sharp 1750P III
how do i set the time and date on my calculator
Nov 23, 2009 | Sharp EL-1750PIII Calculator
I need to change the time on my Sharp EL-1750PIII calculator
You can access the .pdf manual for your particular calculator here:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Page 1 for how to set date/time:
“RATE SET”: To set the date, time, and tax rate, set this switch at the “RATE SET” position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as “date” if the
value is within the following range; “Error” is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”.
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as “time” if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Apr 27, 2009 | Sharp EL-1750PIII Calculator
Changing the date & clock
if this is on a ti calculator go to mode and at the bottome you can set the time and date
Dec 15, 2008 | Sharp EL-1750PIII Calculator
Ho w to set the date and time
Go to the link below. You need adobe acrobat to read. THere is a section in the manual called "Adjust Date & Time"
For Date:
Put Calculator on RATE SET
Press Time/date key: enter the date using a decimal between the month, day and year (all 4 digits) please the date/time button. It should reset. (Exmple: 01.16.2009)
For time:
Leave Calculator on RATE SET
Press Time/Date key until time shows up. just like date, press the hour then the decimal then the minute. (Example if the time is 10:15 you enter 10 . 15) Press the Time/Date Key and the time is set.
This link is the manual:
Jun 04, 2008 | Sharp EL-1750PIII Calculator
Set time & date on Cannon P100-DH II
I can't help you with the Canon, but for the Sharp see the instructions in the first column of the first page of this manual: http://files.sharpusa.com/Downloads/ForHome/HomeOffice/Calculators/Manuals/cal_man_EL1750PIII.pdf
Apr 08, 2008 | Sharp EL-1750PIII Calculator
Sharp EL-1750PIII Calculator Logo
815 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
