Question about Kirby G4 Bagged Upright Vacuum
Belts How do I replace a belt and where is it located. Thanks, Susan
  • 357 Answers
How do you fit a new driver belt.brush is free but does not turn with motor
Susan,
What brand vacuum do you have? If you put it in, it did not come through with your question.
Jul 16, 2015 | Vacuums
How do i replace the belt on my hoover sh40060 canister
Hi there! The belt is replaceable but it must be changed at a local service center. Follow the link to locate the nearest service center to you > Service Center Locator. If you wish to replace the entire nozzle you may do so by following the link Search Results. Thanks!
Jun 04, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt
Look underneath where the brush roller is located. The brush roller is removed to replace the belt. The new belt is installed on the motor shaft and the brush roller then the brush roller is reinstalled
Jul 27, 2013 | Eureka Whirlwind 4481 Upright Vacuum
The bristles will not spin.
See if the belt (that drives the bristles) if is loose or need replacement.The belts are located either on the left or right side of the bristle brush(you can locate it by putting the vacuum upright and see under the brushes). If it is loose or broken replace it(walmart has replacements for it or any hardware store)just bring the belt for the replacement number written on the belt,or know the brand and model number.
Nov 19, 2010 | Bissell 3522 PowerForce Bagged Upright...
How do you change the belt of the m5088520?
Hi There,
Here's step by step instructions for you on how to replace the belt on your Dirt Devil M088520 Featherlite.
Flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips
screwdriver to remove the two screws. Arrows (Diagram 1) show location of screws.
Lift nozzle guard off. Slide belt off motor shaft
(Diagram 2).
Lift and remove brushroll (Diagram 3). Dispose of old belt.
TO REPLACE BELT
1. Place belt on motor shaft, then slip brushroll through belt. Place belt in area of brushroll without bristles (Diagram 4).
2. With belt in place, pull and slide brushroll into nozzle (Diagram 3) making sure that the brushroll end caps are in the correct
orientation (Diagram 3a inset)
IMPORTANT: Rotate brushroll manually to make sure belt is not twisted.
3. Reattach nozzle guard. Secure by locating the 3 tabs in the base slots and replace the screws (Diagram 1).
I really hope that this was helpful to you. If you'd like to download the manual for your vacuum cleaner where I got this information, please see the link below where you may download. If you found this helpful, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by Fixya users.
Thanks so much.
Dirt Devil M088520 Featherlite Vacuum Cleaner
Owners Manual
Chris Jones
GoVacuum.com
May 07, 2010 | Dirt Devil M088520 Featherlite Bagged...
Vacuum has burning smell like a belt but cant figure out how to tear apart
First job is unscrew the 3 retainers (arrowed) they turn a quarter turn.
If your belt hasn't snapped it will need pulling off the motor shaft
The brushbar can now be pulled out (this brushroll had a groove scored into the side of it caused by a hair grip its visible just to the left of my thumb)
With the new belt positioned on the new brushroll insert it into the hole and locate brushroll
(To make the belt easier to locate on the motor shaft give it a bit of a stretch)
Ensure these lugs are located correctly
Pull the belt over the motor shaft
Refit the soleplate cover and tighten three screws
Before switching the machine back on rotate the brushroll to make sure the belt hasn't been trapped between the soleplate.
I hope this helps and good luck!
Nov 11, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
Sweeper belt
Greetings from GoVacuum.com,
Have you replaced the belt with a new one yet? You may want to try replacing the belt, as with flat belts like the Fantom Thunder, they do stretch out 4 -5 inches after time. We in fact recommended replacing a flat belt every year, even if the belt doesn't break, because of the stretching. I think what may have happened, is that your belt is stretched to the point where it will not stay on the pulley as soon as there is any tension (putting the brushes on carpeting), which will cause the belt just to slip off.
You should be able to replace the belt (very inexpensive, we sell Fantom belt for $2) and this should take care of the problem. When you replace the belt, you should also take the roller brush apart and remove any hair, or thread that may be wrapped around the bearings. You should be able to remove the bearing cap by pulling them, or holding one end, and unscrewing the other.
I'd even be willing to send you a free Fantom Thunder belt, if you'd be so kind to vote Fixya for this answer :-) Just send me an email with your name, address, and the exact model number (located on the back of the machine, or the bottom of it) of your vacuum, and vote Fixya, I'll immediately ship you the belt for free!
Please let me know if you have any other questions I can help you with.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
1-866-468-2288
Oct 13, 2008 | Fantom Vacums XT450K Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
104 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
