Question about HP NVIDIA Quadro4 750 XGL (128 MB) AGP Graphic Card
Where can I get a replacement cooling fan an NVidia Quadro4 750
The cooling fan on the heat sink on my NVidia Quadro4 750 has lost it's mojo and will not spin. Anybody know where I can get a replacement fan? Hate to drop another load of cash when the problem is a little fan.
Thanks in advance!
  • 24 Answers
I had a problem with the fan/heat sink assembly on an nVidia GeForce 5500 FX card a year ago. The card was in a multimedia computer and had lots of running hours on the fan, and the fan's sleeve bearings were shot, causing it to rattle. Failure of the fan seemed imminent, and before it did so and damaged the GPU chip on the card, I decided to fix it. Unfortunately, nVidia had used many different styles of fan/heat sink assemblies on this product, all of which were apparently obsolete. On closer inspection, however, one could see that the original fan on the chip cooler assembly was the core from a Sunon KD1204PFB1 12VDC/1.4W 40mm sleeve bearing brushless tubeaxial fan. One could also clearly see where the three struts were cut to remove the fan from its rectangular housing. The fan was glued to a clear plastic 3-tab mounting "spider", which, in turn, was attached to the heat sink with three small screws.
Here's what I did to fix mine; perhaps a similar approach will work for you.
1. Remove the video card from the computer.
2. Unplug the fan connector. On some cards the fan is plugged into a 2-pin header on the card, while on others it is connected to +12V via a Molex-type disk drive supply tap.
3. Remove three small flat head Phillips screws and lift fan assembly off heat sink. You will need a #0 Phillips driver or small jeweler-type crosspoint driver. DON'T LOSE THE SCREWS!
4. Very carefully pry fan from the clear plastic mounting spider. Most likely, it has been secured in the factory with some type of cyanoacrylate adhesive, i.e., "Crazy Glue". Take care not to crack the spider, as you will need to reuse it. It is better to peel the label off the back of the fan motor, than try to get the entire fan assembly off at once.
5. Clean up cyanoacrylate glue residue from spider by carefully grinding with an elliptical or spherical burr in a Dremel tool, to produce a flat surface.
6. Get a similar replacement fan. In this case we'll use a Sunon KDE1204PFVX 12VDC/1.9W 9.5CFM, 40x40x10mm MagLev bearing fan. (Ordered from Jameco Electronics, Belmont, California http://www.jameco.com, about $7+tax & shipping. It costs about $2 more than the sleeve bearing OEM equivalent, but the MagLev bearings should outlast the computer by decades.) Cut the fan core out of the duct housing in a similar fashion to the original. Be careful not to snip the wires.
7. Align the fan motor cable with the cable guide tab on the spider, to route the cable away from the hub and keep it out of the fan blades.
8. Use a small blob of hot-melt glue to secure the fan onto the plastic spider. Press the fan gently against the spider until the glue solidifies, between your thumb and index finger.
9. Install the motor assembly on the heat sink with the three small screws. Route the motor cable between the heat sink fins as before. (The original cable had electrical tape wrapped around it where it passed between the fins, but I deemed it unnecessary to duplicate this. If the chip were to get too hot, it would probably cause the hot melt glue to fail, as well as cook the PC board anyway. In normal operation the heat sink fins stay close to room temperature.)
10. Connect the motor wires to the original connector, matching wire colors. (red = +12V, black = ground) If connecting to a Molex-type disk drive power tap, note that +12V is on the yellow wire.
11. Reinstall the card in the computer, connect the fan to the power supply, and power it up to verify that it spins. If everything looks good, button up the computer and you're done.
Posted on Dec 09, 2009
Why dose my aser aspire ax3300 power up then shutdown
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Jan 28, 2013 | Acer Aspire AX3300U1322 Athlon II X4...
Cutting out windows
When the CPUoverheats it goes into thermal shutdown and will not boot up again until theCPU has cooled down.
The heat sink may be clogged with dust, which causes the CPU to overheat byreducing air circulation through the heat sink.If you are notusing your laptop on a flat surface, it may be obstructing the cooling vents onthe bottom of the laptop. Your laptop fanmay be faulty and not spinning freely, in this case replace the fan.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust.A laptop fanassisted cooling pad may solve your problem
Mar 18, 2012 | Computers & Internet
IBM x3400 server hanging / chipset & processor heating, but cooling fans are working properly.
Make sure that the fans are working at proper speed (not stuck or slow).
Secondly, heat sink could be clogged due to dust or not properly seated. Clean it if required. You may remove it, clean its fins and replace it back (for both processors if required) . Don't forget to apply THERMAL PASTE between the heat sink and the processor (If you remove the heat sink). The Thermal paste conduct the heat from the processor to heat sink which is then dissipated into air by the processor fan. You may also consider adding an additional fan, if required.
Also, place the PC at a well ventilated location so that the cool air enters it from the front and warm air leaves from the back.
Sep 26, 2011 | IBM x3400 Server
Heats up quickly and fan is very loud
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Aug 20, 2011 | ASUS CPU Heatsink & Fan, Cooling Fan
How to repair my MSI brand laptop's screen is nothing display when turn on but window starting tone, I hear
you have to open up your laptop remove the battery; remove the ram;and the hard disk locate where the the nvidia video card is...it is usually underneath the heat copper sink..so you have to unscrew the heat copper sink..the fan if it is attached.. then if you find it..try to clean first the surface of the nvidia chip..remove the paste over it..dont throw the gumlike paste it could still be used..
you heat up the nvidia chip..you can use hair dryer...for at least 3 minutes..dont melt it..just heat it up then...cool it down for 5 minutes..then return all you have taken out..then open it..
perhaps for the 1st attempt..it would not open..just close it up leave for one minute then press again the power then boom..its fix..
hope this can help you
Sep 28, 2010 | Intel Motherboard
My hp media center m7160n computer powers up, has a definite fan sound, normally the fan sound diminishes and the computer boots up. For the last several months, the high speed fan sound would not diminish...
How did you clean it?
The last one I worked on had the fins of the Heat sink totally blocked with dust. This will make the fan scream trying to push air thru the heat sink to cool the processor. If it isn't cooled it will shut down in short order.
You must BLOW it out. Use a pressurized air can. Better if you have a compressor with a nozzle.
The other issue may be the interface between the CPU and heat sink is defective. Heat sink moved or become loose.
Of course by this time the processor could be dead also.
May 17, 2010 | HP Computers & Internet
Power
If the fan is spinning quite fast then the overheating problem is most likely dust clogging the fan and heat-sink assembly. Blasting air into the fan and heat-sink can only make it worst as you are forcing the dust further into the heat-sink fins.
Remove the panels covering the vent and fan/heat-sink, loosen the dust and vacuum to remove this dust off the fan and heat-sink. Check the fan to see if it spins freely, if not replace the fan.
After re-assembling and boot up, if you still have heating problems, addition cooling can be employed by purchasing a laptop fan assisted cooling pad. Place the laptop on top of this pad and the fans on the pad will direct additional cooling air to the laptop's vents.
Mar 08, 2010 | Gateway ML6732 Notebook
Like many others, I have an overheating problem especially with games. I am looking for a repair manual in order to clean and check the heat sink. The Acer website only posts Owners Manual. Any idea where...
it sounds like an overheating issue. download everest home edition andhave a look at the temperatures of the graphics card. the 7000 isntreally a gaming card, but it should'nt overheat without overclocking...
Sep 14, 2009 | Acer Aspire 7520-5185 Laptop
Bad colors and snow
does it have a fan on card if so is it working or is heat sink etc blocked by fluff and dirt if so clean it try again. this sort of thing happens to cpu,s as well I regularly remove and clean fans and heat sinks
Jul 17, 2008 | XFX NVIDIA GeForce 8600 Graphics Card
HP NVIDIA Quadro4 750 XGL (128 MB) AGP Graphic Card Logo
1,638 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
