Question about Shavers
MS 4010 durabrand shavers
My MS 4010 durabrand shaver has dropped one of its foils covering the blades.  Where can I find a replacement part?
Please advise
My email address is :
  • 6 Answers
SOURCE: Shaver head warning light
Here is a link to the owners manual for the HQ7785 Electric Shaver. If this is the wrong model, your manual may be listed at this site as well.
Posted on Apr 16, 2009
  • 276 Answers
SOURCE: Norelco 5825XL Replacement Blades
HQ5 is not compatible with HQ55. I've checked the Service Manual and HQ5 is the correct part. It's got to do with the driving mechanism for the head.
Posted on May 18, 2010
  • 1535 Answers
SOURCE: My Braun shaver 8585 has died. Foil, cable, box,
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See link below
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
Posted on Aug 23, 2010
  • 1535 Answers
SOURCE: how do I remove the foils on my sp 69 shaver and
You will find instructions posted at See link below
Posted on Sep 20, 2010
  • 1535 Answers
SOURCE: How do you remove the battery from a Remington
There are two screws on the back just under where the cutter fits on. Remve shaver head then remove screws and you can then gently pry the front and back apart from the top.
If you need replacement batteries, you will find them at See link below. You will need two
Posted on Dec 20, 2010
  • 1535 Answers
SOURCE: How do you insert a new Remington Microscreen
You will find instructions at See link below
Posted on Jan 06, 2011
0 characters
1 Points
Trimmer of my Panasonic EX3833S is not working
panasonic es3833 replacement foil and blades
panasonic WES9979P combo set for electric shaver panasonic es3833 replacement heads.
panasonic WES9941P outer foil for electric shaver panasonic es3833 replacement parts.
panasonic es3833 replacement blades
panasonic WES9942P replacement blade for electric shaver part panasonic es3833 replacement parts.
Aug 25, 2013 | Panasonic ES3833 Electric Shaver
Need a trimmer replacement
panasonic WES9025PC replacement outer foil and inner blades set for electric shaver panasonic es la63 replacement parts.
And panasonic es la63 parts is also separated foil and blades, then panasonic es la63 replacement foil is WES9165PC and panasonic es la63 replacement blades is WES9068PC.
Feb 06, 2013 | Panasonic ES-LA93 Shaver Electric Shaver
Where can i get replacment blades and cover for the panasonic er223p
panasonic WES9752P replacement inner blade for shaver panasonic es2206 parts.
75272521-cb02-4edc-868c-c98113bab05e.jpgpanasonic WES9775P replacement screen cover foil for shaver panasonic es2206 parts.
Jan 06, 2013 | Panasonic ES2206AC Electric Shaver
Do I need to replace the shaver's blades or foil? or Both? Or get a new shaver? Or should I try to sharpen it?
panasonic es4815 replacement foil and blades
panasonic WES9839P combo replacement outer foil and inner blade set for electric shaver panasonic es4815 parts.
Jan 27, 2012 | Panasonic Shavers
I am having shaver es4033 want spare of,foil and foil cover
Panasonic es4033 replacement foil and blades is panasonic WES9839P foil and cutter set.
Dec 12, 2010 | Panasonic Shavers
Where should i can buy ms5100 shaver blades
remington SP-96 replacement screen foil and cutter heads for electric shaver remington ms5100 blades replacement parts.
Mar 17, 2010 | Remington MS-5100 Electric Shaver
Shavers Logo
239 people viewed this question
Top Shavers Experts
Anglia Clipper...
Are you a Shaver Expert? Answer questions, earn points and help others
