Question about Yamaha RX-V661 Receiver
Humming coming from speakers. this wasn't a problem a couple of weeks ago. thit unit is a yamaha rx-v661
SOURCE: Yamaha RX-V657 Zone 2
Suggestion by clarkent22
I called and spoke with Yamaha support staff (Chuck) who was very helpful. I was able to get my issue resolved hopefully this works for you too.
Couple of solutions:
1) Go into the Menu setting (Manual SetUp/Speaker Set) and make sure that you do not have Presence Speakers or Suround Back Speakers
2) Also in the Menu settings (Manual SetUp/Options/Multi Zone Settings) make sure that your Zone 2 Amplifier is set to "Int" (assuming you are not using external amp
3) Zone 2 can only accept an analog signal (not digital)... so there are two steps to this one. First, make sure that you either run only analog, or if you run digital and analog then you need to select "Analog Input" on the front of the unit. If yours was working earlier, my guess is that your input settings got switched to digital (or auto) You need to have analog set up for each specific external source (DVD, Cable/DTS, etc)....
4) This model receiver will only let you control Zone 2 with the remote control. You can power it on the receiver unit. But to select your source you have to press the Amp button, then the ** button. Then you control Zone 2 and you can toggle sources and adjust volume. (Check your owners manual for programing remote for zone 2.. think I pressed the "code" button and then 2999.)
Hope this helps... it worked for me If not call Yamaha they were very helpful.
Posted on Dec 05, 2007
  • 54 Answers
SOURCE: yamaha rx-v661 unsolved speaker wiring error
1. Try running the auto setup without the sub. ( is it a powered sub {the sub has its own amp on the back} or is a NON powered sub that is driven off the speaker jacks of the Yamaha receiver. )
If the sub is powered, and connected to the Amp via the RCA cable from the " sub out " jack, chances are you either have a defective sub or a gound loop.
Good luck...Rob
Posted on Mar 04, 2008
  • 8 Answers
SOURCE: No volume in Zone 2
Get the original Yamaha remote, go to Set menu, manual setup, speaker setup, and look for "extra speaker." it needs to be set to "zone 2." This is off the top of my head, so it should be pretty accurate. Get used to doing this, though, as this amplifier assignment to zone 2 is prone to resetting itself in those Yamahas.
Posted on Sep 07, 2009
satavlad
  • 405 Answers
SOURCE: My Yamaha RX-V661 shuts off at moderate volumes.
Try to disconnect speakers one by one and see if any of them causes the problem.
Posted on Nov 05, 2009
perpetually
  • 360 Answers
SOURCE: I want my Comcast remote & Yamaha RX-661 to communicate??
30176 or 31176
I am guessing at what remote you are using, so the code may not work. If that is the case, go to the following link and pick your remote from the picture list.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Posted on Jul 13, 2010
Wrong remote
no but you can change the settings from the front panel of the unit.
Feb 12, 2014 | Yamaha RX-V661 Receiver
No sound from zone 2 speakers on yamaha rx-v661
Have you gone into the speaker configuration menu and turned on zone 2?
Oct 18, 2013 | Yamaha RX-V661 Receiver
No sound comes out but my speakers buzz. What do I do? I have a Yamaha RX-V661.
Sorry but you have to get your amplifier at a technician. The buzz from the speakers means internal electronic damage at the amplifier. TAKE CARE THAT in case of keeping the speakers on the buzz noise for some seconds may destroy the speakers.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 04, 2010 | Yamaha RX-V661 Receiver
I need an HDMI PCB
These parts come from yamaha so you will just have to wait, sorry. They get replaced commonly. Larry's Electronics.
Apr 23, 2010 | Yamaha RX-V661 Receiver
Nov 05, 2009 | Yamaha RX-V661 Receiver
No volume in Zone 2
Sep 05, 2009 | Yamaha RX-V661 Receiver
Subwoofer plug broken?
Most likely the plug is ok but the level control for the subwoofer will need to be readjusted in the receiver, If the level cannot be raised making sure your source being used has subwoofer information, then there could be a problem in that circuit.
Jul 17, 2009 | Yamaha RX-V661 Receiver
Right speaker dead on zone 2 on my RX-V 1600 receiver
must be the right speaker wire, sounds to easy I know but maybe your wiring is grounding out the audio to that channel.
Jul 15, 2009 | Yamaha RX-V661 Receiver
Cannot figure all of the setup instructions
is your problem setting up? connecting the speakers and sources or you have made the speaker connections but to make it sound is your problem... pleased let me know.
Mar 31, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V661 polarity problem
There is no "fix" the mic is picking up a lack of bass based on room acoustics and is trying to help. There is nothing wrong. If you are using bi-pole or dipole speakers it will always show out of phase.
Feb 27, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V661 Receiver Logo
55 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
