Question about Logitech Z-5300 Computer Speakers
Noise when changing the volume and connecting speaker to anything.
Hi All,
I have a Logitech speaker system that I have been happily using over the past 2 1/2 years....(Z-5300). Just yesterday, it started making noise when plugged it to any device (low pitch crackling noise)
Symptoms are;
Crackling noise coming out of all speakers, especially with high base. I am talking about with volume only half way.
When I adjust the volume via the remote, I hear the small bang noise each time I go up one bar up on the volume control.
I do connect speaker to both my DVD player and PC, and it's happening to both!
Also all speakers and the sub have the same issue....
I have a bad feeling it's the AMP!! Nnnnnooooooooo.
I did look at the AUS Logitech website and I believe the warranty is only for 2 years, correct???
Done the turn off\reconnect cables, etc.. No luck.
Any ideas anyone, please. Appreciate your advice.
  • Anonymous Dec 24, 2007
    I have the same problem. This happened right after I moved them.
  • 70 Answers
Firstly check the cable, some times it may in loose contact
otherwise any radiation equipment is located near by the amplifier,
sol. replace the location of the amp. and check cable loose contact
other wise
it is due to its amplifier IC problem, it is weak due to over load signal, or temperature of IC make leakage
sol.replace IC
Posted on Jan 01, 2008
Buzzing noise z4 logitech speakers
Hi Haley,
I also enjoy good Music and excellent sound from my speakers that i have and know what you going through. There is two problems that i see here. One is that your bass speakers is dying on you from the excess bass that has been exerted throught it or have you tried lowering the adjusting bass from the contol panel?
Try adjusting the bass and if that doesnt work aleast you've identified your problem.
Thanks Haley for using Fixya.Good Luck.
G..
Nov 03, 2011 | Logitech Z-4 Computer Speakers
I listen to my iphone on my Logitech speakers on my desk. When the volume is low, the speakers work great. However, when I turn up the volume, the green light fades, and the speakers are scratchy. Is...
Hi Roxanne
Sounds as though the power-supply might be faulty. As you turn up the volume more power is required from the supply and it's not delivering - hence the light fading.
Jun 16, 2011 | Logitech LS11 2 Speakers
MY speakers are making weird noise, i have logitech x240 and on youtube i can only listen audio, not voice. Everything is connected but its still making weird noise.
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
don
Feb 26, 2011 | Logitech X-240 Computer Speakers
I am trying to set up my Logitech QuickCam Deluxe for Notebooks but when I am using the Logitech Audio Tuning Wizard I dont get past the microphone test, are my settings wrong? what settings should I have...
Logitech Audio Tuning Wizard ????
I have this webcam - The settings I have made in 'Settings' ( 2 gearwheels) on the Logitech toolbar are:_
Default mic = 'microphone 2 - logitech notebook'
Volume adjustment - midway
Suppress background noise - box checked
In addition my audio settings for yahoo messenger:-
Laptop x webcam/mic x Vista x Yahoo Messenger
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO MESSENGER
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Calling and Audio
Set mic and speakers to show Default equipment
Run call up assistant to test audio equipment > Apply > OK
Dec 23, 2009 | Logitech QuickCam Deluxe for Notebooks
My logitech z 2300 subwoofer is not producing sound
Since this set is hardwired together and the other speakers are working, the only easy fix would be the subwoofer got turned down on the remote volume control. Anything more would mean its broken. If its under warranty take it back. If its not and you know somebody capable, you might have them check for the obvious,bad solder connections on speaker, or and open voice coil on the speaker it self.
Aug 26, 2009 | Logitech Z-2300 Computer Speakers
Output port for left speaker Z2300
I've been having the same problem actually.
In my situation, turning the volume up and down using the speaker volume control will fix the problem. I only have the faint volume problem at some positions of the dial. turning it up usually fixes it. I'm thinking that opening it up and cleaning it might fix the problem (it used to work with an older set of Creative speakers i had).
If that doesnt work im going to try to get a new remote from logitech.
Jul 02, 2009 | Logitech Z-2300 Computer Speakers
Constant loud muffled noise coming from the sub and speakers.
Try playing with the connection, sounds to me maybe the jack is going bad or has a shorted connection. Plug it in and out slowly to see if that's the issue.
Sep 25, 2008 | Logitech Z-5300 Computer Speakers
Logitech x530 hissing noise
I had the same problem for the longest time with my set of Logitech 540 5.1 speakers. Turns out the solution was pretty simple. All I did was open the Master Volume controller and mute the Microphone. Hissing went to zero. Sound is great now.
May 15, 2008 | Logitech X-530 Computer Speakers
Lip Sync issues with Logitech Z-5500 and PS3
hello there
First things First:
1) change the digital opt, cable, for another with cooper conduction. **
2) check connection again on low volume.
good luck
Mar 21, 2008 | Logitech Z-5500 Computer Speakers
Logitech g51
I'm sure you went to Control Panel, opened device manager, and and checkeck for any yellow checks for your
sound, video and game controllers. If there are none, your system is go. Then go to your audio manager on control panel, and set it up for whatever speaker configuration you have. I have realtec audio manager. This step is a must for configuring—you choose whether your laptop will use its own speaks or use your external speakers—you have to turn off the internal speakers and turn on the external. Did you forget?
Nov 08, 2007 | Audio Players & Recorders
Logitech Z-5300 Computer Speakers Logo
259 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
