Home | PDAs | Samsung u600 usb con...
PDAs
Problem for PDAs
Generic problem for all PDAs
Samsung u600 usb connection wizard
By hloopy1 on Oct 24, 2007
hi ive deleted my samsung internet and samsung pc studio
i reinstalled the cd but now i cant connect to the wizard it just wont load at all and i cannot access samsung pc studio anymore it just gos to the usb connection wizard but wont connect.
before i deleted it1 it all worked ok
any ideas?
Clarification Request
Posted by pat73891 on Nov 14, 2008
cannot get photos from phone to pc, downloaded samsung pc suite but it might as well be in japanese, got a usb data cable. any ideas? thanks
Same Problem
Apr 20, 2009
-   Problema la samsug U600 la al meu este ca nu sta conectatc prin USB la PC .....se conecteaza 5 min si dupaceea se deconecteaza....nu stiu ce sa ii fac...:(:(((:((:((-   dydy_paula
Apr 15, 2009
-   can i download photos from my phone to my p c with a ubs cable-   Guest
Apr 13, 2009
-   fuke nose my problem same pising me off **** amsungs never buy a nuffer 1-   mikey-jas
Apr 05, 2009
-   i have set up my samsung usb lead to my old laptop and know i've tried to do it on my new computer but can't set it up. i've also lost my instrustions to do it.
can anyone help??-   corinna-beth
Mar 27, 2009
-   Same-   Guest
Best Solution
posted on May 05, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Oh, and before you do any of that, make sure you set your phone up to use the "Samsung PC studio" selection in the USB Settings menu (Main menu, Settings, Phone Settings, USB settings, "Samsung PC studio") =D
Solution #2
Very Helpful)
Frodosh
Rank: Apprentice
Rating: 96%, 30 votes
PC Studio for Vista can be found on the Samsung Website. Series is "U series" and model, of course, is U600. As for installation, as Samsung suggests, make sure that the phone is NOT connected to the USB port at ANY POINT prior to the completion of the installation. Install the software as normal. Then, after it has finished installing, open up PC Studio and plug in your phone. At this point, the software SHOULD recognize that the phone has been connected after setting it up to use USB connection in the “Connection Manager” (Click “File”, “Connection”).
If it is still not recognizing the device after plugging It in, or if it displays a message along the lines of “USB Device Not Recognized” KEEP THE PHONE PLUGGED IN TO THE USB, Go into the Control Panel in the Start Menu and open up the Device Manager. At the very bottom of the list of hardware etc, there will be a selection for “Universal Serial Bus controllers”, expand this menu and look for an item called something like “Unknown USB device”. Double click on the device and go to the “Driver” tab (I think you have to press a button on the first screen that appears in order to get to the menu driver tab. Although I can’t remember what was written on it, there was only one there). When in the Driver tab, click on “Update Driver”. Now on the wizard that appears, click on “Browse my computer for driver software” then, ignoring the rest of the page, click on “Let me pick from a list of device drivers on my computer”. Uncheck the selection box “Show compatible hardware” and scroll down the list of Manufacturers until you get to “Samsung”. Now, if you’ve installed PC Studio, you should see four separate selections for “Samsung”. Click on the fourth manufacturer selection and you should see “SAMSUNG Mobile USB Device” as a Model selection, select it and click “Next” (If, 1, you don’t see “SAMSUNG Mobile USB Device” at all, then just browse the other three Samsung based manufacturers or, if 2, you have more than one entry of “SAMSUNG Mobile USB Device” then select the top one”. Also, if Windows comes up with any warnings about installing device drivers, just ignore them). Windows will now update the driver (It actually updates three drivers). If you open up PC Studio the phone should now be recognized as connected (Assuming your prior setting up of the Connection Manager to use USB).
Good Luck.
Was this helpful?
Yes
No
10 people thought this was helpful
Solution #3
posted on May 24, 2009
Very Helpful)
inter1212
Rank: Apprentice
Rating: 100%, 1 votes
i can t connect my usb samsung d 500
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Apr 10, 2009
Helpful)
jayrlao
Rank: Apprentice
Rating: 92%, 3 votes
Hi All,
I've been struggling for a few weeks now on this issue. Anyway, after searching I stumbled upon this link. Following the steps below got my Windows XP to recognize my phone.
1. Fully charge battery 2. Remove Battery 3. Remove Sim and memory card 4. Plug in USB into phone 5. While holding down "*" insert battery.
Thanks to Wildnick for the steps.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #5
posted on Feb 01, 2009
Somewhat Helpful)
sunshine15
Rank: Apprentice
Rating: 75%, 1 votes
Since I bought my G 600 for my christmas present I've been having all sorts of problems with my vista laptop, I tried all the tricks in the book but yet it could not reconize the phone, I was about to give up because I have download all the neccesary software but no luck, until I decided to try one last time and lo and behold am getting my monies worth, Am showing my appreciation by giving my ratings to FRODOSH, I'll give 100% for your advise, it works miracle, I should be in bed just now but because it opens a whole new world for me so am still up tranfering my beloved music and mails and files unto my phone and visa versa, well done my brother, Hope this will sloved others problem. In my view, I think samsung is an ********, to be making phone that is not compatable with these nonsense Vista. Am happy I found a solution, but didn't think that one should have to go through this hassle to get it done, but at lest it did worht it. THANKS again.
Was this helpful?
Yes
No
Popular Solutions for PDAs
Questions and Unsolved Problems for PDAs
Answer
I want a product similar to Palm m505 to store data only.
Answer
hi I have an 2g iphone it has a incoming call problem i couldn't recive any call. what should i do... (More)
Answer
how to close aplication on my n6680 cannot send message, its sending failed.
Answer
Hi, i have the HTC MTeoR phone, the problem that i am facing is that the camera capture the pictures... (More)
Answer
when i touch the screen to access it can't run
29 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 24, 2009
same
Comment by Guest, posted on Dec 29, 2008
hi i've installed the cd but when i click samsung pc studio it says cannot connect to connection manager what do i do?
Comment by mick360, posted on Dec 17, 2008
I have the same problem, i have the disk which works fine on windows xp but not vista. I have tried downloading the softw!are from the Samsung website but when i click on the link i get an error message.
Contacted samsung to say i could not download the software and they sent me a reply saying how i can connect the phone blah blah blah (I already kow this as it works on xp) and if i have any more problems to try downloading the software and reinstalling it.
Duh! Did they not read the message that is the problem i have!!!
Comment by Guest, posted on Dec 16, 2008
well my problem is, that i have the disc but it says its not compatible with windows vista
Comment by Guest, posted on Dec 15, 2008
I followed the steps you gave, but the samsung site won't let me access the page >.<
Comment by Guest, posted on Dec 01, 2008
I can't use the wizard
Comment by nimm, posted on Nov 24, 2008
my computer wont even let me install anything off the cd, myU600 phone cant connect to the computer through the usb cable, so annoying! anybody know what to do??
Comment by Delashena, posted on Aug 03, 2008
For the first time I connectet my U600 Samsung to my PC very easy and automatically, but after unistalling and installing again with special CD programm, which was in the phone case, I can not connect my phone to my PC through USB cable. I even bought a new USB cable, but It did not help ether. Pls. help me to solve this problem.
Thanks a lot,
Golestan P.
Comment by Guest, posted on Jul 31, 2008
iv lost
Comment by k07sanjay, posted on Jul 22, 2008
I want to connect my phone samsung sgh600, i have installed pc studio and usb driver. I am not able to connect my phone to pc. I could not found the usb connection wizard.
Can anyone help me pls write me.
Comment by Guest, posted on Jul 17, 2008
i lose may cd to connect usb i wondered how to do next?
Comment by claireludman, posted on Jul 15, 2008
I have lost my cd to go with my usb cable just wondered what to do next?
Comment by tmukuzi2000, posted on Jul 13, 2008
I have installed usb driver cd and the process was completed.The problem is when i connect my phone it does not connect .The cd is for windows 2000 and windows xp, i have windows vista
Comment by mickeyfish, posted on Jun 15, 2008
lost my cd for u600, cani get a free download?
Comment by michiener, posted on May 08, 2008
ive lost my installation cd.. can i in anyway download a free installation for u600 thru the net? tnx
Comment by Guest, posted on Apr 24, 2008
i have my usb wire but i cant see my data on the phone
Comment by Guest, posted on Mar 03, 2008
I dont have instalation disc for usb,and I cannot get my pictures on my pc.is it possible to get this on internet.I have vista is this a problem?
Snezana
Comment by Glenice T, posted on Mar 02, 2008
I can't download photos from my Samsung u600 mobile phone
I have Windows Vista and the CD appears to be only compatible with Windows 2000 and XP
Will I ever be able to download photos?
Can you let me know whether there is a software version that is compatible with Vista
Comment by mrphoneguy, posted on Jan 24, 2008
i installed everything on the cd, but the connection wizard will not load and i cannot get into the program
Comment by rararara, posted on Jan 17, 2008
i'v lost my cd to my samsung u600. but i have a new laptop. i want to get pictureson my laptop.. how can i download it ?
Comment by ljoy, posted on Dec 23, 2007
i lost my installation-cd, can i download it thru net?
Comment by Guest, posted on Dec 21, 2007
I have down loaded samsung vista and when i connect the phone it wont connect it said there is a problem with wizard
Comment by Guest, posted on Dec 16, 2007
i have losen my installation-cd and the samsung U600's instruction manual says that i shall not connect my phone to the computer before i have install all the settings. Is there some net side where i could load those installitions?
Comment by Guest, posted on Nov 25, 2007
when i try to install samsung pc studio, it says it can't install and im not sure why...i have windows vista, does that make a difference??
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PDAs:
Top PDA Experts
Rank: Guru Guru
Solutions: 554
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
