Question about HP Photosmart C5180 All-In-One InkJet Printer
Hooking up wireless computer to printer
I have a HP portable computer that I have hooked up to a wireless router and a printer. I've been able to print out pictures without any problem. I recently went on vacation and took my portable computer with me. When I came back I was unable to print out pictures via the wireless computer. I got a note saying that the RVC service was unavailable. I unhooked the wireless router and the printer and left them off for a minute and then turned them back on to try to reset the connection but that didn't work. How do I solve this problem. Thanks for your help.
Jim Thomas
Savannah, Ga.
    New Friend:
  • 62 Answers
HP has a problem solving or troubleshooting software you can use. Also maybe your port settings changed. 168.06.01 is a typical port. Check that. Also use the WPS method to connect.
Posted on Apr 16, 2017
SOURCE: HP laserjet 1020 one page only when usinga printserver.
I have same problem and have just learned that HP LaserJet 1020 is a host-based (i.e. GDI-based) printer that makes use of the processing power of the host it is hooked up locally to. No GDI based printers works with print servers.
Posted on Mar 07, 2007
  • 93 Answers
SOURCE: how to hook up this printer wireless to my main computer
We cannot connect the pro l7680 printer wirelessly. Connect the printer to the router via ethernet cable and connect the desktop to the router wirelessly.
Posted on May 26, 2008
  • 93 Answers
SOURCE: HP 7410 off line with Vista & HPM8000 computer
Once right click on the printer icon and make it online and then clear the print que and then download and install the patch from the below webpage.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-54112-1&lc=en&cc=us&dlc=en&product=391194&os=2093&lang=en
After installing the patch restart the computer and check for the result.
Posted on Jun 19, 2008
mbase213
  • 728 Answers
Hi jjank740;
First off, did you try to recycle your printer? Turn it off and back on again. Sometimes power outages can disconnect that printer. If that doesn't work. Go to the printer and access the system network configuration on the led panel. Type in the WEP number and password again, and let it search for the connection. That should do it. Once it's connected you'll see the blue wireless indicator turn on.
Good Luck
Mark
Please don't forget to leave a rating.
Posted on Feb 19, 2009
  • 214 Answers
SOURCE: Printing wirelessly using ethernet from printer to router.
You need to get IP address from the printer, and enter it in the router. Or sometimes the software will do it on installation
Posted on Apr 25, 2009
How do I connect my HP 8250 Wirelessly? I have a router and a Linksys wireless-B adapter.
Make sure your router is set to accept Wireless-B connections...most aren't. Log into your router and setup wireless, using an SSID and security. Then connect with your laptop and you're good to go.
Mar 12, 2011 | HP - HP Photosmart 8250 printer
I recently purchased an acer computer that has windows vista. I have a hp2200dn laser jet printer and I want to hook it up by ether net into a wireless router. Unless this printer is wireless. I have a...
All you should need to do is connect the HP printer to your wireless router via Ethernet cable (which should be included with the printer). Follow the instructions that came with your printer to set it up on your computer.
May 13, 2010 | HP LaserJet 2200dn Printer
How can I connect my wireless laptop to print wirelessly?
run the wireless setup wizard on the printer from the front panel menus of the printer...this would assign an IP address to the printer from the router...then use the s/w cd that came along with the printer and get the drivers and s/w installed on your computer....if you want a wireless connection it would give you approprite options
Jun 21, 2009 | HP Photosmart C7280 Printer
Setting up printer on home network
Because your printer is not either wireless or network capable, the only way to get the results you need is to purchase a usb print server, hook it to your router, set it up through it's management console, and if your router is wireless, you can hook up to your router and print to your printer with your desktop turned on or off.
Apr 13, 2009 | Computers & Internet
How to hook up this printer wireless to my main computer
Hi jjank740;
Good Luck
Mark
Feb 19, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Hooking a Linksys wireless router and SpeedStream router together
Connection should be from LAN port of Speedstream going to Internet port of Linksys router. That should be it.
Oct 25, 2008 | Computers & Internet
Hp Photosmart C6180
In order to have a network connection you need to connect your printer to a wireless router that you have. make sure that your computer is already connected to that network.
1. Connect the printer to the router wirelessly. Press the "setup" and then press the arrow key and look for "network". Press ok when you see "network". Press the arrow key and look for wireless setup wizard. After you have successfully connect your printer to the router press ok
2. Check the ip address of the printer by printing wireless configuration page.
3.install the software for the printer
Aug 21, 2008 | HP Photosmart C6180 All-In-One InkJet...
Fax hp office jet j5780 hook up
how to connect the scanner to the computer
Jul 21, 2008 | Lexmark X3470 All-In-One InkJet Printer
May 24, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
74 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
