Question about Randell 47 cu. ft. / 1331 liter Commercial Freezer 47 cu. ft Glass Door Reach-in - All Stainless Steel
A Delfield Mdl 6151-S 2 door stainless freezer into a cooler? Change thermostat? It cost me $25 . Factory service says it's not practical. What is practical?
  • Randell Master
  • 1,035 Answers
To do it right, you gotta get technical. Need to know the BTU rating of the evap coil. Then match the compressor/ condenser coil and the expansion device to the same BTU rating. Can prove to be somewhat expensive. Your unit probably has a 3/4 h.p. compressor. This is pretty big for a 2 door unit. Probably too big, but again, gotta get the technical on all that stuff.
Posted on Jun 26, 2010
How can i change a delfield 407-dhl from a freezer into a cooler
Refrigerators and freezers are almost identical except for more controls on a freezer. Just raise the thermostat to the temperature you need. If it won't adjust that high, you will need to replace it.
Dec 02, 2013 | Freezers
Service manual for delfield 6151 g
http://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/6000XL%20SERIES_spm.pdf. Start with this one.
Jul 02, 2012 | Delfield 113.28 cu. ft. Commercial Freezer...
Delfield freezer evap fan is good i test it with 120v but not working in the freezer whats else could be the possible problem
Defrost limit/fan delay switch may be bad however if the coil temperature is not 25* the switch will not close.
Jun 08, 2011 | Delfield Freezer 6151XLSR Stainless steel
My freezer 6151 has build up ice on top of the unit. please help?
start by verifying that the defrost time clock works. Located in the top of the unit. Let me know if we need to go any farther.
Oct 07, 2010 | Delfield Freezer 6151XLSR Stainless steel
There has got to be a way to change the factory preset freezer temperature on a Delfield 6000 series MCII to operate at refrigerator tempatures. Does anyone know how I can change the factory preset...
Do you mean to go up to +36 degrees? If so, it just won't work correctly. The refrigerant is the wrong one to run at 36 degrees. The pressure on the "low" side of the compressor is so low that the compressor will starve for freon if you tried to change the thermostat to "warm" it up to +36. Also the defrost cycle would have to be disabled or it would jump to 50 or 60 degrees 4 times a day. It also has the wrong cap tube for that temperature. It could be done with a very expensive condensing unit changeout. Over the years I have seen a lot of people try it and nobody that I know have been succesful at it. It may be easier to find someone who wants to trade. After all a freezer is worth more dollars than a cooler. Good luck.
Oct 07, 2010 | Delfield 113.28 cu. ft. Commercial Freezer...
Delfield freezer 6151-S ,replaced door gaskets and they don`t seal
Take a hair dryer (or take off the gasket and throw them in the clothes dryer (yes I am for real I do this all day long)) then put them back on. or the hair dyer way is keep heating the gasket up and holding the door closed while you do it. they should start to seal as you are pressing them together.
Sep 23, 2009 | Delfield Freezer 6151XLSR Stainless steel
Delfield freezer 6151-S keeps tripping GFCI
Try it in a normal plug. Freezers and refridgerators just pull too much to be used on a GFCI. The more a GFCI is used the eaiser it trips.
Aug 31, 2009 | Delfield Freezer 6151XLSR Stainless steel
Delfield Mdl.6151 freezer
If the thermostat will let you set that high of a temp, you probably could use it. Let me give you a few things to think about. At higher temps, the refrigerant pressures could cause the compressor to work harder which would shorten the life. The unit will also have shorter run cycles which could over work the compressor. Shorter run times will affect the humidity of the conditioned space. Bad thing if you have fruits and veggies in there. You will have to eliminate the defrost cycles. No need to have "Forced" defrost at cooler temps. I am not a big fan of using equipment for things other than what it was designed for. So, you can try it and keep an eye on how it performs. Good luck and hope this is of some help.
Jun 03, 2009 | Randell 47 cu. ft. / 1331 liter Commercial...
Can I turn my Delfield freezer Mdl 6151-S into a cooler
It can be done but someone would have to do their homework. They have to know the BTU rating of the evap. Then match the compressor and expansion device to it for the intended temp range. In some cases, the compressor can be used in multiple temp ranges, so you could be lucky and just change the expansion device and possible the temp control, depending on which one you have. Let me know if I can be of any further help.
Digital control settings
I have the dlefield maual if you talking about the digital defrost/temp adj
Aug 03, 2008 | Delfield Freezer 6151XLSR Stainless steel
Randell 47 cu. ft. / 1331 liter Commercial Freezer 47 cu. ft Glass Door Reach-in - All Stainless Steel Logo
473 people viewed this question
Top Randell Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Randell Freezer Expert? Answer questions, earn points and help others
