Indesit wd12s washer dryer
Machine starts to  fill then programmer keeps rotating - pumps ok- spins ok- heater checks out ok with meter - when put onto last rinse position programme button clicks forward one position and starts to fill and drain at same time whilst prog knob rotates all on its own.  interlock works ,- valves ok ,-pressure system not blocked , any ideas please on how to rectify ,many thanks
Hi same prob as i had you need to change your board in the bottom of the machine the indesit wd12s was plaged with probs shop around tho i got a board for £23 you can pay upto 80
Posted on Nov 14, 2007
  • 64 Answers
After all you have checked out I think it must be a programmer fault. Sorry I dont know how to check it out for sure
Posted on Oct 25, 2007
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Zanussi washing machine won't start E10, E40 & E50 at times
It was suggested that the pump had failed and taken out the programmer with it - expensive! Wife wouldn't wait, and bought new machine. Problem almost solved - anyone want an out of order washing machine?
Feb 03, 2009 | Zanussi ZWF1440 Front Load Washer
My indesit washer/dryer model w10 ,is not working.the programme dial keeps cliking round wont start a programme or take in water.
probably a main module fault but worth while checking for continuity thro the heater and that the pump and filter are ok. the idea is that when a fault is detected, the dial will click round indicating a fault but usually it is the module itself. expensive part. not worth repair
Jul 04, 2008 | Indesit Washing Machines
Washing machine wont do anything
rotating timer knob indicates that there is a fault, obviously, so its a case of going through a checklist, based on info given, check in this order, outlet pump, for open circuit, then heater element for open circuit, then maybe the water valves, you have given little information for me to go on as an engineer, please understand, the more you say the more detail we can give ..... ok cheers with looking for the fault, best of luck and work safe
Dec 21, 2007 | Indesit W 123 Front Load Washer
Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Oct 29, 2007 | Indesit W 123 Front Load Washer
Indesit washer dryer
check heater element first, thats a common fault on these machines, loose connection or open circuit, after that check the pump for same open circuit
the rotating of the timer knob indicates a fault, maybe even a setting fault, to try and reset set to off, turn off and back on again, till light flashes, then turn off again and start again
if you do not know how to test for open circuit then the job is not for you, sorry
Oct 14, 2007 | Indesit W 123 Front Load Washer
Indesit w143uk
these machines are a problem! the dial clicking round can be a component fault - ie pump etc - or a module fault. from what you describe, fault could be with the pump. an easy way to check is to power the pump up independently and see if drain works ok. (i assume you have checked the filter) after that, check continuity in the heater as well. if both of these are ok, you are faced with a module fault
Jul 21, 2007 | Indesit W 123 Front Load Washer
Open Questions:
Washing Machines Logo
273 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
