Question about Black & Decker 7750 4 1/2'' Small Angle Grinder
I can't get the wheel to my grinder loose. The locking nut barely locks. Is there any tricks to loosening it up and getting the wheel off so I can put a new and better one on. I don't know if I shouold put some WD-40 on it or what? Please help me Drew
  • 142 Answers
You should have a pin spanner wrench that fits into the holes on the lock down nut. Hold the shaft with a open end wrench that fits the flats on the shaft.
If you dont have the spanner wrench, use a drift punch to tap the lock down nut to loosen.
Posted on Jun 03, 2009
  • George Fleming Jun 03, 2009
    You can put so WD on it if you think it will help.
I have a Delta 6 bench grinder model #23-680. How do I hold the shaft from turning as I loosen the nut hold the grinding wheel in place?
Hold (or lock) the grinding wheel on the other side if loose or lock because the locking direction is the same direction and don,t forget to ringing (sound-check -like a tuning fork) the stone if you replace it with a new one The risk is small but safety first
Apr 10, 2017 | Delta Grinders
Hi, I'm trying to change the fiber disc on a DeWalt DW402 but after pushing the locking button on top I'm not able to unscrew the wheel. If I turn counterclockwise the wheel turns, but it seems I...
  • 1 Check the grinder before you begin. The newer discs on rotary grinders have patented buttons that allow you to remove the disc without any tools. You may have one like that. In models like this, there's usually a spot to depress and then remove the disc.
  • 2 Turn off the grinder before you attempt to remove and change the disc on your rotary grinder. If it's battery powered, put the grinder in lock position so you can't accidentally turn it on. If it's electric, unplug the grinder from the wall.
  • 3 Look for a nut in the center of the disc. This is a give away that you need to use your special wrench. Sometimes the grinder comes with a tool necessary to loosen and remove the nut. Other times you need to use a wrench.
  • 4 Lock the wheel into place before you begin. You can find a button or switch at the side or back that allows you to do that. When you lock the wheel in place, the disc remains still as you loosen the nut in the center.
  • 5 Remove the nut in the center with either the tool provided with the grinder or a shop tool and lift the disc off your rotary grinder.
  • 6Lift the disc off the rotary grinder. If you have different discs, remember to check for the best fit. Put the nut back on a different way for different discs. Check for a rim and indentation on one side of the nut and a flat side on the other. A visual inspection of the disc for the rotary grinder gives you information about the side to use.
  • Here is a diagram of your grinder and the tool you are looking for is number 50...
    http://www.ereplacementparts.com/images/dewalt/DW402_TYPE_6.pdf
    Jun 11, 2011 | Dewalt 4 1/2" Small Angle Grinder D28402
    I dont know how to change the wheel/blade on this DeWalt cut off tool/grinder! Help!
    If its a hand held grinder, on the back or the side of the grinder itself there is a button in which you must depress. While depressing it you must turn the wheel at the same time until it locks in place. You have to keep the button pressing to get it to lock.
    Once it locks into place, you need a spanner wrench to loosen up the nut (counterclock wise). If you have a grinding wheel on it, some just screw on without a nut. And if this is the case, then just grab a hold of the wheel by hand and turn it counterclock wise and it should come off.
    Make sure you unplug the tool before doing any of the above.
    Jun 01, 2011 | Garden
    Can't get nut off to change blade can I dissassemble from back?
    Probably not, Remember the nut is a reverse thread. Your best bet it to try some penetrating fluid or try tapping the nut with a screwdriver, hopefully the vibration will help loosen it. Another trick that sometimes works if the machine has a diamond blade or an abrasive wheel with some life left on it is to put on a pair of heavy duty work gloves. Lock the arbor and try to grab the wheel tight and try to spin the wheel loose with your hand. Don't forget to unplug the machine before attempting to remove the wheel.
    Oct 11, 2010 | Makita 9069 9" Angle Grinder
    I cannot remove the cutting wheel from my bosh angle grinder. Please advise as jammed very tight.
    I had the same problem and it cost me new gears in the end but I found a solution.
    Put the nut in a lathe and drill out the thread with a 14mm drill, then machine a recess of 0.5 x 52mm to get some extra clearance and machine a 2 x 42mm pocket for the SDS-click nut to fit in.
    I did this about 6 months ago and use it professionally and haven't needed the spanner yet, hardly ever needed the locking pin (mine has a brake) and it never came loose.
    Note: chisel marks were result of frustration to need to remove the nut.
    Jun 30, 2010 | Bosch Saws
    How do I lock up the axel on my bench grinder to retighten after replacing the wheels? Also what is the torque setting?
    Just put a wrench on the nut on the opposite side to hold the spindle. They will both tighten at the same time. Tighten them "snug". The threads are made so the nuts will self tighten or should I say will not come loose due to the way the wheels turn and pressure from use is applied.
    Dec 02, 2009 | Delta 23 - 725 8" Industrial Grinder
    I CAN'T LOCATE THE OWNERS MANAUL. NEED TO KNOW HOW TO LOCK THE DRIVE SHAFT ON A SEARS MOD. #21152 - 6'' BENCH GRINDER SO I CAN TIGHTEN THE NUTS THAT HOLD THE GRINDING WHEELS. TX MOE
    Below I included a link to the manual for your grinder.
    However it will tell you the same thing I'm going to tell you.
    Most bench top grinders do not come with a shaft lock. In order to loosen or tighten the retaining nut you need to place a small wooden wedge between the wheel and the metal wheel shroud. This will prevent the shaft from turning. This may seem archaic but it serves a good purpose by preventing the over-tightening of the retaining nut.
    Hope this helps.
    http://www.managemyhome.com//mmh/lis_pdf/OWNM/L0410111.pdf
    Oct 15, 2009 | Grinders
    I don't know how to change the grinding blade on my makita angle grinder.
    There is a nut that you release from the middle of the grinder wheel, (grinder blade)
    This nut is flat and has four holes in it.
    You will see you are providing a spanner wrench to remove this nut. The wrenches' actual name is Lock Nut Wrench. It has a U shaped end with two pins sticking out. On on each side of the U shape.
    The pins are inserted into the holes in the flat lock nut, located in the middle of the grinding wheel. The wrench is laid flat against the grinding wheel, with the two pins of the wrench going into any two holes of the nut.
    At the top of the Makita grinder you will see a Black button. The button is pushed down to keep the grinding wheel from spinning. Holds the grinding wheel in place, as you turn the lock nut loose. When you release the button, a spring inside pushes the button back up out of the way.
    As you view the Makita grinder, Release Button towards the Back, grinding wheel towards you, the nut is turned to the LEFT, to loosen. It is a Left threaded nut.
    The grinding wheel spins to the Right. Using a left threaded nut insures that the nut will stay tight, due to the direction the grinding wheel spins.
    Oct 01, 2009 | Makita Usa Inc 9557PB 4 1/2" Angle Grinder
    all grinders have wheel lock button located usuall on the front facing you... its black... press it and try turning the wheel... when you felt it is locked try turning the wheel.. manually... the bolt should loosen... dont 4get to unplug the unit first....
    Jul 19, 2009 | Saws
    Lock nut on Makita 9069 is stuck & I can't loosen it. Using the lock nut wrench, but it won't budge. Any suggestions?
    Make sure you are turning wrench and nut clockwise to remove nut and counterclock to put back on,you will never get nut off if turning counterclocwise,threads pitch is opposite to screw pitches.
    You are tightening and did not know it maybe???
    Other option:
    Need to put lock nut wrench in a vise jaw and clamp, then place tool on wrench and press down and turn. This should give you added leverage to break loose nut,and btw make sure to turn clockwise to unscrew and clockwise to tighten,this is opposite of what you might do to tighten or untighten
    Apr 09, 2009 | Makita 9069 9" Angle Grinder
    Open Questions:
    See all Black & Decker 7750 4 1/2'' Small Angle Grinder Questions
    Black & Decker 7750 4 1/2'' Small Angle Grinder Logo
    462 people viewed this question
    Top Black & Decker Saws Experts
    Jason
    Mike Carew
    Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
