Question about Watches
Relic doesn't run. TheFossil is missing the bezel.
Relic doesn't run. The Relic has an eight ball and flames in the backgroung which flash on and off, so I assume the battery is good. The Fossil has the crystal broken out.
    Problem Solver:
  • 16 Answers
There is a little tab next to the battery that should have an arrow pointing to it. You will have to depress the tab with a pin to get either the watch to start, or the eight ball and flames to start flashing, after replacing the battery. If this doesn't work, the watch is probably junk, as the movement has been damaged from the impact that broke the crystal. I have done this exact thing on this type of watch two years ago, which is how I know, except that the flashing image in the background was the chinese characters for love, peace, and happiness. It was also a Fossil Relic. Hope this helps. Bilal Hassan Clarksville, MD
Posted on Jun 03, 2009
Relic watch zr15478 adjust wristband
I'm having the same problem with this watch, I found this guide but it's for a similar watch and doesn't seem to help. I'm hoping this helps you more than it helped me
Oct 22, 2011 | Relic 0504648FA
What kind of batery need for relic zr 15490? i don't know because i lose my old batery.
mcdevito75 Here, Your in a spot, Looseing the old battery to your Mens Relic watch, you can look for a small watch repair shop in your area, they may have an idea of the battery number, but will most likely tell you they need the watch to know for sure. You can also try battery 364 or 371 but even I can"t be certain. You can also try online at Contact Relic Watches.com Reic should have a website. You may be left with only 1 choice, have the watch repair shop replace this battery for you, you"d have to buy and try a couple of different batteries and each battery in the store runs about $5.00 each, at the watch shop let the Jeweler figure out the battery number for your watch for 1 price. I think this is your cheapest and best option.
Feb 11, 2011 | Relic Dial ZR15528 Watch for Men
How do you get the bezel off of a tag heuer 4000 automatic, I have 2. The bezel on one is stuck from wearing on very dusty construction jobs, the bezel on the other turns but without clicking. Is there...
Yes, there are special spring under the bezel, not the bearings. Bezels are stuck/not clicking because they are broke/worn out or very dirty. I would not advise to take off bezels, unless you have replacement springs and proper tools to fit the bezels back on watch. You can find bezel springs on Ebay, or visit your closest watch repair shop and ask them to order springs for you. Rate me, plz.
Mar 27, 2010 | Tag Heuer Watches
Set the date on my new Relic watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all RELIC watch manuals.Rate me, please
Mar 22, 2010 | Relic watch
Does not run. does this watch have a battery in it?
There are two types power sources for watches. Automatic and battery.
Automatic needs to be either wound by the crown (winder on the side) or wound by the movement of the wrist while it is worn.
The battery powered is self explanatory.
Since you didn't include the model it's difficult to say for sure because Relic makes both automatics and battery powered watches. Although I can tell you is most automatics will clearly labeled. If your watch say automatic somewhere on the face or back you need to contact Relic for service because your watch has a 12 year warranty.
To prevent violating your warranty a jeweler should be the one who replaces the battery if it is battery power.
I included the link to Relic watches below for info on the warranty and instructions.
Hope this helps.
http://relicbrand.com/
Nov 13, 2009 | Relic Multifunction Watch
Some of the numbers on my relic pocket watch fell off.
Unfortunately you will not be able to get the watch glass off without braking it. Watch glasses usually are friction set or glued into the watch bezel using special press or special glue. Both are of such a good quality, that it is allmost impossible to remove the glass without special equipment.
You can try, of course, but it will be on your own risk.
The best way is to find your nearest watch repair shop and ask for help.
Do not forget to rate, please.
Feb 10, 2009 | Relic Degrade Pocket Watch
Resetting time on relic watches
Press and hold the Mode button - upper left. At first, it will display the stopwatch function. Keep holding until it goes to flashing alarm set mode. Once it starts flashing, release the button and then immediately press it again and release it (do not hold it the second time). Now you are in time set mode. You can change the time, starting with the seconds, by pressing Adjust - upper right. You can move to minutes, hours, day, and date by pressing Alarm - lower right. Pressing Mode again will exit the set function.
Jul 09, 2008 | Watches
Relic Watch Battery
http://www.apexbattery.com/relic-watch-battery-watch-batteries-relic-watch-batteries.html ... I've had 2 different sources take me to this same battery, although the Relic model I'm using is a ZR11586. "This battery is for ALL Relics," is what they keep saying.
Apr 22, 2008 | Watches
Relic watch with animated face
not unless you have the tools to soldier such small parts.
Feb 23, 2008 | Watches
Watches Logo
139 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
