When booting the system cannot find ''C:WindowsSystem32qtahmxbj.dll'' Where can I find the file? vernhunt@aol.com
  • 36 Answers
If the file just came up missing recently and you are using a OS that can go back in time (or has a system restore) simply go back to a time when u know your pc had that file.
I performed a google search for that DLL and had no hits. That DLL can be for a number of software. To find which, turn off 1 by 1 the software that starts up automatically on your pc until you no longer get the error message....or, see which one of the start up progs running on your pc is not loading and that will tell you what software you need to remove and reinstall in order to fix the problem (or u can find the cd,explore it and drag and drop that dll into the specified system32 folder where the file was originally located).
Which ever case, without knowing what program that dll belongs to we cannot direct you to where that file may be on your HDD.
Posted on Jun 03, 2009
Notebook says that windows could not start because the following file is missing or corrupt <windows root>/system32/hal.dll.
Causes of the missing or corrupt hal.dll error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
To fix it:
1) Restart your PC, sometimes the hall.dll error could be an error itself and your PC should boot up fine.
2) Go into the BIOS by pressing the Delete key as the laptop boots. Then navigate to disk boot priority and make sure this is set to your main hard drive (the one that has Windows installed on it). Save and exit the BIOS. Sometimes if you have a USB flash drive/Pen drive or external hard drive it may automatically switch the boot priority to that.
If these two quick steps don't fix the problem then head over to here and continue reading up about repairing the boot.ini file.
Mar 10, 2011 | NEC PKM35-4A33 Buzzer (802870018009A) PC...
Unable bootup & error prompt that HAL.dll file missing or corrupt
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
Resolution
  1. Restart the PC. The hal.dll error could be a fluke.
  2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
    Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
  3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
  4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
    Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Nov 09, 2010 | Acer Aspire 4720 Notebook
The file <windows root>\system32\hal.dll.
Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Feb 15, 2010 | Dell Latitude E5500 Laptop
Hal.dll file missing or corrupted
Follow the steps given in the link below to troubleshoot the hal.dll missing issue:
http://support.microsoft.com/kb/945380
Aug 26, 2009 | Microsoft Windows XP Home Edition with...
Install missing dll file
Dear
If u have missing .dll file (download from web)
copy .dll file to c:\windows\system32
go to run and type (if ur dll file is abc.dll)
regsvr32 abc.dll
and press enter n ok
Oct 19, 2008 | Computers & Internet
I have dual boot 98SE/XP-Pro in same disk partition which got virus attack. In order to fix problem (long story), I had to remove and re-install the XP-Pro OS. Unfortunately I deleted the XP system from...
Why would you torture yourself with that old thing?  Yeah, you can create more boot script lines...they should designate the proper root for the second volume and that ought to fix any missing file issues if indeed ICG32.dll and company are where they started....
Jul 22, 2008 | Computers & Internet
Winxp cannot boot - missing files message
Just make sure you get these files on your computer.
Download hal.dll from here:
http://www.dll-files.com/dllindex/dll-files.shtml?hal
Place it in windows\system32 folder.
Now go to the drive you have windows installed in (C:/ for example), and then create a new file, name it boot.ini.
Open boot.ini with notepad, and enter this:
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS /usepmtimer
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Save boot.ini now, and try booting your computer, it should work.
Nov 17, 2007 | Computers & Internet
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
