Question about Furuno FCV-582L GPS Receiver
Furuno fcv 295 fishfinder
Please give me the details or drawing to enable me to connect the transducer B260 50/200khz 1kw with temp. made by airmar.
PLEASE NOTE THAT MY FURUNO IS THE NEW FCV 295 AND NOT THE FCV 582L AS STATED BELOW.
  • pherodotou Jun 03, 2009
    my furuno is a the model fcv295 not fcv582l. please note my transducer is 50/200khz 1kw . do you have any installation wiring chart?
    Sergeant:
    Champion:
  • 214 Answers
First installation:
Tru-hull on the mounting location behind the battery plate. Due to a erratic cut from the mechanic (he cutted the fairy block the wrong way and he had to cut it anothe time) the transducer came out of the hull too less (maybe 2 inch). This caused no readings over 6 knots due to turbulence from the strake beneath .
Second installation:
Due to unknown reasons i lost the pizo underway in full working season so i had to find a quick solution.
I made a L-shaped mounting plate from inox and bolt it to the stern between my 2 motors in the center of the keel.
Only the fairy block with the transducer in it is 1 inch below the bottom of the keel.
This installation works great and reads up to 130 feet @ 25 knots, faster there are to much disturbs on the screen.
The first installation tru-hull on the mentioned location should work, but you have to take care that the fairy block
is cutted minimal the right inclination and the right way (larger side to bow). So it came off the turbulences from the strake and it should work fine.
If you have 2 outboards, the mounting between the motors works very well and you don't have to drill a large hole to the hull for the tru-hull installation.
Posted on Jun 04, 2009
    Brigadier General:
  • 3,614 Answers
You may choose any two frequencies between 28 and 200 kHz to fit your fishing operation. Output power is selectable from 1, 2 or 3 kW.
Hope this initial info helps.
Let me know.
Posted on Jun 03, 2009
WHAT TRANSDUCE GOES WITH THE DS600X COLOR ..WHERE CAN I BUY ?
Hi
Airmar makes almost all of the transducers for Raymarine. From the Airmar FAQ section, your unit is listed. See the link below. Pretty much any marine chandler or Raymarine dealer should be able to order it for you.
Hope this helps
-Steve
Airmar FAQ What Airmar transducers are compatible with the Raymarine...
Feb 26, 2015 | Raymarine Ds600x Digital Fishfinder With...
I have a furuno FCV295 and when I was doing the initial installation set up of the transducer (airmar r299) I accidently chose the wrong settings. How do I re-do the transducer settings? The factory reset...
If you reset it and while in the Initial Settings" Menu, you press menu, it should take you to the transducer setup screen. These menus allow for "Transducer Type" to be changed to your exact transducer. See the "Installation Manual", which is different than the "Operators Manual". Section 3 page 9 and 10. You may have to enter your units of measure (Knots vs MPH, etc), and then it will allow you to choose the transducer type. Hope this helps. John Barry, 847-746-0100, technicalmarine.com.
Jun 19, 2011 | Furuno FCV 295 104" Fish Finder
How do you get the Furuno FCV 295 out of demo mode?
go to the ' menu ' page -- scroll down to ' simulator ' -- and choose simulator OFF.
the unit should work fine after that.
fish on (!!!)
c...
Feb 02, 2011 | Furuno FCV 295 104" Fish Finder
INSTALLATION MANUAL FURUNO FCV-585 BEST GROUND FOR THE UNIT SHOULD I GROUND IT TO ENGINE OR BELLHOUSING OF OUTDRIVE
Attach to engine grounding point with battery cable. Add a grounding plate for RF (green) ground.
May 03, 2010 | Furuno Fcv 585 Color Fishfinder
GP700F Airmar P66 to TM260
you must run 50KHz for deep water, so you will have to solve the interference problem to benefit from the power
Oct 12, 2009 | Furuno GP7000F/NT GPS Receiver
LLOKING TO BUY A REPLACEMNET TRANSDUCER FOR A FURUNO FCV-582L
Yes, the current model of this is the FCV 585 and it is great. The transducer will need to be changed.
Apr 07, 2009 | Furuno FCV-582L GPS Receiver
I have a furuno fcv 585 echo sounder with a FURUNO CA50/200-12M -c13298 BRONZE THRU HULL HIGH PERFORMANCE TRANSDUCER. The transducer has 4 wires and it looks from the schematic that it attaches via a...
you need an MB1100 matching box has the 10 pin pigtail for your sounder and accepts bare wire input from your ducer
this will also ensure that all power from sonar get to ducer, but it from me if you like 847-746-0100
Jul 09, 2008 | Furuno FCV-582L GPS Receiver
Installation furuno GP7000F/NT
This unit has built in sonar, so no DFF1 is required. The 1KW transom mount is in stock here, with the proper Furuno 10 pin connector. That is all you need, the display, the power cord, the GPS antenna, the transducer and THE BOOK! We are a Furuno dealer in the Great Lakes
Mar 03, 2008 | Furuno GP7000F/NT GPS Receiver
Furuno FCV-582L GPS Receiver Logo
258 people viewed this question
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
