Question about Balance CM2017 17" Monitor
Power Source Monitor
I have found that my power source has gone out.  Where can I find one?
  • 80 Answers
You can get another power supply at any of the computer retail stores for $40-$50. Pls take you comp's power source to the store as they come in different sizes and not all fit your comp.
Posted on Feb 04, 2008
Lcd blank
Here is few question you might want to ask yourself:
Have you try the monitor on another source?
So if it work, what is the resolution the source was set at?
Can you try another video on the source that does not work and compare the resolution?
If the monitor does not work with another source then internal part is failling. inverter for neon lamp most of the time but the power light would lite up. if the power light does not light upe then it is internal power supply. Check the power cable, external power supply, the internal and external power plug (you might want to replace the cable for a test or the power supply if external)
hope this help you.
Jan 04, 2014 | BenQ Computers & Internet
FLATRON W2061 TQ will not turn on.
Yes! it is most likely one or two capacitors that are open in the power supply, and they sometimes show a bulge at the top and leak contents in rare cases.
Apr 23, 2012 | Computers & Internet
My monitor measures18.5 inches across and 11.5 inches high. I don't knoe what model it is. After I turn on my monitor for a while the image turns fuzzy. I have tried to reset the image and...
I searched around on the web and found somebody mentioning the power source. I live in south Florida and we do get power surges almost daily. It seemed too good to be true but I decided to try it so I unplugged my monitor from my surge protector and plugged it into another outlet and BAM!!!!!! Crystal clear and like brand new!
It must have been the surge protector.
So if you have a fuzzy monitor one thing you CAN TRY is to change the power source or outlet. It worked for me and saved me a few hundred dollars.
May 27, 2011 | ViewSonic VA1912wb Monitor
My monitor has gone blue, what do I do
Assuming the monitor is powered (if unsure, check the that power cord is connected to a live 120 volt source and the other end is connected to the monitor), check the data (analog VGA or DVI) cable between the monitor and the computer. Make sure the connectors are firmly seated in the respective jacks, and held in place with the retaining screws where provided.
If all four connections (power in and out and the data in and out) are satisfactory, check your monitor's input "source" selection. This may be selectable via dedicated "Source" button on the monitor or from the monitor's "Menu".
When changing the source input types with the button, it will usually take a couple of seconds before an image will display, so allow enough time for the monitor to respond to the change. If changing via menu selection, it may not change until saved or exiting.
If the monitor refuses to display, it may be an issue with your video card. In this case you could try swapping the video card or the monitor to determine which is the culprit.
I hope you found this Very Helpful and good luck!
Nov 17, 2009 | LG W1934S-BN 19" Monitor
No power even thougth power source is OK? No
If you know the power source is good then it's either a fuse, the cable itself or the power supply for the monitor.
Oct 25, 2009 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Computers has power but will not turn on monitor,fans on blue light on, yellow light constant. cd slide opens and closes normal.
First the obvious, monitor is on? Cables are connected securely to back of monitor and PC? Power cable/power adapter are all connected and plugged in? If a power adapter is used, it will feel warm.
I am assuming it was working on some point and then stopped.
If you are getting power to monitor and it's power light is on, then I'd suggest a problem with the video output on PC
If you are not getting power to monitor or it's light is not on, the problem is with the monitor.It may have gone out on you. Try attaching to another computer.
Oct 05, 2009 | E-Machines T6528 PC Desktop
I have a FPD 1830 flat screen monitor not displaying picture
Send the monitor. It's a power supply problem. My 15.4" LCD has the problem, too, whenever I move the monitor down, it powers off, and the menu disappears as well, but I'm going to fix the screen.
Jul 08, 2009 | Gateway Computers & Internet
Having a problem with my monitor
9 times out of 10, the vertical output IC I501 ( TDA1675 )and resistor R574 (1 ohm, 1 watt) are bad...The resistor opens up because Vert. IC has gone bad. IC doesn't get 30 volts from the power supply, hence , no vertical sweep....
Don Kirsch Questar III BOCES
Mar 18, 2007 | Princeton Digital Arcadia AR2.7AV 29...
Open Questions:
See all Balance CM2017 17" Monitor Questions
Balance CM2017 17" Monitor Logo
67 people viewed this question
Top Balance Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
