Question about Hobart Welders Champion 500433A Factory Reconditioned 10,000 Watt Generator
Arc start board
Howdy,
Where do I get a flyback transformer for a Hobart Cyber tig III CT-150-DC Board #200427 102 Rev. 3? Thanx
    Scholar:
  • 148 Answers
At your nearest Miller distributor (almost all gaz reseller)
Posted on Aug 08, 2009
What polarity do I use for tig welding aluminum, and what color electrode for miller hf-p dial arc
Jackie, watch the linked videos on tigging aluminum. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 31, 2016 | Miller Welding Tools
I have a mishto 220 mig tig mma I can get the arc to work fine but the mig there's no arc at all the machine sounds like its welding but no arc at the gun I'm using gassless wire I thought it may be an...
They told me at welding school the mig transformer has a different slope (whatever that means?) to the tig and mma transformer so I am a little surprised at your question. The implication is two transformer are needed for the three types of welding and for tig and mig a dc converter and also for dc mma welding.
From your description it seems as though welding current is not arriving at the tip of the mig torch or the current is arriving in the wrong form.
You say the mma is fine but you didn't say whether it is fine on ac welding, dc welding or both. I have not tried mig welding with ac and have no idea whether it would be successful but I imagine a lot of sparks and not much welding. The problem could be the rectifier unit is either not working or is switched out of the circuit.
Polarity is important too with dc tig and mig welding.
I hope this provides food for thought.
Feb 04, 2015 | Welding Tools
The settings for welding aluminium using a Tig200P AC/DC inverter
If you are using a remote then you would set the machine in standard for controlling output and also to AC output, HF tig, contactor and control in remote position. I don't know if this helps or not but I pulled it from an owners manual.
1/16" (.062) - pre-flow .1 sec., hot start 20, amperage 70, Hz 100, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 100, background current 30, Hz 1.0
1/8" (.125) - pre-flow .1 sec., hot start 20, amperage 150, Hz 80, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 150, background current 50, Hz 1.0
3/16"-1/4" - pre-flow .1 sec., hot start 20, amperage 185, Hz 60, balance 20%, post-flow 8.0 sec.
For pulse settings - set pulse width 60%, peak current 185, Background current 125, Hz 1.0
Mar 14, 2014 | ARC Thermadyne Inverter Stick/TIG Welder...
Is there a diagram online that can show me where the CP114,120, and 150 are located on my RCA M#D52W20
The are tan and next to the flyback and are marked with location numbers right on the board. On that board if one is open (read like a fuse) the set will no longer display the convergence option--there is a kit with 3 parts available for this.
In case you get that board out this model is prone to bad or broken solder connections at the flyback and around it.
Photo of typical flyback transformer:
Oct 30, 2012 | RCA Televison & Video
No Hf start on messer grieshiem ac/dc tig 150
never heard of this as i always strike a arc ,its comes with experiance and you do not even know your doing it .But this could be a new idea that i havent come across on my old machine
Dec 10, 2011 | Welding Tools
Im welding 16ga sheet metal, with short little beeds. i will lay a 1 inch bead and stop and go to start another one i step on the pedal and there is nothen i have to wait for the machine to cycle....
Is it waiting to finish the post-flow cycle before allowing you to start the arc again? If so I'd return it with all speed because it's going to cost you much in time and gas both.
If you can't return it, are you capable of modifying it? If not, try breaking the arc and just starting the next without letting the pedal up fully.
lp
Nov 15, 2010 | Hobart EZ TIG 165i InverterBased Welder ...
My Lincoln SA 200 welder will not rev up when I strike an arc.
Need code number to be exact, but sounds like the wiring to the current transformer is incorrect.
Sep 17, 2009 | Lincoln Welding Tools
Not generating power
The engine is not running the welding transformer. It may be a fuse, drive belt or gear wheel. Or the transformer is shorting out. Check these points in this order if the last one maybe you will have to replace the transformer. The transformer is 2 coils to stop them shorting out where normal electric wire is cover in plastic or rubber the coils are coated with enamel as are sum cooking pans. If this is damaged in any way it will short.
Apr 08, 2009 | Hobart Welders 500433 Champion? 10,000...
Need transformer for Hobart Cybertig CT300
Hi Steve
my name is Rob
The cyber tig brand covers a lot of ground some of it older than me!
critical questions
do you have a parts list?
can you get from the machine
Model number
Spec number
do you have any drawings?
if these are all no all is not lost.
I can get a transformer custom made. i would need some details from the old unit.
Please let me know.
Regards
Rob Lee
Jan 29, 2009 | Hobart Welders Champion 500433A Factory...
Hobart Welders Champion 500433A Factory Reconditioned 10,000 Watt Generator Logo
210 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Troy
Troy
Level 1 Expert
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
