Question about Dryers
Lg td-c70045e electric dryer power on but not turning
When you switch on power ok but dryer does not turn making noise like wants to turn but doesn't happen
  • lilboy Dec 23, 2007
    electric power is on but turns on for a short time then cuts off
  • Jerf Jan 06, 2008
    HEELLP! It is storming like mad so I can't use my clothes line and my T731 Asko dryer is sick. The power is on, it makes a buzzing sound, but the drum won't turn. It begins turning when given a hand, literally. I started it by hand by pushing on the outside of the drum and it began spinning. I purchased and installed 2 new rollers and a new belt, to no avail. My next choice is to call the repair guy Asko recommended. $100 already spent, now ....?
I had the same problem. Replaced the capacitor and now all is ok. Dryer is working 100%. If you hear a humming sound from the motor then it means the capcitor is faulty and does not start the motor properly.
Posted on Jan 10, 2009
LG TD-C70040E Automatic Clothes Dryer. The diver closes the cover and forces it to work and makes noises
call a good repair service locally,perhaps they will understand what you say
Apr 21, 2018 | LG Dryers
Makes a humming noise but doesn't turn
Try this, open the dryer door and hold down the door light switch. Turn on the dryer and press start.When you hear the motor humming, turn the drum clockwise with your hand to see if it will turn. If itruns, you have a bad motor and will need to be replaced. If it doesn't turn, something is jammedinside and you will need to disassemble the unit to find the jam.
Hope this helps.
Oct 31, 2011 | LG DLE2514 Electric Dryer
Water doesn't go to water tank. Any advice? thanks a lot Peter. LG DRYER TD-C70045E
Try unscrewing the water hoses and cleaning or replacing the filter screens where they screw into the unit and also the valves.
Aug 28, 2011 | LG Dryers
Tumble dryer TD 4112 W has power but drum does not turn - light is on and it makes humming noise but won't start.
hello the first thing to check is. the long pin on the inside of the door these sometimes snap off . if ok then check to see if the belt has come or snaped if ok then you may need to check the capacitor this next to the motor will have 2 wires coming off it these dry up good luck
regards
shaun
Jan 17, 2010 | Zanussi TD4112W Electric Dryer
LG TD C70045E dryer not heating up, this has happened before and the guy just pressed a switch but cant remember where it located, please help!
On the LG TD-C70045E the reset button for the heater is located inside the back air-way cover. This is easy enough to remove and the button is obvious once the cover is off. The button will 'click' satisfyingly if it has tripped. Don't forget to switch off and unlug first...
Aug 22, 2009 | Dryers
LG TD C70045E problem
Fluff has blocked the drain hole into the water drawer.Try locating the hole and using a small bore plastic tube **** the debris out of the container.
Feb 21, 2009 | Zanussi TC7102W Electric Dryer
Clean filter light stays on LG TD-C70045E Dryer
I had the same problem. It actually has nothing to do with the filters. If your dryer sounds like it wants to start the capacitor is blown.
Dec 07, 2008 | Zanussi TC7102W Electric Dryer
LG TD-C70045E Condensing Dryer does not heat up, how do I fix it? All other controlls work fine just no heat.
if not turn the power off and pull the dryer out and take the back off and push the red button in at the back
Aug 17, 2008 | LG Dryers
Dryers Logo
456 people viewed this question
Top Dryers Experts
