The unit has 2 alarms (alarm 1 and 2). They can be used
together or independently. Alarms 1 and 2 have different
sounds so that you can differentiate them. The alarm will
sound for 1 minute unless it is disabled.
To set the alarm:
Navigate to "Set Alarm" setting mode as shown in the
Changing Settings section. The order of the settings is;
alarm 1 or 2, hour and minute.
To enable or disable the alarm:
• Press MENU until you reach alarm 1 or 2 display.
• Press [UP] or [DOWN] button to enable or disable the
alarm. "-:--" means disabled.
OK.
The car alarm on your 2000 Windstar minivan
is wired into your van's battery. When you are making a repair to your
car such as a battery change out your alarm can go off. You can easily
disable the Windstar's car alarm by disconnecting the battery from the
alarm. The battery is connected to the Windstar battery's negative
terminal. Disconnecting the terminal from the battery will disable the
alarm.
