Question about Nokia Consumer Headset
My micro SD meory Card got lock i want to unlock it but i dnthave card reader
Dear Sir,
I have Nokia 5310 xpressMusic phone with two GB micro SD memory Card, which has locked. please unlock the same at your earliest.
Yours sincerely,
Customer
Posted on Jun 16, 2009
Memory card locked
SD and Micro SD memory cards SD and Micro SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts. ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Oct 19, 2012 | Nikon D3000 Digital Camera
Micro sd memory card for 3110c password protected was forgotten
connect ur memory card, to the comp. through card reader,, then format it,,, lock will be opend
Jan 09, 2010 | Nokia 3110 Cellular Phone
Memory card won't unlock
First I know you've said you've checked the card's slide switch, but just want to restate this first for others with the same problem who may not know of this switch.
Check to make sure that you didn't accidentally place the tiny locking slide switch on the side of your SD card in the "locked" downward position. The correct "unlocked" position should be slid up toward the direction of the connectors.
If you've tried this, and it's still showing locked, it's likely that the locking switch inside the camera's card slot is stuck. If you look inside the slot on the side of the slot where the SD card slide switch would be, you'll see a glint of gold color on the side. This is the camera's lock/unlock switch. The other glint's of gold that you may see at the far end of the slot are the reader's connectors (ignore those).
Somehow, the locking switch is making contact and has become stuck in the locked position. With a plastic toothpick, or other skinny NON-METALLIC item, tap against this switch to see if you can jar open the contact to its normal unlocked position. Also try blowing compressed air at it, as some gunk may have worked its way in there, jamming it closed. Occasionally, reinsert the SD card to see if the issue has been corrected.
If repeated tries fail, it may be time to consider opening the camera to force open this switch (not recommended unless you have some familiarity with electronics). In this case please see the following (xscrewdriver, hope you don't mind me referencing your blog):
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
Jun 22, 2009 | Casio Exilim EX-S600 Digital Camera
I ve bought a new meory micro sd 4Gb card for my
Be careful, if you use the USB cord to plug the phone up make sure that your not formatting the entire phone.
Did the Micro SD card come with the bigger card to plug it into making it a standard size SD card ? If so then you can plug that into a card reader if you have one go into MY Computer, and right click on the drive of the SD card click format.
Those are the only other ways of solving said problem if you can't do so on the phone itself. Also the phone may not accept a memory card of such size.
Mar 17, 2009 | Samsung Cell Phones
I want to unlock micro sd card in nok 5200
U CAN TRY TO USE THE UNLOCKER SOFTWARE, SEARH FROM GOOGLE.IS A WINDOWS SOFTWARE.AND PUT YOUR MICRO TO THE READER, RIGHT CLICK N UNLOCK MOVE TO OTHER FOLDER.
Dec 27, 2008 | Nokia 3110 Cellular Phone
Unlock 1 GB micro sd memory card of Kingston Made
check the adapter maybe its switched to locked mode sanjan
Aug 17, 2008 | Nokia 5300 Grey Cellular Phone
hi this is Aravind , i'm having 1 GB micro sd memory card for my mobile nokia 6233 ..... and it is password protected ... bit actually i have forgotton the password and now i'm using another phone ... in other phone the memory card is not openinng its asking for password .... i have tried also by connecting the data cable but in nokia pc suite its showing that there is no memory card ...., i had also tried thru card reader's but its not opening ./... is there any solution to unlock this card without losing the data in memory card ... plz help me out ........
i have microsd card 1gb card of kingston. it is locked & i want to unlock my memory card without losing my data. so pls send me tips for unlock the meemory card
i forgot my password...pls help me unlocked it without losing my files n data... i forgot the password of my micro sd memory card 1 gb , i don't bother about data, how to open , pl explain.
Jul 19, 2008 | Nokia N95 Cellular Phone
my memory card is locked .i use a nokia 3110c model. please give me the solution
Jul 15, 2008 | Nokia 3110 Cellular Phone
Lock memory card in nokia 3110C
Use memory card unlocker. Its a small device like card reader. You can unlock your card with that.
May 15, 2008 | Nokia 3110 Cellular Phone
Nokia Consumer Headset Logo
152 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
Computer Repairing
Computer Repairing
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
