2007 Dodge Caliber SXT Sport Hatchback Logo
Diane Nielson Posted on Jan 27, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The moonroof cover was fore closed while moon roof was open and now makes noise and leaks
Driving down the road with the moonroof open, hubby forcefully closed the interior cover. now it clacks loudly when open and we have had water in back feet wells.
RJ motortech auto repair
Level 2:
Habit-Forming:
New Friend:
  • Expert 75 Answers
  • Posted on Jan 28, 2014
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
75
Questions
0
Helped
20931
Points
172
It sounds like something that is broken inside ,u might need a new moon roof track complete unit
  • Diane Nielson
    Diane Nielson Jan 28, 2014
    is this very expensive?
  • its dealer item.give them the vin number of the car.they can tell u
3answers
2005 Lincoln Aviator Moon Roof is stuck
Check the connections to the motor for the moon roof. It's most likely that the motor has gone out, and will need to be replaced.
2answers
How to fix or reprogram moonroof on 1999 lexus rx 300 ?
Hi Pamellaa
to reprogram the sunroof do this procedure
25732098-qvcgwchcflmhgyws4rkx4jkj-2-3.jpg Good luck
2answers
Sunroof stuck open, think the switch maybe bad
I have same problem. Below are a couple of suggestions from LincolnOnLine.com on how to close the sunroof manually. The first relates to a '93 and I'm not sure about the second. Use this info at your own risk. If you get a better answer, PLEASE POST IT HERE FOR ME. Thanks. Mort
Here is the text from my 93 Manual. There is an access panel in the rear centre of the headliner if it is the same as my 93.
Manual Operation
To close the sliding panel manually, remove the roof access hole trim panel located at the rear of the moon roof assembly. Remove the motor and bracket assembly as outlined to expose the splined shaft of the moon roof drive gear box. Using a typical corporate door window regulator crank handle properly set on the splined shaft, crank the moon roof panel closed.
Motor
CAUTION:
It is recommended that the battery ground cable be disconnected when removing or installing the moon roof motor assembly.
Removal and Installation
1. Operate glass panel until rear of glass panel is flush with sheet metal surface.
2. Remove motor access cover.
3. Remove two motor retaining screws.
4. Lower motor away from splined motor gear and disconnect electrical connector.
5. To install, reverse Removal procedure and synchronize motor as outlined under Adjustments.
Good Luck! __________________
Current:<P>1995 Town Car Executive 80K Miles<BR>1990 Mustang LX 2.3 Auto 62K<BR>1985 Chevrolet Caprice Estate Wagon X 2 (160K & 100K)<BR>1983 Chevrolet Caprice Sedan<BR>1984 Renault Turbo Fuego 60K<P>Past<BR> <BR>1980 Oldsmobile Cutlass<BR>1980 Chevrolet Citation<BR>1974 Triumph Spitfire<BR>1968 Triumph Spitfire<BR>1957 MGA<BR>1966 Renault R8<BR>1966 Renault R10<BR>1974 Chevrolet Malibu<BR>1968 Pontiac Firebird<BR>1966 Honda S600 Converible w Hardtop<BR>1978 Bobcat<BR>1969 Buick Last edited by Thanet; January 8th, 2007 at 07:07 PM. #3 post_old.gif January 8th, 2007, 07:26 PM Bill M. user_offline.gif Registered User Join Date: January 8th, 2007 Location: Boston, MA Posts: 3 reputation_pos.gif Moonroof Woes Thanks for the moonroof help. I might be getting a switch in the a.m. If not that remedy doesn't sound too bad. Bill M. #4 post_old.gif January 8th, 2007, 09:49 PM image.php?u=18244&dateline=1141618175 Tman70 user_offline.gif Moderator Join Date: July 26th, 2004 Location: New York Posts: 2,757 reputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_pos.gif 1. Remove the roof headlining access hole cover located at the rear of the roof headlining.
2. Remove the sliding roof panel motor as outlined to expose the splined shaft of the sliding roof rail and guide.
3. Crank theroof sliding outer glass panel closed using a typical corporate door window regulator crank handle properly set on the splined shaft.
4. After performing these operations, remove crank handle and retime as outlined. Refer to «Adjustments, Motor Synchronization (Timing)» .
5. Install the sliding roof panel motor.
6. Tighten to 4-6 N-m (36-53 lb-in) and install roof headlining access hole cover. __________________
2helpful
....with a power moonroof, the moonroof is now
use the manual override and close the roof glass...
15helpful
3answers
How do i close a moonroof that is not working? 1995 camry
there is usually a manual turn hidden somewhere on the inside roof. Find it and turn it with a wrench/screwdriver. Hope this helps :-)
2helpful
I opened my moonroof on my 1995 Honda Civic EX and now, when I push the button to close it, I hear the system revving, trying to close it, but it won't close.
Either it' has not been used in some time and needs to be cleaned and lubricated or the motor for the moon roof is gone .....you can also check the side of the moon roofs motor to see if you can turn it up some to make it go faster ....hope it helps you out ...if not ...change the moon roofs motor
1helpful
Moon roof is not closing properly
you are having a problem with either your power switch which opens and closes the moonroof. or either you may in fact have a motor problem with moonroof. check to see if you may have an electrical short in your system. also you also may have something wrong with your moonroof sliding armature.
Leaking moon roof
long as the seals are ok, is it factory fitted? you will get different stories from different people all MoonRoof's leak electric . thats why they have the drains just make sure there not blocked..... long as it's not coming in car your fine
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
