Question about Whirlpool Dryers
Dryer runs, but does not heat. Checked all breakers. Took of back to check heating element-can't see it to tell if that's the problem.
  • 97 Answers
Hello Friend, Your problem is very simple to fix. You need a thermal fuse, very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Your dryer will run like new. Happy to help, Tim.
Posted on Jun 24, 2009
5 Suggested Answers
bcroydon
  • 9 Answers
SOURCE: runs but no heat
If you are sure the element is fine use a multi meter to be sure you have continuity from the element back to the timer there could be a thermal fuse. Be sure you have 120V and 240 volt at the plug. If there is a seperate heat setting switch check continuty there. If all is good there chances are it is the timer itself. Normally the dials inside will wear and they will no longer push contact on the micro switch to turn on the element. You can test this with continuity by going from the power into the timer and to the element, have someone spin the timer by hand. You may find it jump when the odd contact is made but it will likley not be consistant. Some timers can be pulled apart and a tiny glob of epoxy on the right contact point will extend the life of the timer by a few years.
Posted on Jan 03, 2008
onthejob5130
  • 640 Answers
SOURCE: Kenmore Dryer won't heat
ok you moving in right direction but you jumped a step,,you already checked the thermal cut offf and the operating thermostat,,those where the two on the side of the heater housing,,you should have checked the thermal fuse and the thermistor,,they are on top of the blower wheel housing tuck a lttle to the left,,since you seem that you know what your doing just jump them out starting with the thermal fuse,,,keep me posted on the job
Posted on Jan 10, 2009
jsrock516
  • 5911 Answers
SOURCE: DRYER RUNS BUT NO HEAT
The following link explains how to troubleshoot a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Most dryer heat related problems are caused by clogged, or poorly installed vent ducting. Cleaning the lint trap is not nearly enough to maintain a dryer in proper condition. This actually causes the heating circuits to overheat to the point of failure. In the majority of the cases, the THERMAL CUT-OUT (TCO) is the components that fails first. This component is designed to trip like a fuse in an overheat condition. Once tripped, it cannot be reset and must be replaced. If your heating element was defective, then you may have more than just the element at fault. Read through the link I provided and see if you may have additonal problems. NOTE: If the TCO is defective, it is recommended that you replace the hi-limit thermostat at the same time. In many cases these components are sold as a set. Failure to replace them at the same time can lead to premature failure of any components you have replaced. Both components will be mounted on or near the heat box that the element is encased in. If you have questions along the way, please let me know. I hope this helps you.
Posted on May 03, 2009
heatman101
  • 43501 Answers
SOURCE: Whirlpool Dryer LEB6200KQ0 -
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Jul 14, 2011
Why won't it start?
check for the operation of a small micro switch at the door hinge
if that is out of adjustment then the unit will not start
Jan 05, 2016 | Bosch Dryers
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
Dec 30, 2015 | Roper REX3614KW Electric Dryer
Will not heat up
Basic instruction
Turn circuit breaker off thit can be checked for en back on, check dryer for heat.
If still no heat, (I am assuming that the dryer runs) There is a high temperature cut out on the heating element, it can be checked for continuity. the Heating element can also be checked. If this dose not help. I would need the brand and model number.
You should check the vent and make sure it is clear, I have had a lot of dryers that blow the fuse because of clogged vents.
Jun 20, 2015 | Dryers
Dryer runs but there is not heat, heating coil has been checked and it is fine. What is the next troubleshooting step to check it out?
hello zack... Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. I know you indicated that the Heating element was checked but here is how you do it. Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Apr 24, 2011 | Whirlpool TEDX640PQ Dryer
No heat but element does not look bad
check breaker box in house.....make sure both dryer breakers are in the on possition...if only one is on there is only 110 instead of 220
Nov 17, 2009 | Vehicle Parts & Accessories
Whirlpool electric dryer that will not heat up, dryer comes on and turns, but no heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 18, 2009 | Whirlpool Dryers
LG Front loader Electric Dryer want heat but will run and spin
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
This link will show teardown illustrations: Parts and more help available on other pages of the website.
http://www.repairclinic.com/0100_16.asp
Hope this helps.
Illeagle
Aug 27, 2008 | LG DLE2532W Electric Dryer
Kenmore Elite dryer
Heating element
Thermal fuse
Wiring
Hope this may help;
Rgards,
VOTIT
DON'T FORGET TO RATE;
Aug 25, 2008 | Kenmore 63942 Dryer
No heat from dryer
is it 220 volt dryer,if so check the plug at the wall and make sure you have 220,the plug runs off 2 circuit breakers at your electric panel,1 breaker may be no good so your only getting 110 volts to the dryer which will run the dryer but not the heating element
Jul 08, 2008 | Dryers
My dryer won'y blow hot air
bpaul...first, check to see if you have full power to the unit. These units run on 220 volts which involves two breakers linked together...my guess is one popped and you're running on 110. You'll get some functions but not full heat. Turn the breakers off and back on. Not it? Then check for lint in the piping which is causing a false reading on your temp sensor.
Dec 17, 2007 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
49 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
