Question about Xerox Phaser 4500 Printer
Margins and warning window
A client of ours has problems with the margin settings which are fixable with time consuming trouble shooting; but every time she prints a document a window pops up claiming marginal errors in section one, and we don't know how to resolve this.
  • conradcott Jun 03, 2009
    She seems to only print from word, it's set to letter along with your other suggestions and no one else in her office has problems. Also she works in a legal office and the margin settings vary from time to time, and can't have default margin settings. We're not sure why the error window appears every time... Thanks for the help!
    That didn't seem to work either we're tried to direct and repair word but that didn't work either.
    Thanks for the help though.
    Scholar:
  • 52 Answers
First i would try to narrow to problem to easier find the issue. Is this happening on all software or only with a particular one? Try with word, outlook, notepad etc. and see how it goes. Try also to set the printer to print only one format (like letter or legal) then setup the software to print only that same size of document... then setup the windows printer to do about the same. Do not forget to change the default print settings in there also. If everything is standard and all paper sizes and types are correct on computer/software printer setup and on the printer itself... then it could be a program/document error. You can aslo try to create a PDF with it and print the PDF to see if it's printing.
Posted on Jun 03, 2009
  • Martin Metivier
    Martin Metivier Jun 03, 2009
    Ok so if it's only in Microsoft Word, then i would try to replace the normal.dot document with the default one.
    Many errors in Word come from the normal.dot file. It may solve your problem.
    First you have to use the show hidden files option in windows explorer to get there.
    Go to C:\Documents and Settings\"profile name"\Application Data\Microsoft\Templates
    Then delete the normal.dot file (Word has to be closed) or rename it. The next time Word starts, it's gonna create this file again.
KXR00 I have a panasonic elfec electronic typewriter r200 and I don't have a manual. I am having trouble setting the Left & Right Margins Regaards Lesley
I have a manual...
To clear margins and have do the following: depress the "return" key so the carriage returns to the left margin. Then depressed the "code" "tab clr" keys.
To set margins and tad do the following: clear your margins in tabs using the steps above. Depressed space bar until you reach the desired left margin. Depressed the "L. MAR" key... you're left margin is now set. Depress the "space bar" until you reach the first required tab stop. Depressed the "tab set" key... your first tab stop is now set. Repeat steps 4and 5 for each tab stop required on the writing line up 13 can be set on each line. Depress the spacebar to move the carriage to the desired right margin. Depressed the "r. mar" key. Finally depress the return key.
May 28, 2011 | Office Equipment & Supplies
How do we adjust the margins on right side of paper?
There are 2 ways.
1. You can use the program that you are using to set the margins.
  • If you are using MS Word, just go click on File (upper left), select Page Setup, and look for Margins. And you can set the margins on all sides of the paper.
  • If you are using other programs they are usually in the same location (File > Page Setup > Margins)
2. go to your Printer's directory and change settings(warning this changes the printer settings so all your documents will be affected)
  • If you are using windows, go press start and the bottom left and look for the word "printers" or control panel.
  • if you click on control panel, look for the word printers again and click it.
  • when you are on the printers window right-click on the printer, and select properties
  • in properties, look for printer preferences and left-click it
  • look for margins to change the settings.
I hope this helps.
May 18, 2011 | Office Equipment & Supplies
I am a teacher. We have Dell computers with windows 7 on them. Recently our school district downloaded Microsoft Office 10. Since the new microsoft office, my xerox phaser 8500 is printing strange. ...
Hi fsaltzman,
You need to check the margin settings in the print preview option, make sure you decrease the margins that are set by default and try printing a test page , this should work fine.
On the File menu, you need to click Page Setup, and then click the Margins tab.
Here you can adjust the margins as per your convenience.
To View page margins :-
  1. You need to go on the Tools menu, select Options, and then select the View tab.
  2. Under Print and Web Layout options, select the Text boundaries check box.
The page margins appear in your document as dotted lines.
You can use these dotted lines to correct your margins so that your student's assignments are not cut off and there is no large margin as you have mentioned in your question.
You can view page margins in either Print Layout or Web Layout view only, and they do not appear on the printed page.
Hope this helps
May 11, 2011 | Office Equipment & Supplies
I have an SX-4000 Electronic Typewriter and use it from time to time BUT I do not know how to reset the margins....basically expand them beyond the norm. Please help - I did do the ALT and then the 4 or 5...
Try this procedure to set and adjust the margin:---- Use the "Space" and "Backspace" keys to set the margins by positioning the carrier where you want each margin. Press the "Alt" key along with the "L Mar" or "R Mar" key, depending on which margin you are setting, left or right.Press ALT with L Mar key to adjust margin on left side.Press ALT with R Mar key to adjust margin on right side. ----------------- For more help.Click this link below and check page number 11:---- http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_SX4000_EN_219.PDF ------------
This should help.Thanks.Helpmech.
Jan 05, 2011 | Brother SX-4000 Typewriter
I can't get my computer to print because it keeps saying the margins of section 1 are set outside the printable area of the page. I have a meeting to go to and It's important that I get this paper off the...
I assume this error is occuring in Microsoft Word.
  1. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
  2. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
  3. Click the Fix button to have Word change the margins
    to match your printer. You should now see the Margins dialog with the new margin settings.
  4. Click OK.
May 12, 2010 | HP Officejet J5780 All-In-One Printer
HP LaserJet 2200D - margins cutting off on the left; not all docs
go to hp's website, they have an excellent site for trouble shooting.
Apr 29, 2010 | HP LaserJet 2200D Printer
Changing margins
To change or reset margins, the keys involved are the ALT key to the left of the spacebar, the #keys 3,4, & 5.
The ALT & '3' keys are used to bypass the set margins.
To bypass the left margin, move the carrier to the left margin. Press the ALT & '3' keys at the same time. Release them then backspace the carrier to the point the new margin is wanted. Press the ALT and '4' keys at the same time to set the new left margin.
To bypass the right margin, move the carrier to the right margin. Press the ALT & '3' keys at the same time. Release them and spacebar to the point where the new right margin is wanted. Press the ALT & '5' keys to set the new right margin.
The main thing to remember is to move the carrier to the point where the new margin is needed. ALT + 3 bypasses old margins, ALT + 4 sets the left margin, & ALT + 5 sets the right margin.
Feb 24, 2010 | Brother SX-4000 Typewriter
Cannot print avery labels, get message the margins of section 1 are set outside the printable page, or will run thru printer , printing complete get blank page
  1. Create a new document, with a full page of the label you are having trouble printing.
  2. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
  3. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
  4. Click the Fix button to have Word change the margins
  5. Click OK.
One thing to watch for- on some inkjet printers, the printable area is narrower than the labels. This will cause the labels to shift to the right on the page and be misaligned when you print.
If the labels run off the right edge of the page display, or are misaligned when you print, an extra procedure is needed.
  1. Undo ([Ctrl]+[Z]) the new margin setting, or create a new page from the label template again.
  2. Select the entire table of labels ([Ctrl]+[A]).
  3. Right-click the table, and select Table Properties.
  4. Click the Text wrapping "Around" option, then the Positioning button.
  5. Change the Horizontal position to Center, Relative to Page.
    Uncheck the "Move with text" option. Click OK to the Table Positioning dialog, then click OK to the Table Properties dialog.
  6. Left-click (or press an arrow key) to "deselect" the table, then go into the margins dialog (see above) and allow Word to fix the margin settings again.
With the labels aligned to the page, rather than the margins, the new margin settings should not cause the labels to shift.
Once you have the margins set correctly for your printer, I would save the empty page of labels to use as a "template".
Jun 29, 2009 | Lexmark P3150 All-In-One InkJet Printer
Margins will not hold, have to keep resetting them.
Auto margins are permanently stored in the Swintec 8014S. If you set new margins within those margins, they should hold. If you set them outside of the auto margins you will have to use the MAR REL key to release the auto margins, and then set the new margins. All margins are set by pressing the Left or Right Margin Set keys.
These settings are stored in a memory circuit that is powered by a battery that is automatically charged when the typewriter power is on. If you still have trouble with the margins releasing after you turn off the machine, you can try one of the following:
(1) Keep your typewriter on for a couple of hours so the battery can recharge and then save your margin settings
(2) Replace the battery which may have died after all these years. You would need to bring your Swintec to a local dealer for the part and replacement service.
Hope this helps!
Jay @ www.granadahillsbusinessmachines.com
Apr 06, 2009 | Swintec Office Equipment & Supplies
152 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
