Question about Homelite Mighty Lite Lawn Trimmer
Fuel Lines leak where they pass through opening into tank
The fuel lines on my homelite trimmer leak or spit fuel out where they pass through the tank. There is no gasket just a tight fit.
I had the same problem with my trimmer. you could replace the fuel line but if you don't want to hassle with fishing it thru the hole i suggest going to homelite.com and ordering the gas tank. it only cost me $18 with shipping and came with everything (tank, lines-with fuel filter, and gas cap). all you need to do is take out the 4 bolts on back of trimmer and the 2 top bolts holding the housing together. be careful not to nick any gaskets especially the one behind the 4 bolts. this is the crankcase gasket. also don't get anything in the crankcase that will score it as this will ruin the trimmer. also there are 3 spacer gaskets that go in the holes in the fuel tank and i believe a plastic heat shield between the gas tank and the bottom of the trimmer. you will see this when you take the tank off. just be careful and be sure all the bolts get tightend up (especially the 4 on the back as this is the back side of the crankcase). it only took me 15 min to replace it and the trimmer runs great. all the above info is if you have a trimmer with the gas tank on bottom. if the tank and gas cap are on top hopefully someone else will be able to help.
good luck
Posted on Jun 06, 2009
Don't try to replace the fuel lines if the leak is right at the tank. I bought new fule lines and found a small crack in the fitment on the gas tank. I had to buy the whole tank after spending money on a new fuel filter and gas line form the hardware store. Homelite sells the tank and lines together for a reason. Yes a poor design, but oyu have to get the gas tank. I strugglewd a bit more than 15 mins with the tank, but welll owrth it.
Posted on Aug 15, 2009
  • 1,040 Answers
Your fuel lines are old and brittle. This is normal ware. All you need to do is replace the fuel lines. Tip: When getting ready to insert the fuel lines, cut the lines at an angle so that they go into the holes more easily. Then square them back up after you get them where you want them.
Jim
Posted on Jun 04, 2009
  • Jim Parker
    Jim Parker Jun 08, 2009
    Did this solution solve the problem?
    Jim
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
How to replace fuel lines on homelite ut20811b gas trimmer
If there are two different size lines in the tank the smaller one is the main fuel line. The main fuel line will have the filter on the end of it in the tank and the filter should lay flat on the bottom of the tank. The main line will go directly to the carb on the fuel pump side. It is very difficult to describe and I dont have a way of giving a picture. If you have had the carb opened up the fuel pump side is the side that is mostly flat with holes and the dighram with the flaps.
The other nipple; usually more toward the center of the carb body, will go to the primer bulb. The primer bulb will have 2 different length nipples. The longer one is out to the tank, the shorter one is in from the carb. There is no need to have more than a half inch of line from the primer into the tank. when hooked up properly; as you press and release the primer bulb it will draw fuel up the main fuel line into the carb and fill the carb with fuel then from the carb to the primer bulb and fill the primer bulb with fuel then the excess fuel will be returned to the tank from the primer bulb.
Oct 22, 2012 | Homelite Mighty Lite Lawn Trimmer
Primer bulb wont prime
Most likely cause for this is fuel lines connected wrong or an air leak in one of them. Another scenario is the fuel line decayed inside the fuel tank (check it) and the filter fell off and now the line comes up out of the fuel on occasion. A clogged filter screen in the carburetor under the fuel pump cover causes this too. So...start at the fuel tank...check for cracks in the fuel lines (and in the PRIMER BULB) too, because air is unwanted in the system, but a little is always there.
Aug 11, 2011 | Homelite Mighty Lite Lawn Trimmer
Gas is leaking, I think its the little plastic gasline thats cracked thats attached to the the gas tank itself, if so, where can I find a new replacement gasline to repair it?
All small engine repair shops carry the lines you need and you may even be able to pick up a fuel line "kit" complete with fuel filter and fuel lines at your Home Depot. They carry many parts and accesories for Ryobi and Homelite trimmers.
May 15, 2011 | Homelite Garden
My Homelite Mighty Lite has developed perished fuel lines. (12 months after purchase!!!!!!) Is it possible to obtain spare fuel line.... preferably attached to a new fuel tank as well. It looks like a...
The fuel lines can be purchased separately usually by the foot from any outdoor power equipment dealer. They can be easily installed by cutting one end at an angle and "feeding" it through holes. Homelite fuel lines are of a different OD than most so make sure you get the proper size. The most popular size for Homelite is OD .203 ID .04.
Feb 12, 2011 | Homelite Mighty Lite Lawn Trimmer
Hello i have a question on changing th fuel
how to change fuel filter in gas tank remove line from carb pull line through the fill hole in gas tank remove filter replace & pull hose back up reconnect to carb & your done
Jun 27, 2010 | Homelite Mighty Lite Lawn Trimmer
My homelite weed eater sx-135 the fuel filter broke of the tube
The longest, and sometimes smaller in diameter, fuel line goes from the carb. to the bottom of the tank. It should rest comfortably on the bottom of the tank. The other line should go from the primer bulb to just inside the gas tank, (about an inch).
HINT: Cut the fuel lines at an angle before inserting them into the gas tank. This will allow you to get them in much easier.
If you need further assistance, just let me know.
Jim
Jun 07, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Replaced fuel lines and pressing the primer pump does not feed gasoline to the car.
Sounds like you have the fuel lines switched around. The fuel line closest to the primer bulb will be the shortest line. It only goes 1" or so into the tank. The other line will be the longest line, and sometimes the smallest in diameter of the two depending on the size of your trimmer, and must rest comfortably on the bottom of the tank.
Jim
May 24, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
878 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
