Question about Nikon Pronea S 35mm SLR Camera
Please let me know where i get the operation manual to change the programing on that timer 300 micro allan bradely thanks in advance for your support Azie HABIB
Try www.orphancameras.com
This web site has operating instructions for a lot of cameras
Posted on Jun 03, 2009
Cannot find the WEEK button on the DT300 as referenced under TO REVISE A SETTING. have not been able to get both of my timers to turn on the lamps i have programmed, perhaps this has something to do with...
Open following links to identify timer.
If you have different timer, then add a comment.
http://waterheatertimer.org/pdf/DT300-series-manual.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
I do not see a week button either, and sure enough the Intermatic manual says press the WEEK button to revise ON OFF times. The GE manual says exact same thing. And so does the Woods manual.
I think what the instruction means is this:
To revise programs, press Progam button as many times as needed to arrive at the program you want to change. For example program1 ON or program1 OFF etc.
Then reset the program as shown in step 5 using the Hour button to set Hour, and Minute button to set minutes, and day button to select the days or blocks of days (including all 'week' as one of the choices).
Both timers will not operate?
I test timers and a percentage arrive defective. There is no repair for defect timer. This timer has 1 year warranty.
There is no load rating on this timer, at Intermatic, GE or Woods. Timer is older style and probably rated for 500-800Watts incandescent light bulbs only.
Also test outlet with circuit analyzer to make sure polarity is not issue. This is a polarized timer, and outlet wiring must be correct for electronic timers.
Make sure each program has ON and OFF time. So set program1 ON, and then set program1 OFF. And make sure same days or blocks of days are selected for each.
When setting on and off times, make sure there are no overlaps or conflicts that cause timer not to function correctly.
Another thing is setting timer for 12:00 midnight. It's better to select 11:59pm so the day is clearly understandable to timer.
When reading complex manuals, I write out the steps until things are clear.
Sep 25, 2011 | Hardware & Accessories
We inherited a Stanley weekly indoor digital timer model 51206 without instructions. Do you know how to program it? Specifically, we want to change the timer. thank you.
I know most timers and have extensive files and manuals available and know how to program most timers.
51206 timer is not identified.
Look at options below and add a comment:
1) Open following link to identify timer, and download same-similar manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-week
2) Add a comment and clearly describe details of timer for possible identification and instructions.
3) Add a comment with link to photo of your timer posted on Flickr for possible identification.
Sep 17, 2011 | Stanley 31200 TimerMax Indoor Weekly...
I have an Amana heavy duty clothes dryer.The finish cycle buzzer sounds when start button pressed,no matter what position the timer is in(including the off position)and there is no operation. I've gone...
some dryers send out a short buzz at the beginning of each start up, so if its just that , no worries, you can just jumper the micro switch to eliminate that in locating your problem, try that and reply to this feed and I'll help you if that doesn't cure the problem
Jul 09, 2011 | Dryers
Hi, One of our client using epson lq-300+II dot matrix printer to print their invoices in custom defined paper (using crystal report). It was working fine when they were using windows xp. Now they...
Hello, Please, if you can change back to the former operating, is either the printer type is not compactable with the new windows(Windows7). But first you have to check the net to see if you can try upgrading the software of the printer. Please if you've done this let me know what happened next.
Mar 26, 2011 | Epson LQ 300+ Matrix Printer
Timers are not advancing through cycle. Dryer just continues to run. Thank you for your assistance. Chuck
Hi Chuck,
If the dryer is heating up and the timer will not advance in either time or automatic cycles, you will need to change the timer. If the timer advances in time cycle but not the auto cycle, you need to make sure it is heating properly. The timer only advances in the auto cycle after it reaches a certain temperature.
I hope this helps you at all. Please let me know if I can assist you further in this matter.
Thanks
Vic
Feb 12, 2010 | Dryers
My frigidaire top loader fills with water at the beginning of the wash...then nothing. it just sits there full of water.
Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
Aug 12, 2009 | Frigidaire FWS933F Top Load Washer
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Programing
Here is a link to the instructions for easy setting your unit:
HB88RC Timer
Hope this helps!
Dec 06, 2008 | Intermatic HB88RC - 7-Day Programmable...
Kitchenaid KAWS750JQ3 Top Load Washer
hi there,
make sure that the program is not on the "Intermittent Agitate Program". that would be the cause of the delay.
the other issue would be the timer itself. the timer is mechanical, so once the contact on it is corroded, it will only function intermitently or not at all.
please let me know if i can be of more help.
thanks
Sep 28, 2008 | KitchenAid KAWS750L Top Load Washer
Nikon Pronea S 35mm SLR Camera Logo
88 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Greg Cann
Greg Cann
Are you a Nikon Photography Expert? Answer questions, earn points and help others
