Question about Zenith B27A11Z 27" TV
Hi I got a Zenith H25C39Y and there is no menu button on the front. I have a zenith remote but it does not have a menu button either. Please help me!! I need to change some settings.
  • 68 Answers
SOURCE: Zenith H2533Y TV Entering Service Mode
wHEN YOU GET THE MENU UP YOU HAVE TO HOLD THE MENU BUTTON DOWN UNTIL THE MENU DISAPPEARS THEN ENTER 9876 ENTER. YOU CAN ALSO JUST AUTO PROGRAM THE SET AND IT WILL COME OUT OF SERVICE MODE.
LADY TECH
Posted on Dec 31, 2007
SOURCE: need a code for my tv zenith
Zenith Product Codes
TV Mode Zenith Code 101 - VCR Mode Zenith Code 201 - Cable
Mode Zenith Code 353 - AUX Mode Zenith Code 401.
Programming Codes---
TV - 101 149 175
Posted on May 07, 2008
SOURCE: Zenith remote codes
i have a nenith remote but lost codes and i have a vcr /tv combo unit tashiba what are the codes ?
Posted on Jun 20, 2008
SOURCE: ZENITH D52WLCD
I just found the solution on another model of Zenith TV. Hold the enter button down on the TV and the MUTE button on the remote. In approx. 5-7 seconds a screen will pop up asking if you want to reset the lamp timer. Hit the bullseye button in the middle of the arrows and it will reset. Worked perfectly.
Posted on Jul 12, 2008
  • 3 Answers
SOURCE: Zeith 27 inches 2001
You will need a Zenith remote with a menu button
There should be a "hidden" menu. Before you access it, I want to warn you, do NOT change any values of anything you don't understand what it is or does. You can PERMANENTLY DAMAGE YOUR TV. Also, write down the original values of anything you change before changing it!!!!!
If you still want to proceed(at your own risk), here ya go.
1. Press and hold the menu button until
the menu comes up on screen and then
times out (5 - 10 seconds)
2. Immediately press 9, 8, 7, 6, Enter.
3. The set should now be in the service menu
mode. To access most of the features
selection 00 needs to be toggled from 0 to 1
4. After your adjustments 00 needs to be
toggled from 1 to 0
5.Feature 16 unlocks the auto-program (change to 0)
Posted on Aug 06, 2008
Have zenith tv with zenith remote working fine. Wrong buttons were pushed trying turn off tv in the dark. Now remote doesn't work. Good batteries. H24F36DT. Ztv. And Zenith tv remote! Non universal..!
I don't have one of these, so a couple of guesses: turn on TV from front panel and attempt to turn off from remote. If that doesn't work turn on TV from front panel and look for setup menus which may have gotten trashed somehow. Take batteries out of remote and leave out for an hour. to see if it resets itself. Have you called Zenith help line?
Service manual: http://www.go-gddq.com/upload/2009_08/09082716157372.pdf
Feb 08, 2015 | Zenith Televison & Video
Zenith factory reset
Hi Rebecca,
Specific reset instructions will vary depending on the model of your Zenith television. For many Zenith TVs you can reset to manufacturer defaults by pressing 'Menu' then press '9, 8, 7, 6, Enter.' If this doesn't work for your set, try a hard reset: unplug your television and leave it unplugged for at least 4 hours.
You can also try this:
Instructions
    • 1 Press the "Menu" button on your remote control. Use the up and down arrow buttons to highlight the video option. Press the arrow that points to the right to select the video option.
    • 2 Use the up and down arrow to highlight the video reset option. Push the right arrow button on the remote control to select video reset.
    • 3 Press the right arrow button on the remote control to return the video to original values.
Read more: http://www.ehow.com/how_8528201_do-reset-zenith-tv.html#ixzz316gKG3ra
May 08, 2014 | RCA 50in Tv M50 Wh 92s Dlp Hdtv Works But...
How do I program channels into my Zenith sy2551s tv without a remote control? Thank you!
If your TV has a "Menu" button on its front panel, you can press it, enter its menu window, select auto tune function, and press Vol+ button. If it has no Menu button on its front panel, you must ahve its remote control to select this function.
Mar 31, 2012 | Zenith Televison & Video
I work for a Super 8 Motel chain with Zenith televisions, Model H25C39Y. My problem is recently we switched cable providers, their signal is on Channel 3, a lot of our Zenith televisions are set when you...
You have to be sure your TV, is in the auto tuning mode. If you have a cable box, this box must be on as well. Get into the menu of the TV and find set up. You will see auto channel search. The TV will note the channel needed to watch TV. Thanks for asking and show all hands of support!
Jul 29, 2011 | Televison & Video
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Zenith B27A11Z 27" TV, can't get into menu, original remote gone
Most universal or multi-brand remotes will control a TV's basic functions, but almost none will support advanced functions like menus. If the TV doesn't have a front panel menu button, the best solution is to buy a universal remote of the same brand as the TV. If you get a Zenith universal remote, it should have a menu button that will work with the TV.
Dec 14, 2008 | Zenith B27A11Z 27" TV
Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Nov 21, 2008 | Zenith DBZN-311 Remote Control
I am trying to find a universal remote code to control the new Zenith digital tv tuner converter box. The model # is DTT900. It is for a person with low vision who cannot see the buttons on the remote...
Pls post back with the brand and model of the universal (replacement) Remote Control or what remote control you would want to use with the Zenith DTT900 Digital-to-Analog Converter Box.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 23, 2008 | Televison & Video
Zenith h32h38dt 32
The "H" model Zenith TVs are hotel/motel sets designed that
a roomer cannot access the menu feature. Your best bet would
be to purchase a name brand universal remote which has the
menu button feature or order an original Zenith master remote
which would not require programming. Once you have a workable
remote which will allow you to access the on-screen menus you
should be able to program the channels.
Hope this helps,
CaseyBee
Feb 27, 2008 | Televison & Video
Lg television du-27fb32c reset to factory settings
mute on the remote and menu on tv
service mode and go to factory reset
Dec 09, 2007 | LG DU-27FB32C TV
Zenith B27A11Z 27" TV Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
