Question about Microwave Ovens
Faberware convection/broil oven (not a microwave oven). The substance holding the glass door in place has failed. I am wondering there is some service centre in Calgary,Alberta, Canada I could take it to have this problem remedied or is there some type of glue that I could purchase to fix this problem. Please advise. Thanks for your attention in this matter. James Cornock (403) 457 - 0759
  • jdcornock Jun 03, 2009
    Could you supply me with a brand name(s) of this silicone gel. Thanks.
    James Cornock
  • 65 Answers
Here is the customer help number and email address get ahold of them and explain the problem and im sure they can help u to fix it or send it some where to fix it good luck farberware-electric@saltonusa.com 1-800-233-9054
Posted on Jun 03, 2009
    Top Expert:
  • Microwave Ovens Master
  • 75,822 Answers
U can reattach this door glass with clear silicone adhesive, it is avail at any hardware store.
We experts are world wide so we would have no access to a location for u to take it for repair, but if u do want to take it in just look in the phone book under "small household appliance repair"
  • yadayada
    yadayada Jun 03, 2009
    3M, Loctite are two brands I use and are high quality. just go to any hardware store, they will know what it is.
How to replace inner glass panel on Neff H7871 microwave
Hi Bill, I am having a same problem I have managed to order the glass from:-
http://www.4neff.co.uk/cgi-bin/product.pl?PID=876912&query=Neff%20H7871N1GB%2f01&model=H7871N1GB&path=127858
1. Open the door.
2. Take out the 2 screws just behind the handle, on the inside of the door, the door should flop down at the handle end.
3. Hold the door handle and pull the door out. It is only housed in by a slip in hooks at the bottom end.
4. Once you remove the door you will see the inner metal mesh and the inner door behind it.
5. Remove the 16 screws holding the inner glass with a special star type screw driver bit no T30.
6. Once you done that the glass housing holding the inner glass can be carefully prised free and taken off the inner door assembley.
7. Once you done that remove and inner glass, and be carefull to leave the glass glass seal intact, clean around the frame housing and the seal then replace the new inner glass and reverse the process.
PS. Becareful of the inner door once you've removed the outer door, as the hinges holding the inner door tend to shut quickly as there is less weight on the hinges.
It will do the job if you follow these instructions.Good Luck. AL
Oct 10, 2011 | Neff H7871 Convection/Microwave Oven
Glass door for a Siemens microwave hf 879
I've the same problem. Inside glass broke while heating.
May 20, 2010 | Siemens HF87950GB Convection Microwave...
The turntable does not move around when the microwave is on
ths is probably a failed motor they can go open circuit i have had a few where the fixing screws underneath that hold the motor fall out severing the drive spigot ,check if the spigot turns under the glass turntable if hard to turn will be motor failed cheap easy fix.
Mar 19, 2010 | Neff H5642 Convection / Microwave Oven
The door handle cracked from the door. The unit is 8 yrs old. Replace the complete microwave or just the door? What would this unit sell for originally?
Or, if the handle itself is the only piece damaged, you can simply replace the door handle.
On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The panel is pressed in place and can be removed by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel to pry the plastic up. Work your way slowly around the perimeter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful RF radiation.
With the inner panel removed, the door handle screws are visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
You can view an exploded view diagram of your microwave at any of the following websites for reference: searspartsdirect.com pcappliancerepair.com appliancepartspros.com Just type in your model number and locate the parts listing for the door. If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Dec 23, 2009 | GE Advantium SCA1001SS Convection /...
I have a kitchenaid microwave handle to replace
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a small hinge pin that has to be removed in order to remove the door.
Sep 18, 2009 | GE Advantium SCA1000H Convection /...
To remove inner door cover
The door handle can easily be replaced on most microwave ovens without the assistance of a repairman. This is a common problem with some microwave oven doors.
NOTE: Some ovens have a small hinge pin that will have to be removed in order to remove the door.
Aug 29, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Microwave/Convection Oven - Door Glass Just Exploded!!!
This happened to us 3 weeks ago with our 3 year old Kitchenaid microwave. Several hours after its last use it just shattered. In doing research I discovered that this has also happend with GE microwaves, all 3 years old. The cause seems to have been a batch of defective glass supplied by a third party. Whirlpool was very quick to cover the cost of the replacement, even though our microwave was out of warrantee.
Aug 27, 2009 | GE JEB1095 Convection/Microwave Oven
Crack on Top of Exterior Door - Interior stained
I would STOP useing at once!! Stray microwaves seeping through the crack can be very harmfull to humans and pets! I would call the maker and complain! this is not normal for this to happen unless dropped! (door can be replaced!)
Please rate this response!
Jan 23, 2009 | Jenn-Air JMV9169B Convection/Microwave...
Owners Manual Wanted for Farberware Convection Oven T4800
I have a T4800 Farberware convection/broil oven. If you have no luck, I'll scan mine and send it to you as a PDF or post it on my website.
Nov 09, 2008 | Faberware FTU700 Microwave Oven
Microwave Ovens Logo
69 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
