Mitsubishi model vs5017s I have sound but no picture. is there a reset or a fuse
    Genius:
  • 1,239 Answers
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Posted on Jun 03, 2009
I have a mitsubishi 73 inch tv model WD-73738. No picture with sound - why is this ?
sounds like the psu. power supply unit. check the caps are not bulged
May 17, 2014 | Mitsubishi Televison & Video
Mitsubishi dlp tv turns on but all static ,no picture or sound
What is model number and do you have Mitsubishi remote?
Soft reset with set on is for most models : Menu, 1,2,3 enter.
Feb 19, 2012 | Mitsubishi WD-60735 Projection Television
Green light at start up but green light goes off
sounds like your lamp may have gone out. check your manual as to changing lamp.
Sep 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green light flashes under timer when tv is turned on. no picture
Sounds to me that the DM is the cause. If this model is 7-8 years old, it uses a DM that is no longer available or supported by Mitsubishi. You could confirm this by calling Mitsubishi at 1800-332-2119. This is there Customer Service Line.
Hope this helps,
Skyassoc
Jul 18, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitshubishi VS-6041 No picture, sound ok
It has been my experience with that model mitsubishi that the usual culprit is loss of vertical sweep. If the beams in the picture tubes stops moving up and down this is detected by the micro processor and the video is blanked, but the set is not shut down. The usual cause of loss of vertical sweep is bad solder connections on the deflection yokes or a failed vertical output IC.
May 27, 2009 | Mitsubishi VS-6041 60" Rear Projection...
Great sound no picture
lamp needs to be replaced.
Apr 16, 2009 | Mitsubishi WD-73833 73" HDTV
Mitsubishi ws65613 no picture or sound, blue screen only
Good day, Bgchzy;
This model is known for the tubes leaking fluid, glucose, on the PCB. Check the front of the chassis for said fluid, it may be only a drop, so look closely.
To fix, after TV has no power, try cleaning the board with cleaner and brush, let dry. I suspect this because of multi unrelated problems.
Jun 13, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi YS-5075
yes, this sounds like a fuse blown or open. What model is this a VS or YS?
Mar 10, 2008 | Mitsubishi VS-50705 50" Rear Projection...
50" Mitsubishi
Check the 5 volt pico fuses on the center board. F9A05 is most likley open. This would indicate bad convergence amps. The two Convergence amps and fuse should be replaced.
Josh
Mar 02, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Dec 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Electro Med Services...
