Question about Toshiba Satellite M45-S169 Notebook
The pc start but dont turn on the screen ?
My pc have already overhauled but suddenly the screnn stay on black dont display any graphics , the pc may seen running ok i only have this issued
  • Toshiba Master
  • 32,281 Answers
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Jun 04, 2009
Acer aspire 5155 turns on but wont start
I am guessing that you already removed the battery and re-installed it. IF not, try it.
Good luck
Joe
Jul 15, 2014 | Computers & Internet
The phone comes on but screen stays black
menu>settings> display keyboard is there
set your screnn display/time ou to 2 min; set your keyboard to 1 min
jeffrey3535@comcast.net
Nov 18, 2011 | Nokia 5230 Cell Phone
When i was working in my compaq presario C765TU suddenly the screen went black.
Hi, If it is black but you barely see the desktop or so it is bad display lighting, i dont know if it can be replaced but maybe you need to change whole screen But if your screen is black at all it looks like graphics died
May 06, 2011 | Computers & Internet
I was watching a movie on my laptop yesterday when the movie froze. So I turned off the computer, now everytime I turn it on, the screen stays black and nothing will come up. I can't get anything to start...
If your screnn is not showing up anything, even the BIOS screen while booting up. Then it could have damaged the Graphics card. You'll have to mostly replace *********** board. Your vendor can provide you a replacement price instead of buying a brand new one.
To avoid these scenerios of graphics card buring out, i would suggest to use the laptop keeping on a flat surface, especially not on pillows, bed and lap. Also dont use the laptop always connected to the power adapted. Connect only when the battery goes down. This will increase the battery life too.
Mar 25, 2010 | Gateway MX6956 Notebook
TURNING ON BUT NO SCREEN DISPLAY
Did you try to connect to external monitor see if you get picture?
If does, You need to look very close the laptop LCD if you have seen any shadow pictures? if does your Inverter or Bulb is Gone. If no pictures on external, Your graphic card is done.
JMC
Aug 18, 2009 | Acer Aspire One PC Notebook
Screen stays black on startup of toshiba satellite L300
have you tried either switching between external and internal monitor usally Fn + F5 on toshiba or try plugging a monitor into the back and see if it displays.
if you get a display on the external monitor then its probably a screen or inverter fault if you donot get a display to an external screen then it is likley t be the graphics on the board itself.
hope this helps
Feb 22, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
Video problem on my Dell Dimension 4600 PC, HELP ASAP.
the resolution set by default when you load your graphics driver is outside the range of your monitors capability.
try starting in safe mode then adjust your resolution to 640 by 480 then restart.
if this works, adjust upwards to 1024 by 768
then up again till the screen blanks.
when it does, dont panic, wait 20 seconds and the settings will restore - you then have the optimum settings for your monitor.
good luck
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
Compaq presario laptop display problem
Use system restore to bring back the computer to a date before the one you started to have troubles with the screen. After this you may need to reinstall display drivers, as you installed an older version after getting in troubles.
cheers
Feb 14, 2008 | Computers & Internet
BAD DISPLAY
Try replacing your video card. That video card may not work with your motherboard.
Dec 05, 2007 | Compaq Evo D500 PC Desktop
BAD VIDEO CARD
The only thing u can do is to change ur graphic card
Nov 28, 2007 | Computers & Internet
Toshiba Satellite M45-S169 Notebook Logo
62 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
